Bluetooth obd2
Discussion in '1st Gen. Tacomas (1995-2004)' started by roehoe72, Mar 20, 2015.
  1. Mar 20, 2015 at 10:40 AM
    roehoe72
    roehoe72 [OP] Well-Known Member
    Dan
    Vacaville, CA
    04 dc prerunner v6 trd
    So i was cruising thru the diy frugal mod thread for second gens and came across obd2 torque. Had no clue what it was, minus the obd2 part. Got to googling and cae across this
    http://m.ebay.com/itm/331143517883
    Its so dang cheap i dont know if it is worth it. Anyone have one? Yay, nay? :crapstorm:
  2. Mar 20, 2015 at 10:46 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Cooper Discoverer ATP 285/50, Bilstein 5100's all around, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
  3. Mar 20, 2015 at 10:51 AM
    roehoe72
    Dan
    Vacaville, CA
    I take it its basically a scan guage, but on your phone?
  4. Mar 20, 2015 at 11:01 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    completely worth it. I've been using an OBD2 Bluetooth sender and the torque app for a few years now. I paid $4.00 for the upgraded app. the units were about $20 a pop when I got mine, but it's all the same stuff. does everything a scanguage does, but is more versatile. can't beat it.
  5. Mar 20, 2015 at 11:04 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
  6. Mar 20, 2015 at 11:07 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    couple of screen shots of various things I use or have used it for.
  7. Mar 20, 2015 at 11:19 AM
    Kchapp
    Kchapp Active Member
    Kevin
    Birmingham
    02 Double Cab SB
    General Grabber At2 on Helo He791 wheels, LED interior dome and map lights , Opt7 Led headlights, Pioneer In dash DVD, Parking brake bypass for DVD, Husky liners, Drop in UTR liner, Stainless D Cab toolbox, K&N air filter, Westin nerf bars, Mounted aux/usb input from head unit. Bluetooth OBDII module.
    I bought a BAFx brand from Amazon. It's totally worth the $25 I paid for it, especially if you don't already have an obd scanner to clear your codes. It functions that way, too.
  8. Mar 20, 2015 at 11:36 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    torque will read/view, web search, and clear codes as well.
  9. Mar 20, 2015 at 11:41 AM
    Assforkr
    Assforkr Well-Known Member
    MA
    03 taco
    The BAFX brand works on my 03 and interlocks with torque seamlessly. Downside is that it stick out pretty close to your right leg/foot and that might be a concern when it comes to you snapping it off. Solution would be to get a http://www.amazon.com/Profile-Right...UTF8&qid=1426876806&sr=8-1&keywords=obd+cable
    Previous to that I had the isaddle orange BT sensor (very small and similar to one of the ebay versions posted above) and that one sent the truck ABS system into permanent test mode so the light wouldn't come off. Stay away from that one.
  10. Mar 20, 2015 at 11:53 AM
    roehoe72
    Dan
    Vacaville, CA
    So i did a little more research on these, filtered my search on Amazon so that it would show the best reviewed products. It came up with the same one you linked. I pulled the trigger on it. Now just the waiting game. And the learning game. Aside from obvious things like mpg, mph, temp, how do i interpret the numbers. say for air/fuel mixture and others, so i know im running good or not.
    http://www.tacomaworld.com/gallery/data/500/medium/screenshot8.jpg
    And as far as the horse power meter goes, has anyone found it to be accurate? Btw this will be on a 04, prerunner, dc, v6, trd. I also downloaded "torque lite" for now and have been playing with it to figure it out. Thanks for all the input
  11. Mar 20, 2015 at 12:09 PM
    Texas50
    Texas50 Well-Known Member
    Brazoria County-Texas
    11 TRD Sport.
    OME 885's,Light Racing UCA's,Bilstein 5100's all the way around, Deaver AAL. Cooper 265/70/17
    Anyone have any ios compatible suggestions?
  12. Mar 20, 2015 at 12:17 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    power meter is really just a "load" meter of sorts. not sure what it actually measures, but it's just a 0%-100% value. it's not an actual HP readout. if it were, no one would pay for dyno runs.
  13. Mar 20, 2015 at 12:24 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    In most cases these little things have an ELM chipset in them, and that's the magic. The ebay linked one is version 2.1, which is ELM's latest:
    http://elmelectronics.com/obdic.html
    The Amazon linked one doesn't mention ELM, let alone which version. Were it me, I'd buy the cheapest one that I could find that was ELM v2.1.
    I wish I'd known that when I bought mine. Now I have to go look and see what chipset I bought.
    Edit: I went and looked. I ordered a v1.5 one: http://www.amazon.com/gp/product/B00D6DOFTK/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
  14. Mar 20, 2015 at 12:35 PM
    roehoe72
    Dan
    Vacaville, CA
    That's kinda what I was expecting. I didn't buy it for that reason anyways. But again how do i decipher the other numbers, say on fuel trim, and others that aren't so obvious..
  15. Mar 20, 2015 at 12:42 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the way torque works, is that you have X number of things that It can display. you can then put between 1 and 8 different "gauges" on each screen (I think you have 5 screens available). depending on what you are doing, we likely don't even need things like fuel trims on your screens. I only had them when I was adjusting the curve on my mass airflow calibrator for a new intake. since doing that, I've taken those gauges off, and replaced them with more relevant ones.
  16. Mar 20, 2015 at 12:59 PM
    roehoe72
    Dan
    Vacaville, CA
    Yeah, i figured after the shinyness wears away, and ive had it for a minute id probably just start monitoring the "normal" things too. Im gonna read up on how to read the more complicated things, such as fuel trim and such. I was just hoping to get more tacoma specific info, from a real live member. Hell maybe someone will chime in eventually. Is this thing capable of "tuning", like say a "power commander"? or is it just a nifty new way of having guages? I mean obviously i should be able to test different things like cai, headers, air filters, spark plugs, wires, alternator and such in theory right? Thanks for putting up with all the stupid questions...
    EDIT: just found this thread, in the process of reading it!
    http://www.tacomaworld.com/forum/performance-tuning/183560-write-up-torque-app-obd2-reader-3.html
  17. Mar 20, 2015 at 4:37 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica
    Icon, AllPro, Total Chaos, ARB, BAMF, Relentless, SCS, Cooper, Leer,
    See my comment at the end nissans use them to control lights remote start and lock/unlock too lots of possibilities if the right mind is focused
  18. Mar 20, 2015 at 6:53 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I have one. Pretty good little thing to have. I just got tired of messing with it and bought a standalone one from Harbor Freight for $80
  19. Mar 20, 2015 at 6:54 PM
    senojeelnodnarb
    senojeelnodnarb Well-Known Member
    Brandon
    Oahu, HI /Canton, NC
    2013 Tacoma DCSB 4x4 TRD OR, 6-Spd Manual
    Fully De-Badged, Mossy Oak seat covers, Fog Light anytime mod, Custom Bed Light Bar, flowmaster 40 series, Plasti-Dipped Grille, Painted Stock TRD Rims, Custom Plate Bumper, High-Lift Bed Mount, Ballacula Trailer Plug Relocate, Rear Seat Dog Platform, sunglasses holder Switch panel, 2" lift, 285/75/R16 Mickey Thompson Baja MTZ, custom sliders, + a shit load more,
    Fucking love it!!!!
  20. Mar 20, 2015 at 6:58 PM
    roehoe72
    Dan
    Vacaville, CA
    End of the thread i linked? Im almost there, on page 21. How would you control auto start with this thing. If its bluetooth you gotta be relatively close to use it.. My auto start is good for 1500 ft. Or am i missing something..
