Boost Gauge!
Discussion in 'Performance and Tuning' started by WOODEX M.E., Jul 22, 2013.
  1. Sep 18, 2016 at 1:13 AM
    #101
    IdRatherBNTheSanJuans
    IdRatherBNTheSanJuans Well-Known Member
    Coe
    05 TRD Sport 4x4 DCLB
    Kings. JBAs. AllPro standards. Mastercraft CXT 255/85r16s
    I know this is an old thread, but was wondering if I could get some details on gauge size, series, mounting pod? I really like the looks of what the O.P. did, and would like some place to start with SpeedHut.
    Thanks All!
  2. Sep 18, 2016 at 1:25 AM
    #102
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Look here, deside what size u want, and use that to choose the rught gauge size i guess?
    http://www.cravenspeed.com/the-flexpod-gauge-mount-toyota/
  3. Sep 18, 2016 at 1:35 AM
    #103
    Coe
    That does help narrow it down, thanks!
    inwood customs likes this.
  4. Sep 18, 2016 at 1:41 AM
    #104
    inwood customs
    Dave
    I dont know specifics of OPs gauge, but maybe its in the pages somewhere.
    Erryones diffrent anyhow.
  5. Sep 18, 2016 at 12:28 PM
    #105
    WOODEX M.E.
    WOODEX M.E. [OP] Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I purchased the 2-1/16" gauge options. I think the gauge series was Revolution. And as posted a little earlier i used the craven speed pods.
    IdRatherBNTheSanJuans likes this.
  6. Sep 19, 2016 at 5:25 AM
    #106
    Coe
    Thanks OP!
  7. Sep 19, 2016 at 4:51 PM
    #107
    WOODEX M.E.
    Corey
    Maine
    No problem, glad to see that this thread still gets some attention. I remember doing a lot of research when i first did this and now it makes it a lot easier for others.
  8. Oct 12, 2016 at 8:51 PM
    #108
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    @WOODEX M.E.
    Hey bud, we've discussed your gauges before at length, but after various life events including buying a house, I am finally getting around to buying boost and AFR gauges.
    My question is how are these SpeedHut gauges holding up? Any issues? Happy with the FlexPod? Anything you'd do different second time around?
  9. Oct 13, 2016 at 9:58 AM
    #109
    WOODEX M.E.
    Corey
    Maine
    They are holding up well. I have not had a single problem with them since installing them. One thing I would have changed is the FlexPod (make a modification to it). It doesn't have anything to actually hold the gauges in, so I just wrapped black electrical tape around the gauge housing and pressed them into the pods. If you do it right they wont move. I do wish that the AFR gauge had a built in control module like some other gauges, that way you wouldn't have to have a separate module and have to figure out how that all works. I had to use the PLX module and locate it in that funny little bin to the right of my steering wheel.
    Now that the work is all done I enjoy them a lot, I just wish someone had done it before me so I didn't spend so much time trying to learn what I needed.
    Biscuits likes this.
  10. Oct 13, 2016 at 10:42 AM
    #110
    Biscuits
    Thank you very much for your feedback, Woodex.
    Just so that I understand you correctly: should I choose the PLX AFR control module, I cannot daisy chain it along with another gauge (e.g. Boost). I would have to buy a separate control module for whatever other gauge I installed.
  11. Oct 13, 2016 at 2:51 PM
    #111
    WOODEX M.E.
    Corey
    Maine
    Well the boost gauge doesnt need to be hooked up to anything to function other than its transducer and power cables. So it itself is already set. You can pull power from the same place with any other gauges, but the problem is that with the Speedhut gauges you need the signal from the sensor to be altered for the gauge to read, hence why i have te PLX unit to condition the signal and then send to the gauge. I dont know of any other way to do this, but im sure there are some. Some other branded gauges have that conditioner built in so you power the gauge and it just plugs the sensor into it.
    As far as i know. Theyre are many options, i just know that this one works wothout any headaches.
    Biscuits[QUOTED] likes this.
  12. Jan 6, 2017 at 4:17 PM
    #112
    Biscuits
    @WOODEX M.E.
    I finally got my gauges in after a month and a half of waiting!
    I also finally fully understand what you're referring to in the quoted message above. I'm looking at the mess of everything and scratching my head.
    I have the SpeedHut boost and AFR gauges and their PLX counterparts. The AFR is fairly straightforward, but the boost is unexpectedly confounding me.
  13. Jan 7, 2017 at 6:14 AM
    #113
    WOODEX M.E.
    Corey
    Maine
    The boost gauge itself, i dont think i had to buy anything else for, im pretty sure it came with everything needed to operate. You hook it up to power like any gauge but then you run it to the supplied pressure transducer. No need for the plx unit on the boost gauge, unlss you want to daisy chain them and data log.
    Want to take a picture of all the stuff you have?
  14. Jan 7, 2017 at 10:50 AM
    #114
    Biscuits
    Hey man, I figured it out last night. I didn't use the PLX module as it meant disassembling the Molex connector of the boost gauge wiring harness because the connections on the PLX module and harness were incompatible, among other things. So I ended up routing the vacuum hose through the passenger-side plug on the firewall to the left of that large harness, like you did. From inside the cab, I ran the hose to the pressure sensor, zip tied that critter secure, and ran the harness to the driver's side near the steering column. I still need to install the AFR gauge today. After actually doing this and not just reading about it, I have more confidence with what I'm doing, and a lot of what you've told me now makes sense. Thank you very much for all your help! :)
    If you want, read more about my "adventure" here.
  15. Jan 7, 2017 at 12:21 PM
    #115
    WOODEX M.E.
    Corey
    Maine
    Sweet news! Glad its starting to come together.
  16. Jul 30, 2017 at 9:12 AM
    #116
    WorldWar546
    WorldWar546 Baja Member
    Anthon
    Utah
    TRD Charged '14 Black TX Baja
    TRD Supercharger And a lot of rice n chrome
    Hey what size of guage/gauge pod did you go with? I have 60mm guage pos from Craven Speed and was hopping I can run these gauges!
  17. Jul 30, 2017 at 12:43 PM
    #117
    WOODEX M.E.
    Corey
    Maine
    I ordered the 2-1/16" gauges. They don't fit tight in the craven speed pods so i wrapped electrical tape around the gauges as a sleeve untill the correct thickness. It holds thim in the pods with no movement like that. I believe i have heard of others doing the same ting.
    jojotoo and WorldWar546[QUOTED] like this.
  18. Jul 30, 2017 at 5:29 PM
    #118
    WorldWar546
    Anthon
    Utah
    Thanks!!! Now I need to order a Boost and a Wideband!!
  19. Jul 31, 2017 at 3:25 PM
    #119
    WOODEX M.E.
    Corey
    Maine
    Just a hint, i was on their site yesterday and saw their new wideband is all one unit, no ned to buy an additional control module like i did years ago. Way easier to do ot all now. I racked my h ad for a long time over how to make it all work. I think @Biscuits even had to get a module about a year ago.
    Biscuits and WorldWar546[QUOTED] like this.
  20. Aug 1, 2017 at 12:23 PM
    #120
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I'm having the hardest time finding a 15psi AEM boost gauge, I guess the x-series!!!
    All I see are 35psi +
    WorldWar546 likes this.
