Body Mount Bushing Install - now with pictures! And a video too!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, May 18, 2016.
  1. Mar 18, 2019 at 7:20 PM
    #441
    Adventure4x4
    Adventure4x4 Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    Any update on this? Having same issue.
  2. Mar 18, 2019 at 7:26 PM
    #442
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I installed these kits last 2 weekends ago and flipped the bushings so that the bigger bushings were on the top and added a 1" BL no issues with the hood for me. They may not be sitting correctly in their respective mounts.
    We installed all the bushings and BL pucks snugged up the bolts so the bushings wouldn't drop free but had to go around to each bushing and make sure that they were sitting in the mount correctly some we needed to push the cab around a little to get them to drop in correctly. Then went around the truck and did the final tightening.
    AR15xAR10[QUOTED] likes this.
  3. Mar 18, 2019 at 7:36 PM
    #443
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    My hood is definitely tighter with the flipped bushings than it was before doing this. I have to wedge my fingers in over the headlight to pop the hood where I can get to the latch. It's not a problem, it's just different than it used to be.
  4. Mar 18, 2019 at 8:23 PM
    #444
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Adjust hood clearance by turning the rubber stoppers on each side. They spin by hand.
    ovrlndkull[QUOTED] likes this.
  5. Mar 18, 2019 at 11:50 PM
    #445
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I don't have hood issues
  6. Mar 19, 2019 at 6:10 AM
    #446
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Replace them with the ones from the tacoma specific kit.
    Still the hood is very hard to open
  7. Mar 19, 2019 at 6:12 AM
    #447
    AR15xAR10
    Also, the zinc coating on these is a joke. Everything is so rusty already
    ovrlndkull likes this.
  8. Mar 19, 2019 at 6:57 AM
    #448
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    I don't think they're zinc, it appears they're only Alodine dipped - I've had mine on for the last 1.5 years, no rust but then again - live in CA and spray... more like flood it with silicon monthly
    whatstcp and AR15xAR10[QUOTED] like this.
  9. Mar 19, 2019 at 7:53 AM
    #449
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I just got a set of these and the radiator bushing as well this last from from the eBay sale. I'm hoping to do these and a CMC at the same time. Any one have issues sourcing new long mounting bolts in the case that they break off during removal?
  10. Mar 19, 2019 at 8:32 AM
    #450
    AR15xAR10
    One winter and the washers are flaking rust....
    I’m in Maryland, towards the lower half of the salt/rust belt
  11. Mar 19, 2019 at 11:26 AM
    #451
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Well damn I could of hit them with some paint before installing them oh well.
    Did you try that other kit first for the rad support?
  12. Mar 19, 2019 at 4:36 PM
    #452
    Thebubble
    Southern California
    2006 GX470
    Sorry to hear that - everytime im in snow... just thinking... fak, where's the water hose...
  13. Mar 19, 2019 at 6:29 PM
    #453
    CoBackCountry
    CoBackCountry Well-Known Member
    J
    Colorado
    Buy new ones from Toyota, they were rather cheap and you do not want to re-use the same bolts. I bought mine from Camelback Toyota parts online month ahead of time to make sure I had all the parts I needed when doing this.
    boostedka[QUOTED] likes this.
  14. Mar 19, 2019 at 7:41 PM
    #454
    boostedka
    James
    NM
    That’s a great idea. Thanks for the tip. I’ll PM Gunny to get a set.
  15. Mar 19, 2019 at 8:24 PM
    #455
    AR15xAR10
    I did the universal kit and it worked fine.
    Then switched to the full body kit and its been a pain in the ass to open my hood ever since
  16. Mar 19, 2019 at 8:25 PM
    #456
    AR15xAR10
    I wouldn’t mind it, if they would just stop spraying that salt brine mixture and spreading salt like its free, wasting my tax money to rot away what I worked hard to pay for.
    Thebubble[QUOTED] likes this.
  17. Mar 19, 2019 at 11:44 PM
    #457
    Taco-Obsessed
    Subbed for future reference. Mine are squeaking must have over torqued. Thanks OP.
  18. Mar 20, 2019 at 2:15 AM
    #458
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Huh??? Has me stumped I don't know what to tell ya to help. Mine did just fine.
    NC sprays that shit when there is a threat of snow. Luckily most of the time it just rains so at somepoint the brine gets washed away and the rain helps some with rinsing off that nasty stuff. But I still rinse it off well.
  19. Mar 20, 2019 at 5:00 AM
    #459
    AR15xAR10
    Its fine. It works.
    Yeah, that shit should be illegal
  20. Mar 20, 2019 at 6:32 AM
    #460
    Thebubble
    Southern California
    2006 GX470
    Funny you mentioned this... mine are too..
