Boat towing
Discussion in 'Towing' started by Maysville06, Jan 24, 2012.
  1. Jan 24, 2012 at 6:18 AM
    Maysville06
    Maysville06 [OP] Well-Known Member
    Bruce
    Georgia
    Pre-runner SR5 Long bed
    K&N Cold Air Intake, Flowmaster Exhaust,20% window tint all around, Weather tec rear floor mats, Blacked out badges,Mudflaps removed,JDM black aftermarket headlights,black grille, running boards removed,Nightshaded tail lights,TRD Sport suspension,3in leveling kit in front,2in blocks in the rear,blacked out rims, Reese class III receiver hitch
    I am looking to tow a 22ft mako with my 2005 tacoma. I know my manual says that with a receiver hitch i can safely tow up to 5500 lbs. I am just looking for some feedback because there are a number of folks that keep saying i need a bigger truck. I however belive and am almost certain i can tow the boat no problem.
  2. Jan 24, 2012 at 6:19 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Do you have the tow package and how much does the boat weigh?
  3. Jan 24, 2012 at 6:22 AM
    txduckhunter
    txduckhunter Well-Known Member
    centex
    08 Tacoma DC LB SR5 4x4
    2.5" lift, ARE Shell, Ducks Unlimited Rubber Floor Mats. ROGUE badges,
    I pulled my 21ft Malibu ski boat all over the place this weekend and it was fine. The boats about 3700lbs with gear and gas.
    My taco actually pulled better than my dodge 1500 with the 4.7. Only time I noticed a difference was braking, gotta take it a little easier with the Tacoma.
  4. Jan 24, 2012 at 8:36 PM
    Maysville06
    Bruce
    Georgia
    No i dont have the towing package. It weighs about 3800 to 4200
  5. Jan 24, 2012 at 8:45 PM
    JWCWV
    JWCWV Well-Known Member
    Morgantown, WV
    08 Tacoma Double Cab
    I have a 20ft Sea Ray, also around 3800 full of gas. I pulled it quite a bit last summer without no problems! I have the tow package though.
  6. Jan 24, 2012 at 8:51 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    if you know you can tow up to 5500, and the boat weighs 4500, do i need to do the math for you?
  7. Jan 26, 2012 at 5:56 PM
    Maysville06
    Bruce
    Georgia
    Whippersnapper, the manual says i can tow 5500 with an installed receiver hitch. So im a bit confused as far as why i couldnt tow it without the towing package.
  8. Jan 26, 2012 at 5:59 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    part of the towing package from toyota is a reciever hitch. that is was the higher rating is for. if you are talking about having a hitch ball on the bumper, you are then limited to what he stated.
  9. Jan 26, 2012 at 6:02 PM
    Maysville06
    Bruce
    Georgia
    So i should be good to tow up to the max as long as i have that correct?
  10. Jan 26, 2012 at 6:13 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the factory tow package comes with some other stuff that's nice to have but not required. so yes, with the actual hitch, you're not going to rip off the rear of your truck like with a bumper mount.
  11. Jan 26, 2012 at 6:19 PM
    Maysville06
    Bruce
    Georgia
    Cool thanks.. I appreciate it... What are some Mods i can do to make towing that load easier. Bigger battery? bigger alternator?
  12. Jan 26, 2012 at 6:24 PM
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    At 3700lbs you should be using trailer brakes. If you get into a panic situation you will be like the tail wagging the dog.
    If you had an F250 you could haul with out the trailer brakes. The Toco does not have heavy duty brakes like a 1/2 ton or 3/4 ton, it has slightly beefed up passenger car brakes
  13. Jan 26, 2012 at 6:26 PM
    zachc113
    zachc113 Well-Known Member
    its not very much but i tow 2 jetskies weighing in around 2500 for everything and you can hardly tell there on there
  14. Jan 26, 2012 at 6:27 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    I'd start with brakes, get a high quality set of brake pads and possible vented rotors (s/s lines if you can afford them), then go with an aftermarket oil cooler.
  15. Jan 26, 2012 at 6:36 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    The tow package comes with a class IV hitch, bigger alternator, bigger battery, tranny cooler, and a 7 pin to 4 pin connector.
    I towed a 1400 lb buggy and it handled it fine. The only issue was braking. Tacoma's brakes are spongy and have a weak pedel feel. Keep the tranny in 4, not D, when you tow and reference this thread:
    http://www.tacomaworld.com/forum/towing/4031-tacoma-towing-bible.html
  16. Jan 27, 2012 at 6:42 AM
    psmcn
    Paul
    Rockville Md
    Even with updated pads and lines you are not going to increase the surface area of the rotors/drum or the power applied to them from an automotive mastercylinder. there may be a harsher feel to the brakes with harder pads that will in turn wear your rotors faster The SS lines may give a stronger feel and have a slight increase of initial force to the pads but the mastercylinder is only going to give what it has to give and nothing more. With a trailer attached that is over 2000# its only wise to ere on the safe side and not become a statistic.
  17. Jan 27, 2012 at 7:32 AM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    You are correct. My point is while the ability to tow the boat may be feasible with the correct hitch, braking should not be disregarded.
    Obviously a trailer with it's own brakes is best.
    How would you modify a stock truck to increase braking power?
    I'm curious as well. I tow my boat close to home with performance pads and vented rotors with out any issues. However, I may be doing a cross country highway trip in the spring and would like to be prepared braking wise.
  18. Jan 27, 2012 at 9:43 AM
    psmcn
    Paul
    Rockville Md
    Brakes are always the weakest link in the towing/cargo capacity equation. That is why the cargo rating for a Taco is only 1200#. I am not an engineer so I will not even speculate on how to increase braking power. What I would do is buy a heavier truck or the less expensive route is to outfit the trailer with brakes. Much less then a new truck!
  19. Aug 16, 2012 at 5:18 PM
    Florida Guy
    Florida Guy Member
    A bit late, but possibly this threat can come to life?
    I have a 22ft Mako and am considering a Tacoma for towing. How did your Tacoma tow the Mako?
  20. Sep 26, 2012 at 3:10 PM
    Maysville06
    Bruce
    Georgia
    Florida guy! I pulled my 211 mako about 9 hours on the interstate and the taco towed it AWESOME! you cant stomp the gas going up hills or anything but it will do just fine my friend.
