Bolt on grill for 2nd gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dylan_ElDoradoCo, Dec 20, 2017.
  1. Dec 20, 2017 at 11:24 AM
    Dylan_ElDoradoCo
    Dylan_ElDoradoCo [OP] Well-Known Member
    Dylan
    Pollock Pines, Commiefornia.
    2nd Gen Super White DCLB
    Am looking for a direct bolt on grill for my 2012, no cutting no BS just remove the old grill, bolt on the new one...most grills I see for tacoma require cutting..i want my origional grill in tact
    ChadsPride likes this.
  2. Dec 20, 2017 at 11:25 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    OEM TRD Pro is a good option
    Dylan_ElDoradoCo [OP] and Coot83 like this.
  3. Dec 20, 2017 at 11:28 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I think this might be one of your only options unless you want to pay like $500 to have a bolt on grill made for you where they cut out the middle and bolt it in themselves. I just cut mine out and screwed in my insert. Took about an hour total between the dremel work and the fitment.
  4. Dec 20, 2017 at 11:33 AM
    Fatmonk8
    Fatmonk8 Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    Got this grill online, bolted right on, just took the old one off and popped this one on, same hardware.
    And mine was only $100
  5. Dec 20, 2017 at 12:40 PM
    Dylan_ElDoradoCo
    Dylan
    Where can I find this one at?
    Bluegrass Taco and ChadsPride like this.
  6. Dec 20, 2017 at 12:41 PM
    Fatmonk8
    Paul
    Delco, PA
    Dylan_ElDoradoCo [OP] likes this.
  7. Dec 20, 2017 at 12:41 PM
    Dylan_ElDoradoCo
    Dylan
  8. Dec 20, 2017 at 12:43 PM
    ChadsPride
    Meh, if you like it...who cares!
    I personally think the OEM insert looks good with modified emblem.
    smw62891 likes this.
  9. Dec 20, 2017 at 12:44 PM
    Fatmonk8
    Paul
    Delco, PA
    If you don't mine me asking. What do you mean by "bro out"?
  10. Dec 20, 2017 at 12:45 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Just remember that you are a 2012 so his 2005-2011 grill style won’t fit on yours. That said they got similar ones like that you just have to use a dremel and cut out the inner area.
    Fatmonk8, Muddinfun and ChadsPride like this.
  11. Dec 20, 2017 at 12:45 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Nonsense!
    I have pro headlights and a pro grille on my sport bro!
    2004TRDtaco, Coot83 and ChadsPride like this.
  12. Dec 20, 2017 at 12:46 PM
    Muddinfun
    Muddinfun Well-Known Member
  13. Dec 20, 2017 at 12:48 PM
    Fatmonk8
    Paul
    Delco, PA
    ohh, dang I didn't catch that, my bad :frusty:
  14. Jan 6, 2018 at 8:49 PM
    Dylan_ElDoradoCo
    Dylan
    Well I want a clean job, a 2011 would require some cutting that would have to be perfect, if it's not it looks ridiculous.
  15. Jan 6, 2018 at 8:58 PM
    Wyckedan
    Wyckedan Well-Known Member
    Seattle/Woodinville
    2014 Stormtrooper AC 4x4 V6
  16. Jan 7, 2018 at 12:24 AM
    Dylan_ElDoradoCo
    Dylan
  17. Jan 7, 2018 at 4:54 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2012 TX pro.
  18. Jan 7, 2018 at 4:56 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 BFG KO2's.
    2012 on is available from same vendor (on Feebay)
  19. Jan 7, 2018 at 4:58 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Early 2nd gen....Same grill is available in late 2nd gen. Hunt it up on Feebay!
    Grill emblem is from 1978 Landcruiser.
  20. Jan 8, 2018 at 11:34 AM
    Ricky B
    Ricky B Well-Known Member
    Maumelle, Arkansas
    2007 V6 Auto
    It's not a direct bolt up but you still use your OEM grill and cut out the middle and put there insert in. It's at customcargrills.com I used automotive goop and it was really an easy mod. I have about 1 hour in the whole project with tapping and cutting it out. The glue needs about 24 hours to set up but after that its good. Here is a shot of before and after. Rick
    You can have the letters painted any color you choose and they have a few options on the style of mesh and the emblems. I went with a gloss black mesh and flat black letters.
    Fatmonk8 likes this.
