bolt size for brackets that attach sway bar to frame?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yosh2000, Jun 23, 2012.
  1. Jun 23, 2012 at 10:49 PM
    yosh2000
    yosh2000 [OP] Well-Known Member
    CO
    '17 Tundra CM 5.7
    hopefully selling my truck tomorrow, but i want to re-install the sway bar before i do. i misplaced the 4 bolts that hold the sway bar bushings to the frame of the truck.
    anyone know what size bolts they are? i've done a quick search here, on google and also looked at an old parts list i had saved, but turned up nothing on the actual size of the bolts. im also in CO and my dad is selling the truck for me in CA, so i cant just go measure, test other bolts, etc...i need to give him and exact size so he can go get them.
    thanks for the help guys!
  2. Jun 24, 2012 at 12:15 AM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Well, I know this is not quite what you are looking for, but it might be an option. Figure you can have your dad run to the local dealer and pick up the four exact bolts and not have to worry about what size they are.
    I believe part number 90119A0168 is what you are after.
  3. Jun 24, 2012 at 12:23 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    Yep, that's the part number, just don't think the parts dept is open tomorrow, hence needing the size. The local ace is, and they will carry that bolt for sure, just need to know what size
    Good looking out, Ill call just to make sure, thanks!
