Boom there goes 4wd, thanks Toyota for frame swap problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueT, Feb 10, 2016.
  1. Feb 11, 2016 at 9:28 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I thought you didn't need 4WD because you're running the super singles???
    archerm3 likes this.
  2. Feb 11, 2016 at 10:42 AM
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Ill give you 1k for it, its useless to you right?
  3. Feb 11, 2016 at 10:47 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
  4. Feb 11, 2016 at 12:34 PM
    BlueT
    BlueT [OP] Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Meh this is crazy ,,, just got quote for obscene amount of money by dealer... apparently something that is a problem after swap is not always covered...
  5. Feb 11, 2016 at 12:35 PM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    So what's the issue?
  6. Feb 11, 2016 at 12:41 PM
    BlueT
    NorthEast
    Apparently front differential is toasted on pass side (mystery how it happened, and its coincidence that happened after frame swap). But they are not sure about mysterious 4wd on/off behavior. However for cool almost $3000 grand I can get new front diff that may fix both.
    :D
    For that much money I can get guys to install Solid axle on the front and never again deal with this shit... I would not have to touch much, and I have solid axle just for that..
    Well I did not expect anything else.
  7. Feb 11, 2016 at 12:44 PM
    TacoTaco15
    Jake
    VA
    They're recommending that you replace your front differential because of a crimped wire somewhere?
    Also, what exactly do you mean by 'toasted'? I'm not sure what that means.
    I also don't really see how swapping out a frame could 'toast' a differential.
    Sugar Silva likes this.
  8. Feb 11, 2016 at 12:50 PM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    Always remember when dealing with the stealership:
    R0dzilla75, JeffreyB and uurx like this.
  9. Feb 11, 2016 at 1:23 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    Always remember when dealing with Blue T
    Fitz235, vssman and TacomaMike37 like this.
  10. Feb 11, 2016 at 2:52 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Take it to a indie mechanic who knows 4 wheel drives.
    Let them check the diff bet they tell you something different.
  11. Feb 11, 2016 at 2:59 PM
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    Another reason to be glad I don't live in the north
  12. Feb 11, 2016 at 3:02 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I think someone is smoking dope. I feel i'm not getting the full story.
    Sterdog and tacoparadise like this.
  13. Feb 11, 2016 at 3:14 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    He left the parking brake is on. That's my guess.
    Rock Lobster likes this.
  14. Feb 11, 2016 at 3:21 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    None of this makes any sense. So Toyota swaps the frame, the 4x4 stops working, and now your front diff is "toast"? I'm thinking YOU screwed something up and just don't want to tell us because you're embarrassed.
  15. Feb 11, 2016 at 3:24 PM
    #35
    BlackTaco1014
    BlackTaco1014 Well-Known Member
    Take it to the dealer. Yell. Truck gets fixed.
    /Thread
  16. Feb 11, 2016 at 4:53 PM
    #36
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    I must have gotten lucky. I took mine in for the swap about 2-3 weeks ago. They knew I needed a truck for work, and handed me a 2016 Tacoma 4 WD and said this should work. I had them do a clutch job, and also in the process of doing my swap they found a couple items that needed some attention that they did at no charge. It took nine days to get back, no big deal, and the day we got it back I put 200 miles on it after leaving the shop. Checked and made sure the ADD worked, 4 High
    and Low, worked great. Since then I have a couple thousand trouble free miles. I also expected some minor issues, but the mechanic that did the swap was very professional and thorough, and did an excellent job. I understand some folks are uneasy about having it done, but at this point after doing so many of them, I believe these guys have it down to a science and know what issues to be on the lookout for before returning a truck.
  17. Feb 11, 2016 at 4:55 PM
    #37
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    There is really nowhere a wire can get pinched.
    What is toasted in the front passenger side diff?.... CV joint? Bearing? There is not much going on in there... it's just axles and bearings.
    tacoparadise likes this.
  18. Feb 11, 2016 at 4:57 PM
    #38
    koditten
    Kirk
    Central Michigan
    Seriously? You have an ass load of posts on how these trucks work and you think the the dealer fucked up your diffy?
    A bad connection is not going to screw up the Diffy. Something mechanical was bad to begin with.
    How about posting something positive? You got skills, find the issue and post how you fixed it
    Otherwise, trade the fucker in, lose your ass on trade in because the front Diffy no longer locks and by something else.
    Nice knowing you, but go be someone else's drama queen.
    Sterdog, archerm3 and TacoTaco15 like this.
  19. Feb 11, 2016 at 5:18 PM
    #39
    File IFR
    Central MA
    If it's a wire issue, it is very likely the suspect wire going into the connector is compromised. I'd believe that long before the 'pinched wire' theory.
    Where wires terminate into the connector and fail, they can be re-crimped with new male/female connectors. A complete wire harness replacement is insane.
  20. Feb 11, 2016 at 5:19 PM
    #40
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Every time I drive by the Toyota dealership my parking brake comes on. Conspiracy or aliens?
