Boom there goes 4wd, thanks Toyota for frame swap problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueT, Feb 10, 2016.
  1. Feb 10, 2016 at 7:05 PM
    BlueT
    BlueT [OP] Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    So came back home, turn on 4wd, light flashed couple times, than weird noise and no more light.
    Now turning 4wd, or 2wd and no action.
    luckily I have another truck so I spend almost an hour trying to drag Tacoma up the hill.
    Since frame swap was done I have nothing but F... problems...
    Thanks Toyota for turning perfectly good truck into shitbox.
    EDIT Looks like Toyota busted my diff so need to start colelcting list of part numbers
    RING, SHAFT SNAP (FOR DIFFERENTIAL SIDE GEAR SHAFT RH)
    90520-41014 INNER 1
    90520-75002 OUTER1
    SEAL, OIL (FOR DIFFERENTIAL SIDE GEAR SHAFT) (for some unknown reason two are listed for out trucks so dont know which one I need Type B or A)
    90311-47013 RH, PNC 41101A=TYPE B 1 ( 07 specific ?)
    90311-47021 RH, PNC 41101A=TYPE A 1
    BEARING (FOR FRONT DIFFERNTIAL SIDE GEAR SHAFT RH) (for some unknown reason two are listed for out trucks so dont know which one I need Type B or A)
    90363-43001 PNC 41101A=TYPE B 1
    90363-T0014 PNC 41101A=TYPE A 1 (this is J made for 07)
  2. Feb 10, 2016 at 7:29 PM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    So........ are you asking a question, or is this like those times like when my wife complains about something but doesn't really want a solution to it? Then gets mad when I suggest a solution? Y'know?
    ... I'm scared.
    LTDSC, Mtnflyer, Sterdog and 19 others like this.
  3. Feb 10, 2016 at 7:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  4. Feb 10, 2016 at 11:12 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    That was an entertaining read, reminds me of an episode of South Park where Butters is being treated for multiple personality disorder but the therapist is the one that has it.
    So Blue, you headed off to the Chevy dealership once Toyota fixes your 4wd problem?
  5. Feb 10, 2016 at 11:14 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    You're welcome
  6. Feb 10, 2016 at 11:23 PM
    BMWags
    BMWags Well-Known Member
    Brent
    2012 Ford Raptor
    Time for a 3rd gen
  7. Feb 10, 2016 at 11:57 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Yep, and BlueT will fit right in with the typical 3rd gen forum poster too!
    Mtnflyer likes this.
  8. Feb 11, 2016 at 1:56 AM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    Hellooooooooooooo minivan engine!
    Fenwick1993 likes this.
  9. Feb 11, 2016 at 2:46 AM
    sander1036
    sander1036 Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    a.s. likes this.
  10. Feb 11, 2016 at 5:10 AM
    BlueT
    NorthEast
    No F way, I would rather buy GM....
    Toyota is not going to fix this if they knew how to fix this, they would not cause the problem in the first place. Chevy maybe in my future because I dont think this problem is fixable with out disassembling good portion of truck to find where exactly this is failing.
  11. Feb 11, 2016 at 5:12 AM
    BlueT
    NorthEast
    I wish it was that easy.
    When they swapped my frame they must have pinched one of the wires. So now system works intermittently and when it stops you need to pull 4wd fuse to reset computer.
    Good luck to anybody of finding pinched wire.
    If system stop workign would be easy but with intermittent issue, this is not going to be possible to solve, and with out dependable 4wd this truck is useless to me.
  12. Feb 11, 2016 at 5:51 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you are something else, chuckles
    1) must be a pinched wire
    OK so you KNOW THIS ?
    2) Good luck to anybody of finding pinched wire.
    OK, SO YOU DON'T KNOW A DAMN THING ABOUT IT.
    WE GOT IT
  13. Feb 11, 2016 at 6:14 AM
    BlueT
    NorthEast
    I know this is a wiring problem, because the same thing happened before (right after they gave me truck back). I checked everything, even got the amperage reading from the 4wd computer while system was engaging and disengaging. There is nothing wrong with system itself (add or Transfer case), its one of the wires somewhere.
    They did not open any of that, but they had to disconnect and unplug all the harness connections. remove the wiring to add and transfer case from the frame. So yeah finding where wire is pinched its going to be impossible.
  14. Feb 11, 2016 at 6:15 AM
    JeffreyB
    Jeff
    Yeah I have to agree you are jumping awfully far to conclusions. Even if it is a pinched wire, believe it or not they do actually know where that wire runs. It's not like they built it and forgot to write down where stuff is.
  15. Feb 11, 2016 at 6:50 AM
    BlueT
    NorthEast
    I am not saying they don't know where the wire is, just saying to find out where they pinched wire is going to be a massive task.
    ADD wire is part of main harness, so it would be cheaper to buy new truck than swap that again.
    Not that I expected any less problems after something like frame swap.
  16. Feb 11, 2016 at 6:59 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Have you even contacted the Dealer, or the local zone office about this issue?
    DustStorm4x4 likes this.
  17. Feb 11, 2016 at 7:17 AM
    4myTaco
    4myTaco SmaSh it Up
    Lucas
    Plainfield, IL
    06 DCLB Sport
    OME 3" lift up Front, LR UCA's, All-Pro Expo leafs in back, 17" XD Addicts with 285/70/17s, OEM Roof Rack, Westin Light Bar, Relentless Tailgate plate, Weathertech's, Blue Sea Fuse Box, Iggy's Switch Holder, Pioneer avh-3300bt Radio, LED Interior/License Plate Lights
    This is the one thing I am really afraid of when getting my frame swapped, an issue popping up that they will either say wasn't caused by the replacement or something they cant' figure out. My dealer has been fantastic so far, but the only thing they have done is keep upgrading my rental when I go in to resign the agreement. The treal test will be when the work actually starts. Did your dealer try to charge you anything extra for the swap for BS things?
  18. Feb 11, 2016 at 7:21 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    WTF, no diesel?
  19. Feb 11, 2016 at 7:24 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    How come you would rather bitch about your truck, instead of taking the thing to the dealer that did the work?
    abarber11, robssol, Mtnflyer and 4 others like this.
  20. Feb 11, 2016 at 7:27 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Yeah what kirk said.
    I would be bringing it back to the dealer since they did the swap.
    robssol and Rock Lobster like this.
