Blowoff Valve Sound from engine after it is shut off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shigs, Jan 27, 2013.
  1. Jan 27, 2013 at 7:11 AM
    Shigs
    Shigs [OP] Active Member
    South Florida
    12 Tacoma XSP-X
    I am not sure what to make of this. I have an 2012 V6 Tacoma. I normally don't just start up my truck and shut it off right away but the last 2 days I've had to do it to move it over a few feet with a total run time of maybe 30 seconds. When I shut the truck off the engine turns off but I hear what sounds like the radiator fan or an electric motor still running then about 3-5 seconds later a pressure release sound almost like a blow off valve on a turbo. I was able to reproduce it several times this morning. It only seems to happen when the engine is cold, it runs for a short period of time, I use the brakes, and shift. I am still trying to catch where the sound is coming from but by the time I get to the engine bay there's not enough time to really tell. I was able to see though that that the radiator fan is not moving after the car is shut off and the sound is present.
    Any ideas?
  2. Jan 27, 2013 at 7:12 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    smog pump, seems to be a common noise from the 12's
  3. Jan 27, 2013 at 7:28 AM
    Shigs
    South Florida
    12 Tacoma XSP-X
    Thanks for the quick reply. I tried searching but I never would have thought to search for smog pump but now that you mentioned it and I read up it seems to fit the bill. Thanks.
  4. Jan 27, 2013 at 7:35 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
  5. Jan 27, 2013 at 7:59 AM
    Shigs
    South Florida
    12 Tacoma XSP-X
    I haven't heard that sound yet but you probably just saved me some research with the heads up. Thanks.
  6. Jan 27, 2013 at 8:09 AM
    12Tac
    12Tac Well-Known Member
    Colorado
    2020 Double Cab, Long-bed TRD Off Road.
    SnugTop, FN Wheels, Meso Custom, Tacos4Cheap
    Mine does that when its first started...probably around 10 seconds are the engine is running. Asked the dealer about it on the last visit, they either didn't know or the tech I talked with just didn't give a rip to investigate. I've read elsewhere its normal for that type of engine in the 2012s.
    12Tac
  7. Jan 28, 2013 at 6:45 AM
    k9cinco
    k9cinco Active Member
    New Jersey
    2012 double cab sb 4x4
    None yet
    That motor is used to blow air into your egr system to stabilize your air/fuel ratio upon startup and shut off...its normal
  8. Jan 28, 2013 at 7:27 AM
    EFalco50
    EFalco50 Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
    Mine does that on cold morning, sounds like a whine noise for a few seconds then once the engine warms up a bit a blow offf sound will emit and it goes away. Seems normal to me!
  9. Jan 28, 2013 at 7:36 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
  10. Jan 23, 2015 at 10:59 AM
    fpf
    fpf Well-Known Member
    TRD PRO
    New here. Glad I found this thread. I had an appointment scheduled for tomorrow to have this noise diagnosed. The weird thing is I never heard this sound coming from my friends 2013 taco so that's why I was fairly concerned. Do all of these have this sound or just a select 'lucky' few?
  11. Jan 23, 2015 at 3:05 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Taco fart!
  12. Jan 23, 2015 at 7:03 PM
    thenax
    thenax New Member
    Black Hills, SD
    2013 DCab
    Elka 2.5, Headstrong AAL, Camburg UCA, Smittybilt RTT, C4 fab bed bars, Diode Dynamics LED fogs and 6" driving lights
    Just got my 2013 and had it in for another reason and got an explanation on what it was but not why it runs after engine shut off for some and not others.
  13. Jan 23, 2015 at 7:20 PM
    Fahrenheit
    Fahrenheit Well-Hung Member
    Garth
    NS
    Mine does it, it's explained in another thread, same as the high pitched whine from the fuel tank 4 hours after its stopped running, all normal :)
