Body Mount Bushing Install - now with pictures! And a video too!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, May 18, 2016.
  1. Aug 26, 2016 at 8:34 PM
    #141
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Had the same issue. Moisture must get trapped in there somehow. I wire brushed my bolts, and coated them with grease to help slow it down.
    Crom likes this.
  2. Aug 26, 2016 at 8:45 PM
    #142
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    That's really wierd. Is it the same situation on both sides?
    I'm really jealous of the impact. I'll be doing it the old fashioned way.
    Crom[QUOTED] likes this.
  3. Aug 26, 2016 at 9:57 PM
    #143
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Thanks Tor.
    Probably so.
    My guess is that the corrosion has to do with the choice of plating of the bolt.
    Very smart to grease the bolts. I generally do the same.
    My new favorite grease is the Prothane Super grease. It's adhesion and waterproof qualities are nothing short of incredible. NASA grade stuff.
    Your experience is vast, and you probably know of it. lol
    Love the cordless electric impact.
    Buy yourself one for Xmas, or birthday. You wrench a lot and it will save you a ton of time. :)
    I haven't got the drivers side yet, but I bet it's the same. When I did the radiator bushings, drivers side bolt was corroded too.
    It appears the coating on the radiator and back body bolts is a crappy black oxide finish or its a phosphate oil finish.
    Plating is difficult to tell visually... Whatever it is, it's not very good.
    The front cab bolt looks zinc chromate coated to me and, it's in excellent shape.
    Not sure why Toyota specified different types of bolts for the same application. Very interesting question.
  4. Aug 31, 2016 at 10:04 PM
    #144
    Crom
    Nick
    San Diego, CA
    Millions
    Completed the install.
    What a pain in the ass.
    I had complications with cab alignment after doing the second side, this was mainly due to my work site being on a slight incline. It didn't seem to matter for the first side, but it definitely mattered after the second side. I fixed it by rolling the truck backwards slowly and stopping suddenly, cab slid backwards a few CM and all was well. :D
    My core support is also f***ed up on the drivers side a little bit making the bolt removal and install another PITA. lol
    Other notes:
    I decided to retire my E.S. universal radiator bushings and went to kit bushings.
    And it turns out that all my cab mounts were in excellent shape. There was nothing really wrong with any of them as far as I could tell. Slight cracking on both rear mounts at the bottom. Front cab mounts had some cracking under the top plate neck area. I had suspected that one was damaged, but it was not the case. And in my opinion, the Toyota OE cab mounts are very high quality. Had I known that they were all fine, I would have left them alone.
    I also noted that the front and rear Toyota OE cab mounts have different part numbers, and are physically different, very slight though.
    New bushings did nothing for my Taco lean. Zero. It's exactly the same as it was before. And it makes sense, it really shouldn't unless one or more is damaged or worn out, etc.
    I did grease the shit out of the sleeves when assembling, left the washers mostly dry.
    I've only got 6 miles on the truck post install, but should be in the dirt soon to see if there is any notable difference. So far on the street I can't tell any difference.
    I'm going to drive the truck for a few days and see if I note any differences.
    I took pics of install and bushings and posted them in my build here
  5. Aug 31, 2016 at 10:14 PM
    #145
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    I could use a front drivers quarter bushing install...
    I seem to be missing one up at the very front in front of the radiator.
    If any one has something used, they could ship... I'll be grateful.
  6. Aug 31, 2016 at 10:28 PM
    #146
    Crom
    Nick
    San Diego, CA
    Millions
    Do you still have the bolt? The nut?
    How about a pic of missing bushing?
  7. Aug 31, 2016 at 10:30 PM
    #147
    Skyway
    Ande'
    St.Pete
    You're in sandiego... That may be the reason for the rust...
    Let's see if I can find that info. Pics on another thread ...
  8. Aug 31, 2016 at 10:33 PM
    #148
    Skyway
    Ande'
    St.Pete
  9. Aug 31, 2016 at 10:38 PM
    #149
    Crom
    Nick
    San Diego, CA
    Millions
    I see. It was as I thought. Truck was maintenanced and they didn't put it back together or vibrated apart.
    I can send you my ES universal bushings i just took out. They are awesome and in excellent shape.
    You need a nut for the bolt.
    PM me your shipping address and I'll send.
    Sandman614 and Skyway like this.
  10. Sep 1, 2016 at 8:20 PM
    #150
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    This shouldn't surprise anyone but the tacoma specific kit doesn't fit 3rd gens. The bushing looks about right and the main bolt works but the mounting plate is different. The bolt holes on the mounting plate are too close. Gotta make new plate.
  11. Oct 16, 2016 at 8:16 AM
    #151
    eppy
    eppy Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Man, does anyone know if Toyota replaced these when replacing the frame. Sure Wish I knew this before because I would have had them replace them with factory ones. Dam!!
  12. Oct 16, 2016 at 8:37 AM
    #152
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    They did not on mine.
  13. Oct 16, 2016 at 9:38 AM
    #153
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    The factory bushings are the problem. The newer models seem to have worse bushings.
    12TRDTacoma likes this.
  14. Oct 16, 2016 at 4:52 PM
    #154
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Never really had an issue with mine, but was just curious because she has 120k and figured everything else is new, so why not replace these to. But it does look like a lot of work to change them out and guys are having issues with the new ES ones
  15. Oct 16, 2016 at 6:48 PM
    #155
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    It's really not that bad and issues were corrected or self inflicted lol.
  16. Oct 16, 2016 at 6:52 PM
    #156
    Pigpen
    Dan
    Northwest Montana
    My noisy bushings were totally self-inflicted
  17. Oct 16, 2016 at 6:57 PM
    #157
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Him and myself. Mine only clunk from the rear ones. Trying to figure out if it is the bolts binding to the inner sleeve because the bolts are rusty, or if the bushings themselves are contributing to the noise.
    Regardless, they work well and are an improvement over stock.
  18. Oct 16, 2016 at 6:59 PM
    #158
    VolcomTacoma
    Jeff
    NorCal
    Your shit is tweaked bro, that's why noises and stuff lol. Since I pulled my glass back from the cab, zero noises.
  19. Oct 16, 2016 at 7:05 PM
    #159
    Pigpen
    Dan
    Northwest Montana
    I still haven't reduced the torque on mine, but they're one of the less noisy parts of my truck.
  20. Oct 16, 2016 at 7:07 PM
    #160
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What's tweaked?
    I need to try that myself. I just zapped them on with all the available power the cordless impact had.
