Body Mount Bushing Install - now with pictures! And a video too!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, May 18, 2016.
  1. Jul 12, 2016 at 6:39 PM
    #81
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Good points. Thanks. Won't bother then.
    I think I'll order the kit and schedule time to install. :). My taco lean is so bad, hope this helps.
    Pigpen[OP] likes this.
  2. Jul 12, 2016 at 9:39 PM
    #82
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Glad to hear that they corrected the washers hole's diameter. :thumbsup:
    Crom likes this.
  3. Jul 13, 2016 at 8:08 AM
    #83
    14 Tacoma
    14 Tacoma ColeMcMathisaDouche
    Clinton
    IL
    2014 TRD Sport
    Cheap ebay bumper, plus others
    I'm contemplating this, but don't want to become the third victim. That is my luck.
    How much shifting would you say the bushing does against the washers? I'm trying to plan ahead and brainstorming.....
    I'm wondering if cutting a round disc out of an innertube or similar rubbermight eliminate the friction squeaks. Maybe a thin piece of softer plastic like a milk jug or something?
    You guys think something like that would wear through quickly and make it moot?
  4. Jul 13, 2016 at 8:11 AM
    #84
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    I'd say it's not worth the trouble. Replace the nuts and torque to 34 lbs. I'm sure over torque is my problem, and even with that the noise has nearly gone away. I'd put a little super lube on them just on principle.
  5. Jul 13, 2016 at 9:08 AM
    #85
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    It's fine, over tightening is the only thing causing the noise.
  6. Jul 13, 2016 at 9:42 AM
    #86
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Loosened and tightened to correct spec and the noises are down to very very minor (<1%) and may be coming from my suspension at this point.
    BluLED, Torspd and Crom like this.
  7. Jul 13, 2016 at 10:49 AM
    #87
    14 Tacoma
    Clinton
    IL
    2014 TRD Sport
    I'll put this on my fall to do list then. Too fricken hot in July and August.
  8. Jul 13, 2016 at 10:50 AM
    #88
    Sandman614
    Tim
    '06 SR5 Off Road
    It's a pretty quick job, get yourself a good fan and cold beverage!
    14 Tacoma[QUOTED] likes this.
  9. Jul 13, 2016 at 10:58 AM
    #89
    14 Tacoma
    Clinton
    IL
    2014 TRD Sport
    Works slowing down a bit for the summer, I'll grab that cold beer and a fishing pole instead.
    I want to wait until I get my 885's as well, that way if I do end up with a reverse taco lean I can pull the spacer when I swap out the 884's. Do it all in the same weekend and be done.
  10. Jul 27, 2016 at 9:28 AM
    #90
    Crom
    Nick
    San Diego, CA
    Millions
    Question for you guys that have installed already.
    Any problems getting a torque wrench in there for the frame bracket bolts? They are the little ones, 45 ft.lb is spec on those.
    Or do I need a crows foot?
    Thanks.
  11. Jul 27, 2016 at 9:37 AM
    #91
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Not if you lift the cab enough. Should have more than enough room to get a torque wrench in there
    Crom likes this.
  12. Jul 27, 2016 at 9:38 AM
    #92
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks Jeff, that's what I wanted to hear.
    Got my kit on the way.
  13. Jul 27, 2016 at 9:50 AM
    #93
    VolcomTacoma
    Jeff
    NorCal
    It all comes down to home comfortable you feel doing it. I also found out you don't have to unhook the ABS connection...because mine wouldn't come undone, I just popped out the wire harness clips from the body and had plenty of slack. Jacked up the cab enough to stick 2 2x6's in between cab and my sliders and then kept the jack under as well for a little extra tension...I get nervous sticking my hands in small places that could close suddenly. But yeah if you jack it up enough, you can easily get a socket wrench in there and a torque wrench.
    Crom likes this.
  14. Jul 27, 2016 at 10:01 AM
    #94
    Crom
    Nick
    San Diego, CA
    Millions
    That's great. Thanks. I'm going to follow suit. Looking forward to swapping them.
  15. Jul 27, 2016 at 10:31 AM
    #95
    VolcomTacoma
    Jeff
    NorCal
    One key thing everyone needs to remember when doing this-
    Be careful where you place the jack under the cab!!
    Rob and I found out the hard way that there is a pinch weld under there that it sealed that if you place your jack along that line, you can split the pinch weld and play peekaboo from under the truck in to the cab. Try to place the jack in a spot that doesnt have a seal and looks pretty stout
  16. Jul 29, 2016 at 7:05 PM
    #96
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yes, I highly recommend it. The steering shaft is secured to the cab. Also keep an eye on the brake lines that go down the firewall and onto the frame under the drivers side there is zero slack in them.
    CollegeKevin[QUOTED] likes this.
  17. Jul 29, 2016 at 7:22 PM
    #97
    VolcomTacoma
    Jeff
    NorCal
    I had zero issues with the steering shaft or brake lines, just the ABS line got really taut before I figured out to undue the wire clasps
  18. Jul 29, 2016 at 7:22 PM
    #98
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    Anyone else have a noticeably bumpier ride after this install? I feel like I'm riding in a covered wagon now. What torque are people using? Mine are at 50 or a little more, but I've read 20-40ish as well. Perhaps I have them too tight and its compressing the poly too much, making it stiffer?
  19. Jul 29, 2016 at 7:25 PM
    #99
    VolcomTacoma
    Jeff
    NorCal
    Doesnt matter, you went from rubber to plastic essentially. So all the vibration eating rubber is now gone. Polyurethane is gonna transmit vibrations alot more.
  20. Jul 29, 2016 at 7:25 PM
    #100
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    It is going to ride a lot stiffer the poly bushings are much former than the soft rubber OE bushings.
