Blue Sea Fuse Block Questions
Discussion in 'Lighting' started by TACORIDER, Dec 20, 2013.
  1. Dec 26, 2013 at 8:46 PM
    #41
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Once I get it all ran and installed hopefully tomorrow I will take you some pics and explain the hookups.
  2. Dec 26, 2013 at 8:49 PM
    #42
    TACORIDER
    TACORIDER [OP] Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Thanks Adam I really appreciate it
  3. Dec 26, 2013 at 9:00 PM
    #43
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    Stinger makes 50Amp to 200AMp I currently run a 100 amp on my amplifiers.
  4. Dec 27, 2013 at 5:55 PM
    #44
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    The blue sea box is rated at 100 amps. This is why you should run a 100 amp breaker. If you run anything larger, then the fuse block will melt and catch fire during a bad short or fault before the breaker trips, which would defeat the purpose of the breaker.
  5. Dec 28, 2013 at 10:18 PM
    #45
    Pcyc
    Fritz
    Concord, CA
    okay. in that case i will get a 100amp stinger breaker and save $75 bucks.
  6. Dec 28, 2013 at 10:51 PM
    #46
    ProForce
    Anthony
    Alaska
    I have the Cooper Bussmann 100 amp breaker from Autozone. Ive seen many members use this model and it works great. water/weather proof and only $29.99.
    All Blue Sea Block are rated at 100amp per block max (30amp per circuit max). So if you had the 12 circuit block and ran a 30amp accessory on each circuit (360 amps) that would be fine but you cant have more than 3 things turned on at once. Get it? If your total block exceeds 100 amp draw then you risk damage to your components or the block and also risk a fire or even battery damage.
    This is why you want to limit the breaker to 100amp because that way if in the unlikely event you turn on more than 100 amps worth of stuff then your breaker will trip and protect everything. Its only a fail safe and also a reminder to you to not use more than 100a on the block.
    So anyone using a 150 or 200 amp breaker on your blue sea box might want to change that out because its a giant waste of money and space since its not protecting anything at all. Just a heads up
  7. Jul 12, 2016 at 8:47 PM
    #47
    ruffridha9
    ruffridha9 Well-Known Member
    West Coast
    2012 Tacoma base
    stock ish
    I'm so glad I found this thread.
    This electrical jargon is a whole new language to me, but Definately learning a bunch before I start working on my install, so thanks to all for sharing your insight.
    I see most folks use a fuse block with a ground post.
    My gf bought me one with out it.
    From the limited info I could find, sounds like this version (without ground post) makes it a little harder to troubleshoot in event of malfunction.
    Does anyone know of any another cons?
    Also, seeing as there is no negative post, can the grounds running from say lights be connected anywhere near them, Or should they run to the ground connected to the negative post of the battery, or even negative post of battery itself?
    Thanks in advance
  8. Aug 3, 2016 at 4:50 PM
    #48
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    Great info in this thread.
    What's the ideal guage wire to run between the block/relays & relays/switches?
    How do you know what size fuses to use? I'm assuming the lights (which are in order) will say but figured I'd ask here.
  9. Aug 4, 2016 at 1:53 PM
    #49
    Kohan21n
    Kohan21n A caffeine dependent life form - IG @dizzy.trd
    Nazareth, PA
    2016 DCSB MGM 6MT
    +1 Would like to know these same questions also!
    Also looking for some pictures of the way you guys have the relays mounted. I am very picky and don't want a 'sloppy' look.
    Toynado[QUOTED] likes this.
  10. Aug 4, 2016 at 2:38 PM
    #50
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
