Body Armor Hiline Series Bumper
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zgriff, Aug 22, 2019.
  1. Jun 23, 2021 at 7:22 PM
    #321
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    It's hard to say. You will know once you mount it and then eyeball it. That's your chance to make the adjustments if necessary.
    jtb88[QUOTED] likes this.
  2. Jun 24, 2021 at 11:01 AM
    #322
    Methadras
    Methadras Well-Known Member
    South DFW, TX
    2021 White TRD Sport 2WD
    Fox 2.0 Lift, JLA Uppers, Dual battery setup, ARB-Double Barrel compressor, CBI skidplates, CBI Covert bumper, Winch, various light setups.
    I have the CBI version of this bumper and I'm going with the APEX as well. For the cost and what you get, it's just a good value.
  3. Jun 27, 2021 at 6:33 PM
    #323
    willtill
    Maryland
    This is the FOURTH time I have removed this BA Hiline bumper from my truck. Yesterday I removed it to uninstall the 22" LED light bar; I did not like the idea of not being able to see what the spool was doing on my winch. So now I have got to figure out where to remount the LED light. The only effective spot would be immediately under the hoop and using L brackets. I was going to try to install it behind the plastic grid under the hoop area but too much light would be blocked by the hoop.
    How do you guys monitor the spool on your winch if you have a LED light bar blocking all view to it? They only way I could see the winch spool previously, was get on my hands and knee's with a flashlight and try to peer into the hawse. That's not practical.
    For the upcoming winter, I plan to place a 3.25" x 22" piece of clear polycarbonate in front of the opening, to keep most of the brine and crap from entering the winch area.
  4. Jun 27, 2021 at 8:18 PM
    #324
    dowNNshift
    dowNNshift Well-Known Member
    I can see the spool on my winch, but I have to pop the hood to monitor it. I did a Smittybuilt Synthetic rope winch with wireless controller -- so far 7 months in, its been reliable and good.
    I have to drop my bumper this fall / winter when its cooler to replace a cracked LED Lightbar lens, but I'm not particularly looking forward to it given how heavy the bumper becomes with the winch installed. I am pleased with my bumper though.
  5. Jun 28, 2021 at 2:40 PM
    #325
    omg_miiiike
    omg_miiiike Well-Known Member
    Maryland
    2017 Tacoma TRD Off Road | DCSB
    Had mine professionally installed. Instead of the rubber strip around the part they cut, they rolled the edges on the plastic.
    ricco333 likes this.
  6. Jun 28, 2021 at 3:47 PM
    #326
    doc76
    doc76 Well-Known Member
    B.C. Canada
    2021 Tacoma Sport, 2020 Honda Pilot Black Edition
    Close up pic of the rolling job?
    ORtoCOTaco, jtb88 and soundman98 like this.
  7. Jul 1, 2021 at 3:33 AM
    #327
    willtill
    Maryland
    What size shackle pins are you all using for the Hiline bumper? 7/8" ?
  8. Jul 1, 2021 at 8:41 PM
    #328
    jtb88
    jtb88 Member
    2021 Cement TRD Sport
    Yep, 7/8" pins.
    Got around to installing the bumper. Waiting for a 20% discount at HF to pull the trigger on the Apex.
    svermilyea likes this.
  9. Jul 2, 2021 at 7:28 AM
    #329
    Dawelda
    Dawelda Well-Known Member
    West of West Phoenix
    20 Tacoma DCLB TRDOR Desert Sand
    2.5" lift w/33" tires, 10K Winch & bumper, camper shell
    I really like the look of a TRD front skid plate!:thumbsup:
    I beat the shit out of my steel one first trip out, caved in at two spots and pushed over to the side.:rofl: But what are the TRD items...$400+? Geez!
    jtb88 likes this.
  10. Jul 2, 2021 at 7:36 AM
    #330
    jtb88
    jtb88 Member
    A little under $400 for the skid plate, local discount lol. Really, just a drop in the bucket for how much these rigs cost from the dealership haha
  11. Jul 2, 2021 at 5:28 PM
    #331
    Mikro
    Mikro Well-Known Member
    2020 MGM TRD Pro
    Anyone with the Rough Country 20” light bar care to share how you mounted it to the Hiline bumper?
    The RC supplied mounting options don’t seem to line up with everything. I’m terrible at this stuff.
    Thanks!
  12. Jul 2, 2021 at 6:59 PM
    #332
    jtb88
    jtb88 Member
    I went with a cheap Amazon light bar for now and I ran into the same alignment problem. I just used washers to lift the light bar until it was centered to the cutout.
  13. Jul 2, 2021 at 8:01 PM
    #333
    ORtoCOTaco
    ORtoCOTaco Well-Known Member
    Colorado
    2018 White Tacoma TRD Off Road DCSB 4x4
    BodyArmor 4x4 HiLine Winch Bumper, Warn Zeon 10-S, Uptop Bravo Roof Rack, ExtremeLED Super Stealth 40" LED Light Bar, DV8 Offroad 20-Inch BRS Pro Series LED Light Bar, Truxedo Roll-Up Tonneau Cover, Automatic Tailgate Lock, Trailgate panel, cheap Amazon ditch lights.
    I don't have the RC light bar but when I installed my DV8 bar their brackets wouldn't work at all, I used the light bar brackets that came with the bumper and it was exactly what I wanted, super easy.
    jtb88 likes this.
  14. Jul 12, 2021 at 5:32 PM
    #334
    gregnauman
    gregnauman Well-Known Member
    Greg
    2020 Tacoma TRD Pro
    None
    Hey doc when you do the cutting……Mark the 3/4 inch across the top and draw a straight line correct? I was going to just mark two to four spots across the top and connect them with straight edge.
    As far as the angle cuts down toward the ground. Do you cut right in the bend or leave a bit of material out from the bend forward for the edge guard to push on to?
  15. Jul 12, 2021 at 6:36 PM
    #335
    doc76
    B.C. Canada
    hey there
    Yes you’re on the right track. I marked once in the center and one on either end and connected the line. A straight cut.
    I got real picky and checked it with my laser straight edge but really that was unnecessary.
    Some guys cut following the curve of the front of the truck but I think it is much less visually appealing. I looked at tons of trucks both with straight cuts and curved
    As for the cuts down the side yes I cut right in the bend.
  16. Jul 12, 2021 at 6:39 PM
    #336
    doc76
    B.C. Canada
  17. Jul 13, 2021 at 9:06 AM
    #337
    Dawelda
    Hey Doc,
    I see you have the plastic tucked BEHIND the small strip of metal on the side of the bumper. I have the same bumper and put the plastic in FRONT of the same strip. :goingcrazy:I don't have a good pic but it looks good and, it's been so long I can't remember why i did this but assume I had a reason. What was your reason for the location please? Did I miss something in the crappy instructions maybe?
  18. Jul 13, 2021 at 9:31 AM
    #338
    Tacocement5
    Tacocement5 Well-Known Member
    Northwest Indiana
    2021 Toyota Tacoma TRD Off Road
    Where did you get the tail lights. They look amazing!
  19. Jul 13, 2021 at 9:32 AM
    #339
    gregnauman
    Greg
    2020 Tacoma TRD Pro
    None
    I think it shows it that way in the instructions
    Dawelda[QUOTED] likes this.
  20. Jul 13, 2021 at 10:59 AM
    #340
    Dawelda
    Well...shit!:facepalm:
