Boot Slide Mod - Tutorial?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChoyotaIII, Jun 26, 2018.
  1. Jun 26, 2018 at 10:46 AM
    ChoyotaIII
    ChoyotaIII [OP] Someone took "Choyota"
    Echo
    Placentia, CA
    2012 Spruce Mica + 2018 MGM
    Boot Slide Mod - Tutorial? A comprehensive one for the inners? I'm finding stuff online and on this forum, but things seem a little unclear. Where can I find parts, what tools I need, etc.
  2. Jun 26, 2018 at 10:50 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    To do it the "right" way is a little involved. You have to remove the CV, partially disassemble it, slide on a new boot, and add a dissected boot on there to keep it from sliding back. It's really not worth it unless you already have a torn boot.
    What I did was just snip the inner small clamp and slide it down a little bit, and use a hose clamp to hold it in place. Works well. Just don't slide it down TOO much or you risk tearing the boot when you go full droop.
    chadabear likes this.
  3. Jun 26, 2018 at 12:42 PM
    ChoyotaIII
    Echo
    Placentia, CA
    Hmm. That sounds good. No need for diff drop right?
  4. Jun 26, 2018 at 12:44 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The diff drop barely helps any, so I wouldn't bother with it. If you want to slide them down, just snip off and slide down juuuust enough so the fins aren't touching at ride height, maybe 1/2" or so.
  5. Jan 17, 2019 at 9:17 PM
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Which hose clamps to buy if I wanted to do this? Was thinking OEM unless not worth it
  6. Jan 17, 2019 at 9:23 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    You’ll need a crimp tool also to use them.
    I bought oem bc the dealer is close and I knew they’d fit. That said, I ended up using one regular hose clamp which seems to be working fine.
  7. Jan 17, 2019 at 9:24 PM
    ejewels
    CT
    Crimp tool to install the OEM clamp? And what’s the easiest way to get old ones off? Hoping it’s not messy.
  8. Jan 17, 2019 at 9:31 PM
    Rujack
    Yep. I got one on Amazon for like $18. Think it was this one: https://www.amazon.com/dp/B00K0TOYJE/ref=cm_sw_r_cp_api_i_nuwqCbDW3FPSQ
    Cut the old ones with tin snips or good large wire cutters.
    Edit: make sure you don’t knick the boots.
    Taco_Sam_96 and ejewels[QUOTED] like this.
