blueprints for a dual 8 ported L7 box?
Discussion in 'Audio & Video' started by cmytacoma, Nov 14, 2011.
  1. Nov 14, 2011 at 4:55 PM
    cmytacoma
    cmytacoma [OP] Well-Known Member
    Humboldt county NORCAL
    05 black DC LB sport
    Eclipse AVN 6620, Diamond audio 4.5" component in kicks, center channel with same mid and 2 tweets, infinity kappa perfect component 6.1 in front doors, kappa 6.1 coax in rear, sx900.4, fosgate power 1000, 06 L7 in ported box. BHLM, custom made sliders,
    Anyone have any blueprints for a double cab behind the seat dual ported 8" box? was gonna go under the seat but the cost and time outwieghs my budget. Have two 2 ohm 8 L7 8s and trying to find the best design for them in a ported enclosure or should i really save the money and just get a supercrewsound sealed box? suggestions...
  2. Nov 16, 2011 at 2:29 PM
    cmytacoma
  3. Nov 16, 2011 at 2:32 PM
    bendbolden
    bendbolden Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I have always like sealed better but ported sounds okay when done right. I would be worried about size though. I believe a ported box generally takes more size than a sealed box. Someone correct me if I'm wrong. If it were me I'd go sealed.
  4. Nov 22, 2011 at 12:55 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '06 DC LB 4x4
    OME lift w/ Dakars & 885's Remote Start w/ window control
    OP - Post up some specs AND pics of the subs (or are you buying new?) and i'll do what i can to help...
    but also, this
  5. Nov 22, 2011 at 1:00 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    It all boils down to how much bass you want and the space your willing to sacrifice for it. If you want loud bass then Yes, if you need all the space back there then NO on the 8's.
  6. Nov 22, 2011 at 1:09 PM
    rectoyo
    rectoyo Well-Known Member
    Robert
    South Gate, Ca
    15' PreRunner SR5 Blk Badges
    Fogs on Anytime
    Question will Fosgate P2's bass sound good in a double cab limited pace and will they have enough room for good solid bass? If anyone has an answer to that question or point me in the right direction I appreciate it Thanks.
  7. Nov 22, 2011 at 1:12 PM
    TurboGT
    Gabe
    Portland
    '06 DC LB 4x4
    lol... are you following me from thread to thread?? :)
  8. Nov 22, 2011 at 1:14 PM
    rectoyo
    Robert
    South Gate, Ca
    Fogs on Anytime
    Space*
  9. Nov 22, 2011 at 1:14 PM
    Johns Taco
    Albuquerque, NM
    Lol, I guess we just have some things in common / similiar interest. :)
  10. Nov 22, 2011 at 1:18 PM
    Johns Taco
    Albuquerque, NM
    I am a diehard RF guy, I only buy the best they make. However.....i'm not sure about there mid level stuff, there are better brands out there. I would go to JL personally if your looking for a good middle of the road sub. :anonymous:
  11. Nov 23, 2011 at 12:11 PM
    cmytacoma
    Model Solo-Baric L7 8"
    Size (IN.,CM) 8, 20.32
    Impedance (OHMS) 2 or 4 DVC
    Max Rec Amplifier Power (WATTS PEAK/RMS)* 900/450
    Sensitivity (dB 1w/1m) 83.6 Frequency Response (Hz) 28-100
    Mounting Depth (IN.,CM) 4-3/4, 12.1
    Mounting Cutout, Square (IN.,CM) 7-1/4, 18.4
    Min Rec Sealed Box Volume (CU. FT., Liters) .33, 9.4
    Max Rec Sealed Box Volume (CU. FT., Liters) .75, 21.2
    Min Rec Vented Box Volume (CU. Ft., Liters)** .66, 18.6
    Max Rec Vented Box Volume (CU. Ft., Liters)** 1.0, 28.3
    Here are the specs and i already have the subs and amp just need the proper box
  12. Nov 23, 2011 at 12:13 PM
    cmytacoma
    Itll be going in an 05 double cab behind the seatss preferably
  13. Dec 14, 2011 at 4:52 PM
    NOCENTS
    NOCENTS Well-Known Member
    Arm pit of Cali
    08 TRD DC needin some lovin
    loooooong list of mods coming as soon as I finish the audio/video system
    Did you get the L7 installed??
