Blue Sea aux fuse block install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tooblutacoma06, Jan 14, 2010.
  1. Apr 13, 2010 at 6:34 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I like. What's the best way for me to save this so I can find it again ?
  2. Apr 13, 2010 at 7:40 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Hmmm I really like this. I might have to use a similar setup for my Z as I gotta re-wire it anyway... :D
  3. Apr 13, 2010 at 7:41 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Subscribe to thread. You already did by replying, or near the top of the thread there is a place to subscribe without replying. Find it again through your User Control Panel
  4. Apr 13, 2010 at 10:48 PM
    george3
    New Jersey
    Thanks. User Control Panel is the upper right corner, right.
  5. Sep 12, 2010 at 7:16 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    subbed.
  6. Oct 28, 2010 at 8:32 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    looks great.
    1 question though. Since power is straight off the battery, won't all of your accessories be hot all the time?
  7. Oct 28, 2010 at 9:52 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    thats the whole point of relays...
    custom car audio huh...!!
  8. Oct 28, 2010 at 9:57 PM
    tooblutacoma06
    tooblutacoma06 [OP] Member
    Kellon
    Houston
    Yups! Relays FTW.
  9. Dec 7, 2010 at 3:56 PM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    beautiful!
  10. Dec 7, 2010 at 5:39 PM
    RCL
    RCL Well-Known Member
    Bob
    Oklahoma
    2010 TRD Dbl. Cab
    Winch
    Great job. I seriously need to consider this.
  11. Dec 8, 2010 at 2:45 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Looks great! But I really dont understand the wiring of this stuff, lol.
    From the + battery, you run a wire to the 100a circuit breaker, then from circuit breaker to the fuse block? Is there a ground coming off that fuse block to the - battery terminal (think I answered my own one here... gnd comes off the back and hard to see I think)? From there, you just ground any accessory and run power to one of the terminals on the block?
    Are the 187 series breakers ok to go w/? One you listed seems to be being phased out.
    This looks like a great setup, and would be awesome as I start to add accessories, I'm just partially retarded when it comes to the actual wiring :eek:
  12. Dec 10, 2010 at 7:38 PM
    tooblutacoma06
    Kellon
    Houston
    Yep you got it. You don't have to run grounds for your accessories back to the block though. You can ground them anywhere. I just did it to try and keep things visible so I can trace them if necessary.
    Those breakers should be fine. Just a new look to replace the old ones. Do the same thing though.
  13. Dec 10, 2010 at 8:10 PM
    cactuscorn
    cactuscorn Another FNG
    Rapid City, South Dakota
    2019 Cement TRD OR AT DCLB w/JBL Premium Package
    Ironman Stage 2 FCP 3" lift kit, Ironman skid plate kit, C4 Fab Hybrid front bumper and frame supports, C4 Fab sliders, Smittybuilt X2O 10k lb winch, Diode Dynamics Pro fogs, Baja Designs Sport fogs, Falken Rubitrek AT's, Midland Micro MXT275 GMRS radio, Victory 4x4 hood hinge antenna mount, ARE MX shell, 12 Volt Solutions remote starter w/ phone app module, Overland Equipped aux power tray/Blue Sea 12 circut ST blade fuse block w/ 187 series 100a circut breaker, OEM bedmat and floor mats, Hooke Road tailgate cover, JDM ASTAR 800 lumen LED reverse bulbs, iOttie wireless phone charger, blue LED dome light, back seat dog bed and rear seat12v/USB ports, Ironman diff breather, ac drain mod,, tons of rad recovery equipment and every cubbyhole filled with crap. On order: Method MR 316 wheels and 285/70R/17 BFG KO2's.
    from another electronically challenged guy, thanx for not talkin over our heads and makin this a doable project.
  14. Jan 28, 2011 at 12:42 PM
    mickyd9990
    mickyd9990 Well-Known Member
    marc
    ri
    07 tacoma off road
    awsome write up,, supeer clean...
    you used a 100 amp circuit breaker correct.. like this one?http://www.boatersworld.com/product/MP63496989.htm
    also where is a good place to buy odd and end electrical stuff online.. like switches relays and all that stuff??
  15. Jan 28, 2011 at 12:52 PM
    #35
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
  16. Feb 4, 2011 at 2:43 PM
    #36
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Would you happen to remember what # screw you used to mount the panel to the factory holes under the hood?
  17. Feb 13, 2011 at 5:30 PM
    #37
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
  18. May 15, 2011 at 12:47 PM
    #38
    ryrydtl
    ryrydtl Well-Known Member
    Cailifornia
    2019 Tacoma Pro
    Very clean. on my build i plan to replace the my amplifier fuse with circuit breaker as well. do you recommend this or no?
  19. Feb 15, 2013 at 6:12 AM
    #39
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Ilike the newer pics that you posted. Very clean.
  20. Feb 15, 2013 at 6:23 AM
    #40
    rtn1911
    rtn1911 Well-Known Member
    Richard
    CA
    2013 MGM 4x4
    I had a similar setup on my 2004 Tacoma, without the custom powder coated mount.
    You did a nice, clean job.
