Body Mount Bushing Install - now with pictures! And a video too!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, May 18, 2016.
  1. Feb 18, 2018 at 6:19 PM
    #421
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Here is directions for toytecs 1" body lift and in them it explains loosening the steering shaft
  2. Feb 19, 2018 at 7:09 AM
    #422
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    OOh man, Pigpen - your steering stem ( at the coupling point ) probably was a little loose. I actually forgot to loosen it and it actually started to pull the frame with the body. At the end, the second I loosened the nut, it started to space out. Literally - 1.5 turns is all that it takes to loosen it.
    As for pictures, I'll have it later today.
    The location is driver's side ( Left ) wheel well. You need to remove the splash guard - once removed, you will see the coupling point and from there, you will loosen the top nut. BEFORE you loosen it - mark the coupler and spline just for reference.
  3. Feb 19, 2018 at 8:47 AM
    #423
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    My truck was 3 years old when I did this mod. Steering was, and is, fine.
    Looking forward to seeing your pics, so I know where to check though. Thanks
  4. Feb 19, 2018 at 9:03 AM
    #424
    Thebubble
    Southern California
    2006 GX470
    That's cool, yeah when I did mine and that happened, I really don't think it would have massive detrimental effects. The only thing it would affect would be your rack's bushings, even then - it's got room for ample amount of deflection.
    Pigpen[QUOTED][OP] likes this.
  5. Feb 19, 2018 at 2:07 PM
    #425
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I think version 1.0 of energy's instructions said to loosen the steering coupler. But I think they dropped it in an updated version. I didn't loosen steering during install and truck was fine.
    AR15xAR10 likes this.
  6. Mar 29, 2018 at 11:50 AM
    #426
    panardo
    panardo Well-Known Member
    Taco 2000 4x4 V6 manual w/RDlock
    which is the difference between installing new body mounts bushings on a 2nd and a 1st gen?
  7. May 19, 2018 at 7:33 PM
    #427
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    forgive the newby question, but what is the purpose of doing this mod? I have 2nd gen. DCLB. Im curious if this is something i should do...
  8. May 20, 2018 at 10:09 AM
    #428
    CoBackCountry
    CoBackCountry Well-Known Member
    J
    Colorado
    Purpose of doing this mod is to replace the stock cab mount bushings that degrade over time, allowing your pinch weld below the cab to make contact with your sliders if you have them.
    Hawco636 likes this.
  9. May 20, 2018 at 7:18 PM
    #429
    Pigpen
    Dan
    Northwest Montana
    I only did it because my cab was hitting my sliders, as CoBackCountry mentioned. The kit isn't intended as a body lift. It's just firmer, more durable bushings.
  10. May 22, 2018 at 11:07 AM
    #430
    Bravisimo
    Joe
    Santa Clarita, CA
    Ah I see. Thank you.
  11. Aug 19, 2018 at 4:29 AM
    #431
    DrFunker
    DrFunker Well-Known Member
  12. Sep 20, 2018 at 9:44 PM
    #432
    jluu44
    jluu44 Well-Known Member
    Jon
    North County San Diego, CA
    2016 Tacoma DCSB 4x4 off-road
    Does anyone know if its the same body mount bushings for 3rd gen Taco? Can't find them on their website.
  13. Sep 21, 2018 at 8:10 AM
    #433
    Pigpen
    Dan
    Northwest Montana
    I don't know if Toyota changed them. It's the same chassis, so I would think they are the same.
    jluu44[QUOTED] likes this.
  14. Sep 30, 2018 at 10:14 AM
    #434
    jluu44
    Jon
    Just did it today on my 2016, the brackets are not wide enough. Had to use a step drill to make the holes bigger. Seems like they upgraded the mount size by a tad on the 3rd gens.
    TireFire likes this.
  15. Oct 26, 2018 at 2:43 PM
    #435
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    @yotastaco @Pigpen
    I am in the garage now about to start doing this project and i have a few questions.
    What is to stop me from doing the rear first, and working my way forward?
    How should i disconnect the ABS wires exactly? The brackets and the plugs or just the connections?
    Thanks so much!
  16. Oct 26, 2018 at 4:32 PM
    #436
    AR15xAR10
    Where do I apply the super lube?
  17. Oct 29, 2018 at 8:07 AM
    #437
    Thebubble
    Southern California
    2006 GX470
    You apply this lube on the poly bushing - pretty much any surface that MAY experience friction. This surface does not have to endure extreme temperature fluctuations so I feel it should be good.
  18. Oct 30, 2018 at 6:12 PM
    #438
    Pigpen
    Dan
    Northwest Montana
    No reason not to work rear to front.
    I didn't disconnect the ABS. I did the front on a different day than the 4 body bushings. I think this may have prevented me from damaging the ABS wire.
  19. Oct 30, 2018 at 6:30 PM
    #439
    AR15xAR10
    I got it done. Disconnected the ABS plugs and removed them from the brackets before i even started. Did driver’s side rear, passenger side rear, passenger side front, driver’s side front. Then driver’s side radiator and passenger side radiator.
    To get the front cab mounts out, i had to losen the steering shaft and both radiator mounts.
    Thebubble likes this.
  20. Nov 10, 2018 at 11:07 PM
    #440
    AR15xAR10
    I think i installed my radiator mounts upside down because my hood doesn’t want to open when i pop the latch. So i guess i’ll be troubleshooting that.
    Had the same issue when i did the universal mounts a year ago
