Body lift gap!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by machotaco2012, Oct 23, 2016.
  1. Oct 23, 2016 at 9:25 PM
    machotaco2012
    machotaco2012 [OP] Well-Known Member
    •3” front blocks •2” steel rear blocks •1.25" spidertrax spacers for clearance •285/70/17 (33's) Ko2's •20% tint
    Whats up guys I have a question about body lifts. I have a 2012 prerunner with a 3/1.5 inch suspension lift right now but im considering getting a body lift too. I wanna go 1 or 2 inches. I can get gap covers for the wheel wells but what about the bumper? Will there be a gap? If so where can I get brackets to raise it. Pics of your body lift would help a lot. Thanks.
  2. Oct 23, 2016 at 10:25 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Cape Breton Island Nova Scotia
    09 Tacoma 4x4 TRD Off Road
    Dont do it. Body lifts are filled with problems. Your engine, tranny all that shit is mounted to the frame. You lift the body and now you have misalignment with shifters, heater hoses, wiring, Steering column. oh and yes there will be a bumper gap.
    THROTTLE231 and ChadsPride like this.
  3. Oct 24, 2016 at 4:27 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    I wouldn't.
    ChadsPride likes this.
  4. Oct 24, 2016 at 6:44 AM
    Spencer97TJ
    Spencer97TJ Well-Known Member
    Spence
    CT
    stock
    I have a 1 inch BL and Engine mounts on my Jeep to tuck the tcase and engine. I would not do it to my Taco. Invest in a sweet suspension kit.
  5. Oct 24, 2016 at 7:40 AM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    You can do a 1 inch BL on a Taco without incident. HomerTaco has one, as do many others. I have a .5 BL on mine. At .5, you don't need to do anything to the bumper or even the bed. I installed the Energy Suspension body mount bushings to replace my squashed stock bushings. I Installed the bushing kit with the bigger puck on top to make it a BL. It's .5" over what stock should be, but I actually got close to 1" from how it sat with the squashed stock bushings.
    https://www.tacomaworld.com/threads/body-mount-bushing-install-now-with-pictures.432885/
  6. Oct 24, 2016 at 9:01 AM
    machotaco2012
    Would you guys recommend getting a spindle lift. I have a prerunner.
  7. Oct 24, 2016 at 9:05 AM
    TrapComa
    TrapComa Well-Known Member
    Mason
    Cedar Park, TX
    07 Indigo Ink LT PreRunner
    Wannabe prerunner, wannabe overlander
    Yes, I have 3" lift on top of my 4" spindles to get 7" total lift. Super easy to install, maxtracs are super stout, and it wont hardly change the handling of the truck
  8. Oct 24, 2016 at 9:05 AM
    machotaco2012
    You got it off maxtracs website?
  9. Oct 24, 2016 at 9:11 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    I think the 1" BL would be negligible for any concerns of stretching hoses etc. No steering column extension required either which is nice when only 1 ".
    Had a 3" BL on my old truck and the steering column extension was sketchy. Don't reccommend 3 " for sure.
    And you'll have to fab up some brackets for bumper. Shouldn't be a big issue.
  10. Oct 25, 2016 at 2:28 PM
    TrapComa
    Mason
    Cedar Park, TX
  11. Oct 25, 2016 at 3:22 PM
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    2015 MGM DCLB TRD Sport 4x4
    Not an overbrander.
    I've had the 3" Performance Accessories body lift since May. Everything works fine for me. The kit comes with the front bumper relocation bracket. I also got the rear bumper relocation brackets and the gap guards.
    The steering column and are fuel hose are both extended (comes with the extensions), and I haven't experienced any problems.
