Bolt-on Slider Users, Share Your Experiences
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Sep 18, 2011.
  1. Sep 20, 2011 at 9:31 AM
    #41
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I agree welding the frame will not hurt it but disagree that welded is the way to go. In order for the bolt on sliders to fail, you'd have to snap several grade 8 bolts (assuming that's what you used, if you went cheap on the hardware then shame on you). That is no easy task and I have yet to see a thread where someone actually managed to 'break off' bolt on sliders. If everything is mounted up properly and all bolts properly torqued, I don't see the benefit of weld on vs. bolt on other than you can't remove them to touch them up from trail damage or salt.
  2. Sep 20, 2011 at 9:40 AM
    #42
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    a member here who will remain nameless has bolt on sliders and one bolt was either sheared or vibrated out and the slider hit the rocker. I have weld on and dont have to worry about that...
  3. Sep 20, 2011 at 9:41 AM
    #43
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    That's why you go with Shrockworks and drill only 3 holes per side. ;)
  4. Sep 20, 2011 at 9:43 AM
    #44
    Yoytoda
    Roland
    completely stock
    6 months after placing your order:p
  5. Sep 20, 2011 at 9:44 AM
    #45
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I totally agree with you on that one I myself would never run bolt on sliders but that's just a personal preference. for most of the wheelers on this site bolt on would be fine. But Ive seen hard hits with bolt on sliders (I don't know what kind) but they move way too much for my taste but those are HARD hits i'm talking 2' drops right on the slider and most guys here don't wheel that hard.
    That being said OP bolt on sliders should be fine for you with the light wheeling your planing on doing.
  6. Sep 20, 2011 at 11:40 AM
    #46
    Umrunner
    Umrunner Caltanian
    Around.
    '11 DC OR Timberland Mica. 6 speed.
    Leer 100xr with adventure package, duratrack's, weathertech's, demello sliders, billie 5100's all around, URD short shifter, Diff breather mod. Hiese lightbar. Grillcraft grill. PIAA 520 severere weather driving lights. Other random stuff as well.
    I went with the demello bolt on sliders.
    You can bolt them up without any drilling if you don't plan to beat on them, but 4 holes per side are all you have to put in if you do.
    Super easy to install, super beefy. I have also done the high lift deflection testing, no budging at all. Hit them a few times on a trail, and they are just as they were.
    Bolt on done right, is just as strong as a weld on job. Don't be afraid to go either route.
  7. Sep 21, 2011 at 12:57 PM
    #47
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    We believe our sliders are the best offering on the market. Our latest version has many features that others don't offer including:
    • Beefy .134 wall tubing
    • Proven Kickout design (not all kickouts function properly)
    • Fully Gusseted
    • Made in the USA (unlike TG's from China)
    • Bolt-On Design with Minimal Frame Drilling (we use many existing holes)
    • 3/16" Thick Frame Mounting Plate for Added Strength & Reinforcement
    • Angled Up to Provide the Most Amount of Ground Clearance
    • Optional Dimple Die Fill-Plates
    • Grade 8 Hardware Included
    I've ran both versions on my truck. My original ones were first bolted on (16 holes per side), then welded on, then cut off to bolt on our latest version, and yet no problems with my frame! I'm still running them bolted on and they have been plenty strong enough on some of the hardest trails around.
    Also, to set the record straight, our older style required notching of the pinch weld for proper installation. Those who had problems with them "hitting the body" did not do this. Our new version uses square legs instead, but we still recommend notching the pinch weld.
  8. Sep 21, 2011 at 1:11 PM
    #48
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I agree with the others that mentioned Shrockworks. I love my sliders and they did save me a few times so far. I also use a Hi-Lift Jack on them with no problems at all. Very well, sturdy product. I'd buy them again in a second
  9. Sep 21, 2011 at 3:44 PM
    #49
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    Bolt on with proper design and hardware is easily strong enough for sliders. As far as I know, winches have been bolted onto bumpers that are bolted onto frames that are bolted, riveted and welded together for some time now without notable failure.
    :deadhorse:
  10. Sep 21, 2011 at 6:35 PM
    #50
    mhuff29
    mhuff29 TÅpƐwo®m
    Arvada, CO
    05 Tacoma Double Cab SR5
    Air Filter (K&N) Wheels & Tires
    haven't seen anyone mention Stubbs either
  11. Sep 21, 2011 at 6:47 PM
    #51
    jandrews
    '09 FourDubDee TRD OR
    Agreed, quality bolt ons will work fine.
    There are hundreds if not thousands of sets of weld-on sliders out there. If there was a problem with the method, it would be known.
    There is no problem.
    Whatever method you choose, hybrid sliders come highly recommended. Square tubing takes most of the abuse in these designs and it is beefier than round tube. It's also stiffer and less likley to allow deflection when jacking/using.
  12. Sep 21, 2011 at 6:50 PM
    #52
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    should also check out Avid!
    i got bolt on from him last year and i love them!
    very solid and can take hits with no problem.
  13. Sep 21, 2011 at 6:53 PM
    #53
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Avid bolt-on Sliders are technically not sliders, as they use the Mounting point in the body (same as step bars).
  14. Sep 21, 2011 at 6:58 PM
    #54
    jandrews
    Avid bolt-ons bolt to the tube-step mounts and CANNOT stand up to offroad use.
    Did you get a custom set?
  15. Sep 21, 2011 at 6:59 PM
    #55
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    na, but they have been holding up fine for what i have been doing
  16. Sep 21, 2011 at 6:59 PM
    #56
    Captarm
    Captarm Well-Known Member
    Armand
    Maine and Rhode Island
    2010 SR5 Silver/Black, Tinted windows
    Leather Arm Rest Firestone Ride-rite K&N oil air Filter Wet Okole Black/Gray w heated seats Alpine CDE-123 receiver w Blue tooth,MP3,USB port AP Rock-sliders Viper Auto starter, should have gotten with alarm Anytime Fogs NOKYA7626 yellow lights Muth Heated, Signal Mirror Leer Cap Silver stream line top Differential Breather Mod
    I have the A P bolt on Rock Sliders and I love them.
  17. Sep 21, 2011 at 7:00 PM
    #57
    jandrews
    :facepalm:
  18. Sep 21, 2011 at 7:07 PM
    #58
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
  19. Sep 21, 2011 at 7:14 PM
    #59
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    what?
  20. Sep 22, 2011 at 7:41 AM
    #60
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    and on the flip side, you have to worry about a crappy weld job... both need to be properly installed, and if so, will take plenty of abuse. therefore i choose bolt ons personally.
