boostedka's Turbo 3RZ Tacoma
Discussion in '1st Gen. Builds (1995-2004)' started by boostedka, Jun 3, 2016.
  1. Apr 20, 2020 at 6:15 AM
    #481
    boostedka
    boostedka [OP] Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    @Bhz2rz
    Those are the throttle body coolant lines. You can do one of two things with them...1. You can delete both of them and cap off the hard line behind the intake manifold where they originate or 2. You can just replace the one that runs through the EGR valve so that I goes directly from the throttle body to that hard line and leave the other line in place as well. This will allow the coolant to still pass through the throttle body. I've done this both ways. The first way will make the truck idle a little odd for a while until the ECU adjusts to no coolant going through the TB. With the 2nd way, the truck will idle completely normal right away on the first start up.
    Let me know if you have any other questions
  2. Apr 20, 2020 at 7:54 AM
    #482
    Bhz2rz
    Bhz2rz Member
    Toyota Tacoma 2rz
    Do you have any pictures that can guide me? I just wanna be sure where exactly to put them. I want to do it the second way so I don't have any Idling problems. BTW Thank you so much for your help man.
  3. Apr 20, 2020 at 9:00 AM
    #483
    boostedka
    James
    NM
    Here's a pic of when I capped them off on this black truck on the hard line I mentioned. This will at least give you an idea of where these lines connect to at the back of the engine bay. You can do this without removing the manifold like I did, there's just a lot less room to do so.
    If you want to still have coolant going through the TB, you can leave on the line that runs straight to this from the TB (I don't remember if it's the upper or lower one). Then just get a new line from a local parts store to also run directly from the TB to the hardline to replace the two piece line that runs through the EGR valve. I don't have any pictures of that from my reg cab truck I did that to.
  4. Apr 20, 2020 at 9:13 AM
    #484
    boostedka
    James
    NM
    If I was to do this on another 2/3rz motor, I would leave coolant going through the TB. Seemed like the truck just ran better that way and I'd worry long term about one of those caps cracking or something causing a huge coolant leak.
  5. Apr 20, 2020 at 10:16 AM
    #485
    Bhz2rz
    Bhz2rz Member
    Toyota Tacoma 2rz
    Yes it sounds that it's be best idea. I really appreciate your help. I will try to do it the same way
  6. Apr 20, 2020 at 11:13 AM
    #486
    boostedka
    James
    NM
    No problem. LMK if you any other questions.
    Torspd likes this.
  7. Apr 23, 2020 at 8:30 PM
    #487
    Bhz2rz
    Bhz2rz Member
    Toyota Tacoma 2rz
    Hey man, I got it done but I don't know what to do with the two little hoses now and I have 3 inlets what am I supposed to do there?
  8. Apr 24, 2020 at 5:30 AM
    #488
    boostedka
    James
    NM
    Can you post a picture of what you're referring to?
  9. May 12, 2021 at 6:17 AM
    #489
    Awsome57
    Awsome57 Well-Known Member
    Kevin
    Hey, Boostedka you run that taco with the egr delete sense 2017 and have had no check engine codes for the egr because you connected a resistor in line?
  10. May 12, 2021 at 8:46 AM
    #490
    boostedka
    James
    NM
    Yeah man, no issues at all. I did it to another 3rz that was a '99 with 200k+ miles and had the same positive result.
  11. May 12, 2021 at 8:53 AM
    #491
    Awsome57
    Kevin
    yeah I keep getting a lean code p0171 and I replaced all the o2 sensors cleaned MAF and all new exhaust from cat back including cats so I was thinking on replacing the intake manifold gaskets and deleting the egr and add headers I have a 2003 tacoma v6 with 150k miles on it. Do you think that is a good step to take?
  12. May 12, 2021 at 12:39 PM
    #492
    boostedka
    James
    NM
    First thing I would do is pull the intake manifold off and clean out all the carbon build up inside of it. You'd be surprised how much is in there. Try to get the intake ports on the head as clean as possible as well. The easiest and most effective way I've figured out to clean those manifolds is to spray some oven cleaner inside of it, let it soak, then spray it out with a pressure washer. Then, if you can while the manifold is off, either get your injectors cleaned or buy a new set. You can usually find the pink tops on ebay for around $100. Many times tacomas run lean because all the carbon build up plugs the injectors and intake ports.
    Also, one other problem could be your valve clearance. 3rz's are supposed to have this checked and adjusted every 80-100k miles. This makes a decent difference in how the truck runs and also can cause certain CELs to pop up if left out of spec.
  13. May 13, 2021 at 5:47 PM
    #493
    rybern
    rybern Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    I can confirm that you know what you are talking about. I pulled my intake at around 300K to reveal that there was a TON of buildup in the intake runners.... I likely had close to 50% blockage. I also replaced the OEM injectors with Ebay pink tops and my truck has been great and I'm at 346K miles. :thumbsup:
    boostedka[QUOTED][OP] likes this.
  14. May 14, 2021 at 1:04 PM
    #494
    boostedka
    James
    NM
    I remember that now! I'm happy to hear it's still running well for you.
  15. May 14, 2021 at 5:02 PM
    #495
    rybern
    N Alabama
    Posting this for the OP. Pics worth a thousand words. I believe my truck runs like it did when it was new after cleaning out the intake runners and replacing the injectors.
    This was on my 3rz at around 296K.
    Here's the intake/exhaust for #3 and #4.
    The worst was #4.:eek:
    Here's #1 and 2 after cleaning
    Here's #3 and 4 after cleaning
    Here's the thread if you want to read through it.
    https://www.tacomaworld.com/threads/chasing-the-2200-rpm-ping-2-7.494905/
  16. May 14, 2021 at 6:11 PM
    #496
    boostedka
    James
    NM
    Holy shnikies! That was some serious carbon build-up! Gotta be some kind of record.
    Just out of curiosity, have you ever messed with the valve clearance on your heads?
  17. May 14, 2021 at 6:51 PM
    #497
    rybern
    N Alabama
    Checking the valve lash at around 290K. It wasn't out all that much. Here is the link where I addressed this. Being a machinist, I was able to alter the existing shims on a surface grinder. Anyone could do the same if they carefully labeled each shim like I did and have them ground to a specific dimension by a local shop. I'd be willing to help if needed for a nominal fee.
    https://www.tacomaworld.com/threads/valve-lash-results-290k-miles.495565/
  18. May 14, 2021 at 7:00 PM
    #498
    rybern
    N Alabama
    I edited post #495 to show before and after pics of carbon build up in ports.
    boostedka[OP] likes this.
  19. Jun 27, 2023 at 10:00 PM
    #499
    davidgfcxc
    davidgfcxc New Member
    David
    2002 regular cab 4wd 3rz taco
    @boostedka
    Just finished reading this thread from beginning to end.
    I'm planning on creating a similar setup on a stock ECU to what you ran on your turbo 3rz.
    Quick couple questions for you.
    I assume I need a bigger fuel pump to hit around the same numbers as you ran? Do you think a Walbro 250 would work?
    Will I be able to run a stock ECU with the 440cc injectors you recommended earlier? Looks like these might be the right ones?
    https://www.ebay.com/itm/204326732137
    Is there a big incentive to use these injectors over the stock ones I have with a stock ECU? I have a 2002 4wd Tacoma with the 3rz, and from what I understand, it should have the pink-top injectors from the factory.
    I can't imagine my injectors are all that bad, considering my truck is sitting at only 110k miles.
    Thanks for the response,
    David
    boostedka[OP], GoJo and Brake Weight like this.
  20. Jun 28, 2023 at 7:07 AM
    #500
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I would personally stick with the stock injectors if not going standalone ECU or any sort of way to electronically mitigate fuel trims.
    If you thought this was a decently long and informative read, check this thread as well: https://www.tacomaworld.com/threads/turbo-bs-thread.481844/
    GoJo likes this.
