Bootleg Budget DIY Ram Mounting
Discussion in 'Canada' started by WestCoastMango, Feb 19, 2021.
  1. Feb 19, 2021 at 6:51 PM
    WestCoastMango
    WestCoastMango [OP] Well-Known Member
    Anthony
    Vancouver Island
    2019 DCSB
    Howdy!
    Made a cheap DIY ram track system that's been working extremely well. Most systems that are shipped to canada I found were to be $150+. No drilling required and seems to be able to withstand offroading.
    The 3M tape seems to be doing its job with no issues for 3 months now.
    Parts: RAM Mount 12 inch End-Loading Composite Tough-Track
    https://www.gpscity.ca/ram-mount-12-inch-end-loading-composite-tough-track
    : Scotch(R) Heavy Duty Mounting Tape, 1 Inch x 125 Inches
    https://www.amazon.ca/Scotch-Heavy-Duty-Mounting-Inches/dp/B00347A8GC
    Pretty straight forward Install. When adhering the mounting tape, I recommend using rubbing alcohol to clean the top surface for better adhesion as well as a c clamp or any type of clamp to hold down the tough track to the mounting tape.
    ODSC1 and bigmw like this.
  2. Feb 20, 2021 at 10:07 AM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    Good idea! I have a piece of the aluminum tough-track that I was going to mount in a similar position. Do you have your track mounted on the outer piece or in the space behind it? Any more pics?
  3. Feb 20, 2021 at 3:59 PM
    WestCoastMango
    Anthony
    Vancouver Island
    2019 DCSB
    Got it mounted to the outter lip. You planning to drill into the moulding or you plan to use the Scotch 3M tape?
  4. Feb 20, 2021 at 7:52 PM
    ODSC1
    London ON
    2017 DCSB Sport MT
    I was planning on drilling the part behind the outer lip. I could do the tape and a few screws though. Is your setup strong enough you think to hold a tablet?
  5. Feb 20, 2021 at 8:03 PM
    WestCoastMango
    Anthony
    Vancouver Island
    2019 DCSB
    So far it held a phone and my baofeng radio. Tablet, I'd probably want to drill in.
  6. Feb 20, 2021 at 8:04 PM
    ODSC1
    London ON
    2017 DCSB Sport MT
    Ok. Good to know. Thanks!
