Blue Sea Aux Fuse Block Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adamberliner, Aug 16, 2014.
  1. Mar 1, 2016 at 11:52 AM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    What gauge sheet metal?
  2. May 25, 2016 at 6:22 AM
    hackeradam
    hackeradam @the.trd.pro
    Adam
    HTX
    2017 Cement LT TRD Pro | 1965 FJ40 383 SBC
    I fab'd up a plexiglass aux fuse block panel for an 8 circuit Blue Sea w/o ground, and a main fuse. Tapped holes to hang 5 relays off the back. Didn't bother with a brace like most, and just made it low enough to where the bottom rests atop a factory relay.
    Ncpi007, gavia, jammer and 4 others like this.
  3. Jun 9, 2016 at 8:44 PM
    ruffridha9
    ruffridha9 Well-Known Member
    West Coast
    2012 Tacoma base
    stock ish
    Does anyone know if there is an advantage/disadvantage to having The circuit panel with or without a negative post?
  4. Jun 9, 2016 at 9:16 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Nice! Just started mocking my aux box up, having to get a little crafty with my clutch master cylinder though
    CD5A9361-DA22-4C4C-9E26-8E9D5D78CA96_zps_430519fdd516e534d9b03e8b7c972b86522a6060.jpg
  5. Jun 9, 2016 at 9:27 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I just used a piece of aluminum that I cut incorrectly for a fill plate on an airstream. I like the breaker use with this, I might have to pull the one from my car when I add a relay box below the fuse panel.
    More work is required on mine to get it looking good like y'all's.
  6. Jun 9, 2016 at 10:10 PM
    hackeradam
    Adam
    HTX
    There is no advantage/disadvantage for either/or. Since we're talking vehicles made of steel, you don't need one with an integrated grounding post - you can ground anywhere on the truck. Blue Sea systems is marketed around the marine market (hence the name, obviously). Boats are typically nonmetallic, lacking accessible grounding points. Thus, having a block with a central ground makes sense in that scenario.
    Then again, that's a biased opinion...
  7. Jun 10, 2016 at 7:19 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Another approach -
    JHEAL77 likes this.
  8. Aug 4, 2016 at 9:01 PM
    ruffridha9
    West Coast
    2012 Tacoma base
    stock ish
    Thanks man-
    Really digging the plexi.
    I'm using Lexon and plan to do similar multi-bent platform
    hackeradam[QUOTED] likes this.
  9. Dec 9, 2016 at 11:38 AM
    gfiber
    gfiber Well-Known Member
    Gary
    Seattle, WA
    2017 Black TRD Sport Access Cab
    TRD sport pkg, Towing Pkg, Ham radio installation, bed lights, front 32 inch LED Bar behind the grill.
    I wire up my ham radio equipment using a similar fuse panel and relay shelf. Though all of yours look nicer than my old one, have to get better. I use a remote controlled relay to control 2 - 12 volt 40 amp relays. doing this I just hit a remote control button and all my ham radios turn on or off. Have some 1/4 inch black ABS at home and made the original "shelf" out of it, used those 2 factory threaded holes to mount mine too, wonder what accessory they are there for ?
    Neatness counts so it is back to the layout mode for me this weekend hahaha.
  10. Jun 7, 2017 at 10:30 AM
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    Dude thanks much for this write up there OP I'll literally be following this step by step when I do mine here in a few weeks.
  11. Jun 7, 2017 at 11:20 AM
    njcoma
    njcoma Well-Known Member
    California
    2017 Accord Sport Special Edition
    Previous: 2006 Tacoma SR5 Prerunner: 2010 4Runner sr5 Rims, TSB rear leafs, Wetokole neoprene seat covers, JVC LED color matched head unit, scanguage II, Flowmaster 40 cat back exhaust, hankook dynapro atm tires, Class 4 Uhaul Hitch. Kicker 12 inch sub and amp. Focal speakers. jba offroad UCAs.. Detroit truetrac rear end... bilstein 5100 rear and 6125 front coilovers. Nfab front bumper with KC apollo lights, bed lights, bluesea systems fuse box....lots of painted stuff.
    Did the same thing here. Same box. Same place.
  12. Jun 7, 2017 at 3:22 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    If you are no capability of cutting sheet metal, the top of the fuse box is a good place with plenty of room:
    PzTank likes this.
  13. Jun 7, 2017 at 9:28 PM
    jagergirll
    jagergirll Well-Known Member
    Sam
    Midwest
    4x4 RC
    OME Suspension ARB Bumper Rock Sliders BFG KO3's Camper Shell
    Super easy. Just painted it tonight and I'll set it back up in the morning and start wiring. Let me know if you want info on how it made it.
    Montanaguy, PzTank and uh_salt_rifle like this.
  14. Jun 11, 2017 at 12:35 PM
    Montanaguy
    Montanaguy Active Member
    Missoula, Montana
    2013 dbl CB lb
    18x9 Fuel rims, All-Pro Pack Rack cut to 14". CVT Mt. Rainier RTT with 79" awning, Thule rack over cab. Rotopax gear. Bilstein 6112 coilovers/5100's and Dakar leaf pack
    Awesome post guys! Thank you! I'm currently on a ship I work aboard and wondering if any can give me close measurements of the panel. Mostly just clearance and doesn't have to be exact.
    I would like to cut and fab everything in our fully loaded maintenance shop before I go home in a couple of weeks. Lol. Thanks in advance!
  15. Sep 20, 2017 at 5:21 PM
    #35
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Let me preface by saying I'm still learning, lol. If I followed this installation and installed a breaker with fuse box, do I wire my relays from the fuses coming off this box? Would this eliminate the need for in-line fuses? Would I still need the add-a-circuit to tap the signal for my switches to go on/off with the truck power? Thanks!
  16. Sep 21, 2017 at 10:11 AM
    #36
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    I think I'm reading this right, but someone else please chime in:
    1) If you're running power out of a fuse box (like the blue sea) and each line has a fuse (5A, 10A, etc.) you would run the main power from the fuse box to the Relay for whatever it is controlling.
    2) If you want your relay'd items to only work when the ignition is on then you will need a control line from an add-a-circuit to the relay. I've only done this for non-switched items (internal USB power items). For my lights and such, I wanted them on even if the ignition was turned off.
    Here's the part I need others to verify:
    3) If you want something on a switch that also only works when the power is on then you need two relays. Your first relay would have main power from a fused circuit in the fuse box, but only open if the ignition is on. That power output would then go to a second relay that is controlled by your switch for your lights or whatever. If you do this you'll either need a super beefy first relay to supply power to all your secondary relays, or you'll need multiple pairs of chained relays and will probably want to run your "Ignition control" add-a-circuit to a bus bar so that multiple relays can use a single signal input.
  17. Sep 21, 2017 at 10:26 AM
    #37
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Thanks, that all makes sense. I should have clarified on 3, the ignition controlled portion of my switch is just for the illumination within the switch. I want power at those switches even when the truck is off, just don't want the lights in the switches running down my battery when the truck is off.
  18. Sep 21, 2017 at 10:31 AM
    #38
    i8boots
    UT - 801
    I haven't installed any switches in the cab yet, but from what I've seen on tutorials people are daisy-chaining the illumination power from other switches in the console which already have the ignition control so they all go off when the truck is off.
  19. Nov 20, 2017 at 3:58 PM
    #39
    rannon
    rannon Active Member
    Hi guys, quick question here - with this setup, if I wanted to run a light bar for example, do you have to use a relay in between the blue sea box somewhere? How would that work?
  20. Aug 28, 2018 at 1:29 PM
    #40
    Sauzacoma
    Sauzacoma IG: @Stancaban
    Southern California
    2017 TRD Off-Road (DCLB)
    How did you come to find that the 100 Amp breaker was sufficient? I would want to know that my breaker would trip when needed, 100 A seems big but I could be wrong.
