Bocsy44's taco addiction build
Discussion in '2nd Gen. Builds (2005-2015)' started by Bocsy44, Jul 11, 2017.
  1. Jun 3, 2018 at 9:39 PM
    #801
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
  2. Jun 4, 2018 at 2:03 AM
    #802
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    thanks!:cookiemonster:
    Good work done! Now to paint those skids and go bash them in the woods!
    MarX and Bocsy44[QUOTED][OP] like this.
  3. Jun 4, 2018 at 2:20 AM
    #803
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    Looking for a UCA, what made you decide on that and how much?
    MarX likes this.
  4. Jun 4, 2018 at 4:47 PM
    #804
    Bocsy44
    Bocsy44 [OP] Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    cuz I got them brand new off a guy on kijiji for 400 bucks hahaha realistically I probably would have gone with them anyways. second choice would be the JBA ones. a little less expensive and just as good, not adjustable but I know a few guys running them with no complaints and no issues getting the alignment numbers they wanted.
    Justanotherhemi and MarX like this.
  5. Jun 4, 2018 at 6:40 PM
    #805
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    son of a bitch, they retail for $660....
    wondering if I could forgoe them for now no?
    got my shocks, struts and leaf pack or sorted out (all though I might be changing it to an even heavier duty leaf pack)
    Bocsy44[QUOTED][OP] and MarX like this.
  6. Jun 4, 2018 at 6:48 PM
    #806
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    What springs and shocks are you running up up front? UCA'S are pricey.
  7. Jun 4, 2018 at 6:58 PM
    #807
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    − OME 9000 Front Shocks
    − 2886 Front Heavy Coil overs
    − EL096R Rear spring pack
    − OME 60091 Rear Shocks
    MarX[QUOTED] and Bocsy44[OP] like this.
  8. Jun 4, 2018 at 6:59 PM
    #808
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    it wont hurt anything not to put them in right away. lots of people never even bother with them, as long as you stay under 3'' you should be good. I would suggest adding them at some point, but I wouldn't let it hold you back from installing the lift. just pray to the taco lords that ur LCA cam bolts aren't seized lol mine were, now I'm replacing my LCA's and cam bolts. will be buying the TC gusseted cam tabs as well lol the OEM cam bolts retail for 350 from the dealer and 300 on toyotapartsdirect.ca. I have read a lot of threads saying aftermarket cams and bolts are garbage and ware down faster which is why I'm sticking with OEM hardware. cant afford no fancy LCA's tho so I went with Dorman which were still about 700 for the pair lol I also ended up having to replace my sway bar end links cuz I had to trash them to drop the sway bar out of the way to remove the coil over.
  9. Jun 4, 2018 at 7:08 PM
    #809
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    Ya staying under 3" for a multitude of reasons, but I doubt ill be coming anywhere near that with all the weight attached to my truck right now haha. I think right now that lift I mentioned above is 1800 all said and done so this is going to be an expensive endeavor haha.
  10. Jun 4, 2018 at 7:10 PM
    #810
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You’ll like it. I have the same set up in the front, and it handles my bumper/winch/skids really well.
  11. Jun 4, 2018 at 7:12 PM
    #811
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    I don't even have my skids yet haha
    right now im posted out east and its in the Appalachian range so my mileage is shit. 350km for a tank roughly when it was upwards of 550 before all my armour went on
  12. Jun 5, 2018 at 2:54 AM
    #812
    MarX
    Mark
    NE Kansas
    Nice, with those 886s and depending on weight your probably going to need UCA's. If your that heavy as it sounds like you could be, you could be ok.
  13. Jun 8, 2018 at 5:22 PM
    #813
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    So from what I've heard as well the dakars will fail depending on the constant load if it reaches a constant load of like 300/400?
    @Blackout14 offers his here so I'm wondering if I should just go full retard with the lift once as opposed to seeing if the dakars will hold up. Probably looking at 200/250lbs for a constant load
    At an impass here.
    Blackout14 and MarX like this.
  14. Jun 8, 2018 at 5:28 PM
    #814
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Standard duty Dakar’s are rated at 330 lbs constant load and it holds a 3” lift, so that should be good for your needs. I have the older dakars with an AAL and they handle my ~600-700lbs constant load really well.
  15. Jun 8, 2018 at 5:31 PM
    #815
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    I've never contemplated a purchase for this long haha since Oct of last year but dropping 2k on something that might cause me some future problems is what's holding me back from pulling the trigger
    MarX likes this.
  16. Jun 8, 2018 at 5:33 PM
    #816
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s totally understandable! It’s good to be educated when buying something that expensive.
  17. Jun 8, 2018 at 5:56 PM
    #817
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    I love my @Blackout14 springs. I'm glad I didn't get Dakars. That was my other choice.
    ovrlndkull, MarX and Blackout14 like this.
  18. Jun 8, 2018 at 6:16 PM
    #818
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    Oh gosh you and @EatSleepTacos. Are making this hard hahaha
  19. Jun 8, 2018 at 6:17 PM
    #819
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I think either way you’ll be happy! But my vote is obviously Dakar’s haha
  20. Jun 8, 2018 at 6:25 PM
    #820
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Mine don't squeak
    MarX likes this.
