Bolt on my amp is stuck. what should i do
Discussion in 'Audio & Video' started by chaos316, Oct 18, 2011.
  1. Oct 18, 2011 at 2:11 PM
    chaos316
    chaos316 [OP] Well-Known Member
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    285/75/16 BFG KO2 Ditch Lights
    The bolt that clamps down my power wire is stuck. I have tried wd40 and pretty much everything else. now the bolt it stripped. what do you guys think i should do?
  2. Oct 18, 2011 at 2:22 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    its the bolt that screws down on the power wire
    its stuck all the way down
  3. Oct 18, 2011 at 2:26 PM
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    Did you actually allow the WD40 to penetrate or did you spray and try and unscrew?
    If it is stripped, good luck with that. You can try drilling it out.
  4. Oct 18, 2011 at 2:30 PM
    jandrews
    '09 FourDubDee TRD OR
    Pull harder.
  5. Oct 18, 2011 at 2:30 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    alright I'm going to go try all of those right now. wd40 wont hurt the amp at all will it?
  6. Oct 18, 2011 at 2:33 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    can that all be found at a home improvement store? i want to take it to a local audio shop, but i feel like they would charge a lot, know its the only jl audio dealer in town
  7. Oct 18, 2011 at 2:33 PM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    grab a drill with a small bit and make a hole on the stripped screw, try to brake it off or some times while your drilling a hole it will start unscrewing it self. After you've done that, do hunting for a new one or find something similar to it, alot of times audio shops have spare screws they will sell ya or even have it for free.
  8. Oct 18, 2011 at 2:35 PM
    TROKITA
    Arty
    Utah, the valley
    you can always look for the screw online, if you live in a little city, just type in the model of the amp,
  9. Oct 18, 2011 at 2:36 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    alright. thanks guys
  10. Oct 18, 2011 at 2:38 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    yea i think I'm gonna run to that shop real quick.
  11. Oct 18, 2011 at 2:39 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Do you really need to remove the wire? Did you sell the amp? Are you replacing the amp? If replacing-just cut the wire. If selling-sell it with the ground wire. Problem solved.
  12. Oct 18, 2011 at 2:40 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Use a dremel and cut a slot in the head of the bolt. Then use a flat head to unscrew it.
  13. Oct 18, 2011 at 2:40 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    no I'm installing it and i can't get the power wire attached
  14. Oct 18, 2011 at 2:41 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    i would but i don't have a dremel
  15. Oct 18, 2011 at 2:42 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    You might be able to hammer a slightly larger flat head into the head of the bolt and get the same effect.
  16. Oct 18, 2011 at 2:55 PM
    Opihiman10
    Opihiman10 Active Member
    Honolulu, Hawaii
    2011 double cab 4x4 TRD SR5
    Nerf bars
    If you can make sure the connector does provide direct access into the amp you should be fine. However things like liquid wrench and the WD40 tend to get everywhere whether you want it or not.
    One more option you can try is to heat the black portion up with maybe a soldering iron. or a small torch with a damp cloth covering the rest of the amp.
    Good luck.
    OPI
  17. Oct 18, 2011 at 3:27 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    That's the way to get the screw out.
  18. Oct 18, 2011 at 3:50 PM
    Firetech
    Firetech Well-Known Member
    Ralph
    Maryland
    2010 SR5 Off Road
    Drill a small hole, get an easy out at the hardware store. It should come right out.
  19. Oct 18, 2011 at 6:34 PM
    dexterdog
    Oly WA
    2012 F150
    I gotcha now. I'm a little slow. Your best bet may be to drill it out if you can't cut a slot in it. I'd get a reverse drill bit smaller than the screw. As you are drilling it will probably start to back itself out. Use pb blaster or aerokroil and let it soak overnight before hand.
  20. Oct 18, 2011 at 9:13 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    alright thanks a lot
