Bolt size for pre-threaded under-hood fender mount points?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vtstouff, Apr 26, 2017.
  1. Apr 26, 2017 at 8:54 AM
    vtstouff
    vtstouff [OP] Member
    Richmond, VA
    2017 Silver DCSB TRD OR
    RCI Alum Skid, BFG KO2, ARB OBA
    I'd like to install an OBA (CKMA12) under the hood on the passenger side close to the firewall. In my 3rd gen TRD OF (DCSB), I don't have any components there but I have two threaded holes in the fender side and 3 threaded holds below (straight down).
    I have searched this forum for different build threads or install threads the might list the size of the bolts used to mount things into these points (maybe I suck at the TW search). I know there is a bracket I can buy that fits this area (single or twin compressor), but at $125, I'd prefer to see what I can fashion myself.
    Several threads mention putting a rubber gasket or rubber feet between the compressor and the mount (which sounds like a good idea) and others mention fashioning their mount out of polycarbonate from Lowe's/Home Depot, but I didn't see anything about the hardware used to mount these home-grown brackets.
    Thoughts? I'm heading out Sunday on a trip and I'll have the compressor tomorrow so I'd like to try and squeeze in the install on Friday/Saturday if I can figure this out fairly easily.
    BlueRidgeFly likes this.
  2. Apr 26, 2017 at 9:16 AM
    Nail
    Nail Well-Known Member
    NH
    2017 OR
    I know the two threaded bolt holes on the drivers side over the wheel well (right behind the battery ground) are M8-1.25 x 30. If those look close to the holes you are talking about then I bet they are the same size.
    Joe23 likes this.
  3. Apr 26, 2017 at 9:22 AM
    vtstouff
    Richmond, VA
    Exactly! Thanks!
  4. Apr 26, 2017 at 9:24 AM
    vtstouff
    Richmond, VA
    Sorry I didn't have pics to make it more clear but I'm traveling. I'll add pics when I get home in case others have a similar question.
  5. Apr 26, 2017 at 10:20 AM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    They are not the same as the driver side. I believe they were M6 when i checked.
  6. Apr 26, 2017 at 10:45 AM
    Simpleton
    Orange County
    2017 DCSBOR
    None as of yet
    Confirmed.
    M8 x 1.25 on driver side.
    M6 x 1.0 on passenger
  7. Apr 26, 2017 at 10:46 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Those things have helped me out numerous times.
  8. Apr 26, 2017 at 11:12 AM
    Simpleton
    Orange County
    2017 DCSBOR
    None as of yet
    Saves you from a real headache almost every time.
  9. Apr 26, 2017 at 10:29 PM
    vtstouff
    Richmond, VA
    Yes, I tried the M8 on the passenger side when I got home and it didn't fit so I grabbed an old M6 x 1.0 to try and that 1.0 seemed incorrect. But it could have been paint or something in there. I definitely wasn't trying to force it since I didn't have that handy ring of thread sizes. Thanks to you all!
  10. Apr 27, 2017 at 9:31 AM
    Simpleton
    Orange County
    2017 DCSBOR
    None as of yet
    When I put the M8 on the driver side for a fuse panel one was fighting me too, it was just paint. Either clean it out with a tap if you have one or just run the bolt through slowly to do the dirty work.
  11. Apr 27, 2017 at 9:34 AM
    vtstouff
    Richmond, VA
    Purchased. Very handy.
    tomwil[QUOTED] and Simpleton like this.
  12. Apr 27, 2017 at 6:39 PM
    LS14ME2
    LS14ME2 Kind of a big deal
    In hiding, CA
    2017 SSM Sport DCSB 4x4
    Center console divider thingy, rubber bed mat and side steps for the wife.
    Curious, what are those holes on each side for?
  13. Apr 27, 2017 at 6:56 PM
    Simpleton
    Orange County
    2017 DCSBOR
    None as of yet
    Fuse Block and on board air :thumbsup:
    soundman98 likes this.
  14. Apr 27, 2017 at 6:57 PM
    LS14ME2
    In hiding, CA
    Thanks, for what model or application?
  15. Apr 27, 2017 at 7:21 PM
    vtstouff
    Richmond, VA
    Funny, after spending time looking in there today, I couldn't help wonder the same thing. On the passenger side down below those fender mount points, I have 3 threaded M8 bolts pointing up, two on the high side by the air filter mounts and another set an inch or so lower about 6 inches closer to the passenger firewall. A local fabricator is making me a mount for the CKMA12 on those 3 posts instead for a more sturdy position (but its lower in the engine compartment... potential hot air being drawn into the compressor air intake).
    I was wondering to myself what else would go there in another trim package that isn't in the TRD Off Road. A friend has a 2016 Limited so I was going to look in there next chance I get.
  16. Nov 11, 2017 at 5:51 PM
    88tacos
    88tacos Member
    2008 red dbl cab trd sport
    Is it the same for 2nd gen?
  17. Nov 11, 2017 at 6:35 PM
    Simpleton
    Orange County
    2017 DCSBOR
    None as of yet
    I believe so, not much as changed in the little details between generations.
    88tacos[QUOTED] likes this.
  18. Apr 10, 2021 at 3:33 PM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    In the non- OR/TRD PRO that is where the ABS/TC system lives..
    schmack b likes this.
  19. Apr 10, 2021 at 3:36 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    How did you end up here?
    StreetsTheWay likes this.
  20. May 30, 2021 at 1:20 PM
    StreetsTheWay
    StreetsTheWay Well-Known Member
    Justin
    Alberta, Canada
    2020 Tacoma TRD Offroad, Cement Grey
    @Scott17818 Learned me something new anyways...
    I needed the threaded hole details for a Fuse/Relay panel mount I'm working on.
