Body Mount Bushing Install - now with pictures! And a video too!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, May 18, 2016.
  1. Oct 16, 2016 at 7:16 PM
    #161
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Your Frame.
    And they are overtorqued as well.
  2. Oct 16, 2016 at 7:21 PM
    #162
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    I did the same with the impact. Then, when I heard the noises, I got out the big torque wrench and tightened them :bikewheelie2:
  3. Oct 16, 2016 at 7:28 PM
    #163
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Overtorqued I definitely agree. As for the frame. I would agree with you, but I have seen too many instances where things line up when they were originally fabbed up using OE parts which lined and bolted right up no problem.
    What did you spec them to? Lol. We are so quick to use the impact. :D
  4. Oct 16, 2016 at 7:32 PM
    #164
    Pigpen
    Dan
    Northwest Montana
    Either 85 or 95. I don't remember.
  5. Oct 16, 2016 at 7:35 PM
    #165
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The Makita cordless impact is capable of 118 ft lbs. of torque fully charged. Not much over what the spec you posted was. I'm starting to think I just need to pull out the bolts fully, wire wheel them off then just lube the shit out of them and the sleeve, as well as the bushings and the sounds should recede.
    Pigpen[QUOTED][OP] likes this.
  6. Oct 16, 2016 at 7:39 PM
    #166
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Energy Suspension told me the noise from the over torqued bushings is the sleeve moving internally vertically. Grease will help, but really correct torque is all that's needed. 35 ft.lbf.
    12TRDTacoma[QUOTED] likes this.
  7. Oct 16, 2016 at 7:40 PM
    #167
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh 35 ft. lbs. is what it is? Damn. If that's the case I went way overboard on the torque for mine.
  8. Oct 16, 2016 at 7:41 PM
    #168
    Crom
    Nick
    San Diego, CA
    Millions
    Technically it's 34. lol but yeah, not much is needed.
  9. Oct 16, 2016 at 7:45 PM
    #169
    Pigpen
    Dan
    Northwest Montana
    They say not to reuse the old nuts and bolts too
    Crom likes this.
  10. Oct 16, 2016 at 7:57 PM
    #170
    Crom
    Nick
    San Diego, CA
    Millions
    I've had my radiator bolt loosen up on me after off road washboard...
    Speaking of, the nuts on the radiator bolts are not the same as the cab mount bolts on my 09. Just an observation I made after looking at a catalog for a later model truck that indicated same part number for all 6 nuts, and ordering new nuts to discover they are different. Could have been an error in the catalog too.
  11. Oct 16, 2016 at 8:43 PM
    #171
    VolcomTacoma
    Jeff
    NorCal
    Things are torqued to a certain degree for a reason. Toyota engineers didn't just point at numbers and say "Yeah that sounds about right", nothing is impacted until it won't go anymore. Overtorque is just as bad as under torque. Loctite and a torque wrench are you friends on these trucks.
    And the U bolt torque spec was an admitted typo from Toyota. A Typo, not an incorrect torque number.
    Zebinator likes this.
  12. Oct 18, 2016 at 9:51 PM
    #172
    NaZRaQ
    NaZRaQ Well-Known Member
    Zee
    Denver
    2024 TRD OR Tacoma hybrid
    glad to find this thread, I've had the pinch weld banding against my sliders bad lately and its beyond annoying! it got worse after i had the body mount chop done... this looks like a great solution but not sure i can tackle this on my own. what would a shop charge to replace the body mount bushings ?
  13. Oct 18, 2016 at 9:58 PM
    #173
    Pigpen
    Dan
    Northwest Montana
    Get together with some local members and have a mod day. It's really not as bad as I make it out to be. I went in blind, so it sucked. If I did another one, it would fly by quick and go smoothly. Just have all the tools and parts on hand, and make sure anyone involved has a clear understanding of what's going on. I did this write up so it would be easier for others than it was for me.
    NaZRaQ[QUOTED] likes this.
  14. Oct 19, 2016 at 8:35 AM
    #174
    eppy
    eppy Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Good stuff fellas and its threads like this that make all us taco heads lives a little easier!!!
    hirod likes this.
  15. Oct 19, 2016 at 9:40 PM
    #175
    NaZRaQ
    Zee
    Denver
    Did you ever retorque yours? How's the noise level now?
  16. Oct 20, 2016 at 7:31 AM
    #176
    Pigpen
    Dan
    Northwest Montana
    Haven't touched them. They've quieted down to the point where I very rarely notice, or even think about, them.
  17. Oct 20, 2016 at 8:21 AM
    #177
    Crom
    Nick
    San Diego, CA
    Millions
    I don't trust my old hardware, and I am going to double nut my radiator bolts. I'm going to try and source some metric nylocks. I'll share back when I find the right thread size and pitch.
    This is the parts image that is in the thread OP. I believe it is right for part numbers. I will verify. Part verified 10/26/2016
    The image below is the image I used when ordering parts, and was wrong. It's the PDF catalog for the 2013 that's embedded in the forum somewhere.
    They showed the same nut (item 35) for the radiator bolts, as the same for the body bolts. Wrong.
    Biscuits likes this.
  18. Oct 26, 2016 at 10:56 AM
    #178
    Crom
    Nick
    San Diego, CA
    Millions
    Radiator nuts are M10-1.25. I've .
    Pigpen[OP] likes this.
  19. Oct 26, 2016 at 11:36 AM
    #179
    Pigpen
    Dan
    Northwest Montana
    I need to check mine. I've got a vibe that I can hear but not feel when taking off from a stop. I hope this is it. I drive a lot of wasboard and potholed dirt roads.
    Crom[QUOTED] likes this.
  20. Oct 26, 2016 at 11:50 AM
    #180
    Crom
    Nick
    San Diego, CA
    Millions
    I too drive washboard.
    I've had my radiator bolt loosen up on me after the first time i swapped to the universal ES bushings last year.
    I'm not taking any chances this time. I torqued the radiator bolts as firmly as possible with 1/4 drive ratchet and 14mm socket. This helped firm up the front end. I'm running the kit bushings now.
    There is enough threads exposed to double nut it with nylock nut, so that's my plan.
