Body Mount Bushing Install - now with pictures! And a video too!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, May 18, 2016.
  1. Oct 26, 2016 at 11:51 AM
    #181
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    How did you know yours was loose?
  2. Oct 26, 2016 at 11:58 AM
    #182
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Heard front end clunking, knocking sounds, wen pulling in forward on sloped driveways or off camber situations. Truck sounded and felt like a POS. I was so happy when I found it. Torqued it solid, and truck was awesome again.
    IMO, this type of joint stands the greatest chance of self loosening because the lateral movement under the surface under the bolt face / nut.
  3. Oct 26, 2016 at 12:04 PM
    #183
    Pigpen
    Dan
    Northwest Montana
    Damn. That's not my sound. All the rest of my bushings make that noise because they're still over tourqued, but not the fronts.
    Thanks
  4. Oct 28, 2016 at 3:30 PM
    #184
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    and the radiator core bushings corrected this:fingerscrossed:
  5. Oct 28, 2016 at 4:21 PM
    #185
    Crom
    Nick
    San Diego, CA
    Millions
    Not exactly. My problem, and cause of noise was that was the bolt and nut had self loosened after I wrenched it and went off road. The noise was probably the core support being beat to hell and bolt rattling around. I already had the ES bushings in there. I found the loose bolt and nut and torqued it good, and it and fixed the problem.
    Toyota states that the nuts, are one-time-use only. My experience should serve as a warning to others, to use lock-tite, nylock nuts, or new hardware from stealer.
    I ordered new nuts from stealer and I am goign to double nut it with lock-tite.
    llibrm[QUOTED] likes this.
  6. Nov 17, 2016 at 9:02 PM
    #186
    NaZRaQ
    NaZRaQ Well-Known Member
    Zee
    Denver
    2024 TRD OR Tacoma hybrid
    Going to replace body mount and radiator bushings this weekend with the energy suspension part... Wish me luck!
    llibrm likes this.
  7. Nov 17, 2016 at 9:04 PM
    #187
    Pigpen
    Dan
    Northwest Montana
    No need for luck, you have this thread!
    NaZRaQ[QUOTED] likes this.
  8. Nov 20, 2016 at 11:30 AM
    #188
    NaZRaQ
    Zee
    Denver
    Doing this as I type... I've got all 4 nuts off and the front bolts loose but the tears are seezed as yours were... I've tried the bfh for an hour along with lots of pb blaster.... Any other ideas would be greatly appreciated of getting the rear bolts out. Oh and the clips are off from the pins.. Actually already was.
  9. Nov 20, 2016 at 6:41 PM
    #189
    Pigpen
    Dan
    Northwest Montana
    I sprayed PB Blaster from the top and let them sit while I did the front. It was probably an hour. I still needed the BFH, but they broke free.
  10. Nov 20, 2016 at 7:21 PM
    #190
    NaZRaQ
    Zee
    Denver
    I got the passenger side done but the rear driver is severely stuck... I sprayed for hours and hit it for hours too still stuck. I'm hoping spraying overnight will do the trick, I'll bang on it some more tomorrow.
    The tip of the bolt you can see in pic is flattened out and I doubt will fit through the opening of and when I do get loose... I think I'll have to cutoff the tip.
  11. Nov 20, 2016 at 7:24 PM
    #191
    NaZRaQ
    Zee
    Denver
    i decided to do this because of the pinch welds banging against the sliders like you and also like you flipped it so the larger cushion is on top... Looked like doing the larger on bottom would not have solved the problem, as it looks to be same as stock.
  12. Dec 1, 2016 at 8:46 AM
    #192
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    This thread is awesome and should be a sticky or how to if it isnt already
  13. Dec 1, 2016 at 8:49 AM
    #193
    Pirhett
    Rhett
    San Diego
    Stock...
    Just to touch on it though, will I need the linked lube below when doing the radiator bushing?
  14. Dec 1, 2016 at 3:13 PM
    #194
    Pigpen
    Dan
    Northwest Montana
    No, you don't need it. I linked it because I used it.
    Pirhett[QUOTED] likes this.
  15. Dec 1, 2016 at 7:21 PM
    #195
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    No Lube and no noise here after I loosened and tightened to spec.
    Crom and Pirhett[QUOTED] like this.
  16. Dec 6, 2016 at 7:23 AM
    #196
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    do you torque the energy suspension bushings to the toyota amount or are they different?
  17. Dec 6, 2016 at 7:27 AM
    #197
    Crom
    Nick
    San Diego, CA
    Millions
    Factory specs, in first post on this thread. With new lock nuts, bushings are great, hardware won't loosen. I've beaten my truck severely now for hours off road and I trust it all now.
  18. Dec 6, 2016 at 7:31 AM
    #198
    Pigpen
    Dan
    Northwest Montana
    Same - 35 ft/lbs
  19. Dec 6, 2016 at 8:09 AM
    #199
    Allstar780
    Allstar780 Well-Known Member
    Colin
    Alberta, Canada
    15 TRD Trail Teams Sport
    3" Lift, 32" Goodyear Duratrac, XD Series Hoss Rims
    How tight did you guys go on the radiator bushings?
  20. Dec 6, 2016 at 10:34 AM
    #200
    Pigpen
    Dan
    Northwest Montana
    I didn't torque them. I just tightened them tight with my 1/2" ratchet.
    Edit: I used my 3/8" ratchet for that.
    Crom likes this.
