Body Armor Hiline Series Bumper
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zgriff, Aug 22, 2019.
  1. Mar 25, 2021 at 8:46 PM
    #261
    doc76
    doc76 Well-Known Member
    B.C. Canada
    2021 Tacoma Sport, 2020 Honda Pilot Black Edition
    Btw you do not have to remove your bumper to install this insert. I did the whole job without loosening the fender flares or removing my bumper. They really need to revise the instructions. Anytime you remove parts you risk damaging them, scratching, broken clips, etc.
    They have you do a bunch of work needlessly.
    Read through the threads on here. I have detailed it pretty well. Remove the center plastic, grill and air dam. Mark and make your cut, remove crash bar easily after the cut is made then install the Hiline insert.
    Astr0Aar0n and Guami54[QUOTED] like this.
  2. Mar 25, 2021 at 9:54 PM
    #262
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    The stock bumper and parts weigh about 12 pounds.
    medic7556, Astr0Aar0n and doc76 like this.
  3. Apr 12, 2021 at 2:41 PM
    #263
    nick7257
    nick7257 New Member
    Nick
    2020 Tacoma TRD Sport 4x4 (Cement)
    TRD Skid Plate Body Armor HiLine Bumper Warn 10,000lb Winch (EVO 10-S)
    I'm a bit late to this thread, but what light bars are yall using for your hiline bumpers? First one I bought doesn't quite fit the pre-welded mounting spots and I want the light as close to the cutout as possible. Thanks in advance!
  4. Apr 12, 2021 at 3:01 PM
    #264
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
  5. Apr 12, 2021 at 3:05 PM
    #265
    nick7257
    nick7257 New Member
    Nick
    I like the look of the black series from RC, glad to know they fit well. Looks like they use the same mounting hardware as some "universal" mounts on Amazon, gonna try a $10 mount swap and see if that works, maybe save myself a few dozen bucks.
  6. Apr 12, 2021 at 3:06 PM
    #266
    ydlee
    ydlee Well-Known Member
    I ordered a 24" light bar for maximum to fill up the cut out.
  7. Apr 12, 2021 at 3:45 PM
    #267
    doc76
    B.C. Canada
    I used a ProComp dual row 20” bar. Fit great
  8. Apr 12, 2021 at 4:18 PM
    #268
    medic7556
    medic7556 Well-Known Member
    Blue Ridge, Ga
    17 MGM Tacoma SR5 4x4 DCSB
    I installed the Rough Country Black Series 20 inch dual row light bar with amber DRL. Perfect fit and did not interfere with the install of my Smittybilt winch. 20210324_152415.jpg 20210324_201202.jpg 20210324_202124.jpg
    svermilyea likes this.
  9. Apr 12, 2021 at 4:38 PM
    #269
    nick7257
    nick7257 New Member
    Nick
    Lots of folks recommending the RC Black kit. Will pick one up if my mounting bracket swap doesn't work out. Thanks!
  10. Apr 13, 2021 at 7:31 AM
    #270
    ljh824
    ljh824 Regular Guy
    Lou
    Kabul, Afghanistan / Oviedo, Florida
    -21 AG Sport 4x4 DC
    Sooooo, how did you wire it? I have the same thing, and trying to find a way to tie into my actual DRLs, so the light bar DRLs come on automatically. Took it to a few places, with no luck so far. Emailed RC and havent heard back yet. The harness they provide is beefy, but the switch that comes with it is not.
  11. Apr 14, 2021 at 11:26 AM
    #271
    medic7556
    Blue Ridge, Ga
    I use the below switch. It stalled it on the left side of steering wheel below the cubby hole. It has 5 wires and the light bar has 3 if I remember correctly. Spliced them together. Ran the ground to a nut that secures the fuse box under the dash. Left the dash light wire disconnected since the light will remain on if connected directly to the battery. You can connected it to the ignition switch but that above my expertise. The way my buddy and I wired it up there is not back light on the button unless the buttons are switched on. Top button works the lightbar bottom works the DRL.
  12. Apr 14, 2021 at 12:05 PM
    #272
    ljh824
    ljh824 Regular Guy
    Lou
    -21 AG Sport 4x4 DC
    Okay, so you used a double switch, but have to physically put the DRLs on (with the switch). I'm probably just going to go this route. One tech I talked to said i could potentially T Tap into the truck's DRLS, but you're right, the RC switch only has three wires. Basically LED-Off-DRL. So not sure how to make it work. thanks for the info. Appreciate it.
    medic7556[QUOTED] likes this.
  13. Apr 15, 2021 at 5:44 PM
    #273
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Glad I found this thread! Who has the best deal on these bumpers right now?
  14. Apr 15, 2021 at 6:28 PM
    #274
    medic7556
    Blue Ridge, Ga
    Vicious offroad was the cheapest I found but that was 2 months ago.
    CoastieRon[QUOTED] likes this.
  15. Apr 15, 2021 at 7:04 PM
    #275
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    The yotagarage has it for $540 with coupon code BR10.
    I pulled trigger.
  16. Apr 18, 2021 at 11:05 AM
    #276
    ljh824
    ljh824 Regular Guy
    Lou
    -21 AG Sport 4x4 DC
  17. Apr 18, 2021 at 3:42 PM
    #277
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    I'm no welder, but I see nothing wrong with this bumper. Ordered Thursday, received today. Will mount later this week.
  18. Apr 19, 2021 at 4:41 AM
    #278
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    Did you make your own wire harness for this? I decided I can't live with the hole in the bumper, so I might as well fill it......
    If anyone has a pic of the "pigtail" this bar comes with, I'd appreciate seeing it....
    Thanks!
  19. Apr 21, 2021 at 6:19 AM
    #279
    Toolndie7
    Toolndie7 Well-Known Member
    2019 Sport DCSB Cavalry Blue
    Ordered this bumper from Truck Brigade for $540 on 4/10 , I am being told it probably wont get through port customs and ship until 5/3 - 5/4 :( Also ordered a Rough Country lightbar and thats on backorder as well...... Oh well
  20. Apr 21, 2021 at 6:23 AM
    #280
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    For those of you with a light bar and winch installed....how are you guys reaching the clutch on your winch?
