Blue Sea Aux Fuse Block Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adamberliner, Aug 16, 2014.
  1. Aug 16, 2014 at 7:02 PM
    adamberliner
    adamberliner [OP] Member
    Maine
    2013 Access Cab 4x4
    ARE MX Cap Custom built sleeping platform Aux Fuse Block LED Bed lights
    Howdy. Thought I'd share this super simple install for anyone else looking to organize their electrical accessories and clean up their wiring. Thanks to several members of this forum for inspiration.
    I purchased the Blue Sea 6 circuit fuse block with a negative bus, in order to keep all of my wiring as clean as possible. I installed a 100 amp circuit breaker in front of the fuse block.
    I made a mounting bracket out of a small piece of sheet steel. I first bent the steel to fit in the spot just behind the factory fuse block, using the OEM mounting holes above the wheel well. The angle is slightly more than 90 because the mounting location is angled outward just a bit. I used a heavy hammer and a block of wood to bend the steel - not perfect, I know, but cheap, quick, and effective if done carefully. I cut the bracket to size, and drilled holes to mount the bracket to my truck, and also to mount the fuse block and circuit breaker to the bracket.
    I cleaned up all the holes and cuts with a file, and then sanded the whole piece smooth. I primed the bracket and then painted it with Rustoleum Gloss Black engine paint.
    I installed the fuse block and circuit breaker to the bracket using 3/4" machine screws, with washers and lock nuts.
    I attached the completed bracket assembly to the truck using the OEM mounting holes. (The OEM holes accept M8 1.25x25mm screws).
    Next up was the wiring. I measured and cut 4AWG wire, and crimped and soldered on copper ring terminals. These all got heat shrink tubing, and I used red electrical tape to denote the positive leads. Then it is simply a matter of wiring it all up. Run a wire from the positive battery terminal to a terminal on the circuit breaker. Run another wire from the other post on the circuit breaker to the positive post on the fuse block. Finally, ground the fuse block by running a wire from the negative post on the fuse block to the frame (I used the same bolt as the battery ground). (This is only necessary if you are choosing to run a fuse block with a ground bus, as I am). I ran two of the wires underneath my mounting bracket to keep things neat.
    Only had time today to pug in my bed lights to this, but it will be almost full once I get around to moving some other wiring to this block.
  2. Aug 16, 2014 at 7:17 PM
    medic2230
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB 2019 TRD PRO 4runner
    Nice well done write up!
    Great job! Welcome to TW!
  3. Aug 16, 2014 at 7:23 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Nice work!
    Thanks for the posts.
  4. Jun 8, 2015 at 9:48 AM
    CaptainReverso
    CaptainReverso Instagram @ CaptainReverso
    Cory
    Los Angeles
    2015 TRD off road 4x4 DBL cab Magnetic Grey
    Full weather tech floor mats, hid fog and headlights, window tint, Yotamac aux fuse plate, black plasti dip badges. 4' saber whip. Infinity kappa 6x9 front speakers, Infinity kappa 6.5 rear speaker, full Icon stage 4 suspention with billet upper control arms, prinsu design roof rack
    looks good! do you just have the box hooked up to the battery straight up so its always live? or did you tag it into the ignition power?
  5. Jun 9, 2015 at 1:03 PM
    adamberliner
    Maine
    2013 Access Cab 4x4
    No the fuse box is run straight from the battery, with a circuit breaker in between. If I wanted to kill the power to the block for any reason or prevent accessories from drawing down my battery, I could easily flip the breaker off. Eventually I'd like a second battery in there, but for now, I want to be able to run some low amp accessories (LED bed lights, outside lighting, etc) while I camp without running my engine. Would not be hard to have this be switched to your ignition though.
  6. Jun 9, 2015 at 1:12 PM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    Beaufort, SC
    Mods: sand, dog hair
    What circuit breaker did u use? Got a link? Nice job
  7. Jun 9, 2015 at 1:39 PM
    CaptainReverso
    Cory
    Los Angeles
    Powerprozeus, Toynado and ruffridha9 like this.
  8. Jun 9, 2015 at 1:46 PM
    adamberliner
    Maine
    2013 Access Cab 4x4
  9. Jun 9, 2015 at 2:18 PM
    CaptainReverso
    Cory
    Los Angeles
  10. Jun 9, 2015 at 2:35 PM
    adamberliner
    Maine
    2013 Access Cab 4x4
    Cool! Might just have to order one (or make one up myself) to fit some new relays I've messily jammed in there since the original install.
  11. Jun 9, 2015 at 5:03 PM
    CaptainReverso
    Cory
    Los Angeles
    Yeah haven't got my wire harnesses with my relays hooked up yet. I'll see what I end up doing with them then i all repost
  12. Jun 22, 2015 at 6:36 PM
    baurat88
    baurat88 Well-Known Member
    California
    '14 DCLB 4x4 TRD Sport JBL NAV
    TRD skid, BAMF light bar, 20in double row LED bar
    nice install in just got my plate from Ze as well. What kind of bolt did you use to mount the breaker and the fuse block? and Size and did you use a lock washer and bolt underneath? excited to mount it. Just wanna get the right bolt sizes Thanks!
  13. Jun 22, 2015 at 6:41 PM
    CaptainReverso
    Cory
    Los Angeles
    The fuse box I just pre drilled through the aluminum then used short metal screws that hold perfectly. The breaker I used extra bolts I had laying around. No lock washers just lock nuts. With the plastic
  14. Jun 22, 2015 at 6:45 PM
    baurat88
    California
    oh ok the nylon washers. Do you know what size by any chance? I wanna head over to home depot now to pick some up. If not no worries, i'll bring them into the store with me
  15. Jun 22, 2015 at 7:11 PM
    CaptainReverso
    Cory
    Los Angeles
    Yeah off hand I don't know I'm sorry :(
  16. Jun 22, 2015 at 7:22 PM
    09 Redneck
    09 Redneck Well-Known Member
    Ga
  17. Jun 22, 2015 at 8:52 PM
    baurat88
    California
    all good i just got back frome home depot. The breaker i used 1/4 x 1 inch long screws with matching nuts, blue sea fuse block i bought #8 3/4 long screws with nuts. Just drilled them in. perfect fit
  18. Jun 24, 2015 at 12:36 AM
    Midship909
    Midship909 Well-Known Member
    SocaL
    13 MGM 4x4 OR 6speed
    Where did you purchase your fuse block and breaker. Great write up
  19. Aug 14, 2015 at 3:35 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Where did you get the new wire and terminals for the lines from the battery to the breaker? certain gauge that it needs to be>?
  20. Aug 18, 2015 at 9:29 AM
    adamberliner
    Maine
    2013 Access Cab 4x4
    Both are from Amazon.
    Fuse Block
    Breaker
    Also ordered from Amazon:
    4 AWG Wire (I used ~4')
    4 AWG Ring Terminals
    I pulled the silly little red and black connectors off the ring terminals, and used good quality heat shrink instead over all connections. I also took the time to both crimp and solder the terminals onto the 4AWG going to the battery/ground. The terminals are big and beefy, so I actually used a hammer to crimp them down, then filled in the connection with a healthy but neat does of solder. The other connections are all crimped.
    Toynado likes this.
