Blue Screen on my PC
Discussion in 'Technology' started by sammy87, Jan 19, 2012.
  1. Jan 19, 2012 at 9:15 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    it can also be the result of hardware issues.
  2. Jan 19, 2012 at 9:16 AM
    sammy87
    sammy87 [OP] Well-Known Member
    co
    10 TRD SPORT 4X4
    I dont think i have the cd. I work from home, and they gave me the computer from my office, so I would have to search there to find it.
  3. Jan 19, 2012 at 9:20 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Incorrect. You can most definitely get the blue screen of death via overheating. The most popular BSOD caused by overheating is the 9C-MACHINE_CHECK_EXCEPTION error. This sounds a lot like some sort of hardware error to me honestly, unless you have a program in the background that is executing improperly... :notsure: Wanna do a data log for us, and then we could at least rule out a couple things.
  4. Jan 19, 2012 at 9:22 AM
    cc350
    cc350 Retired Member
    You'll need to install http://www.malwarebytes.org/ it's a software issue. Then clean your computers hard drive up. Run anti virus also, and maybe defrag. A conflict in software is the most common thing to cause blue screen.
  5. Jan 19, 2012 at 9:25 AM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    If its a hard disk issue, its most likely a hardware issue. Dust and overheating has a big part to do with it. Where i work our computers sit on the ground. When i do maintenance on them i clean them out and you would think its a sandstorm with all the dust that comes out. When a CPU/GPU overheats and is covered by dust the heat cannot get proper airflow. When the heat has no where to go, it fries the hardware components.
  6. Jan 19, 2012 at 9:27 AM
    memario1214
    Colton
    Missoula, MT
    Also, which operating system are we running here?
  7. Jan 19, 2012 at 9:29 AM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    Just because it referenced the hard drive doesn't mean thats the problem. At the bottom of the blue screen there will be a code, eg. 0x000000. That code will tell you most everything you need to know. As of right now with the information you have given it could be anything.
    More than likely its something in the OS is corrupted. Do you know how to post a data log? It would tell us the code since you said it only happens once a week.
  8. Jan 19, 2012 at 12:22 PM
    myname150
    myname150 Well-Known Member
    First do this because most computers are configured to restart automatically:
    1.) Right Click on My Computer and choose properties (or Computer for Windows 7/Vista then on the left click "Advanced System Settings")
    2.) Go to the Advanced tab, then under Start Up and Recovery, click settings.
    3.) Uncheck "Automatically Restart". Click OK.
    So once it blue screen's again you can actually catch the error codes and write it down. I circled what we'll need. The "gv3.sys" part is really useful too, it could end up being just a driver that got corrupt (yours will be different from gv3.sys, i just got that picture from the web.)
  9. Jan 19, 2012 at 12:49 PM
    sammy87
    co
    10 TRD SPORT 4X4
    Im running windows 7 on this btw...ill try the steps listed and see what I can find. Ill report back a bit later.
    Thanks again everyone!
  10. Jan 19, 2012 at 8:34 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    could be a driver/hardware issue,.... in my experience, i'll get a problem every so often w/ the video card... i also blame the windows screensaver/powermgmt crap for causing problems too..
  11. Jan 23, 2012 at 3:35 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    You can also try doing a system restore. Choose a restore point from before the problem started occuring. Booting into safe mode will give you the option (hold down the F8 key while booting and choose safe mode.
