*****BORA WHEEL SPACERS up to 25% discount*****
Discussion in 'Group Buys' started by lj973gm, Apr 23, 2012.
Thread Status:
Not open for further replies.
  1. May 31, 2012 at 9:16 AM
    #221
    hondarider215
    hondarider215 Well-Known Member
    Wes
    Socal
    KR Tacoma
    KR Fabrication front and rear bumper ICON 2.5 c/o's All pro leafs Maxtrac Fox rear resi shocks Lr uca 17" methods
    I think your right.
  2. May 31, 2012 at 9:46 AM
    #222
    munkel
    munkel fka unregistered lurker...
    PDX
    2004 Dbl Cab V6 4WD Tacoma
    Icon Suspension, 285/75/16 BFG MT's, Steeeckers, Custom Bed Mounted Tool Storage, Wilderness Trail rack, SoftTopper, K&N CAI, Hella Aux lights, PIAA Fogs, Warn M8000, Elite Front Bumper, BAMF sliders, All-Pro leafs and shackles
    would something like work for the BORA spacers? I can't remember if there was room for a ET nut like this. I am referring to the last item, the ET lug nuts.
  3. May 31, 2012 at 10:29 AM
    #223
    munkel
    PDX
    Can anyone look at a uninstalled spacer and confirm if a ET lug nut would fit in the hole? Much appreciated.
  4. May 31, 2012 at 10:46 AM
    #224
    hondarider215
    Wes
    Socal
    KR Tacoma
    That looks like it would work. It states it for the short factory studs. Interested if anyone has these to test
  5. May 31, 2012 at 11:08 AM
    #225
    munkel
    PDX
    damn, I called the vendor and they couldn't tell me if the ET lug nuts would work or not. They didn't know if there was room around the stud for a ET nut to fit down in there. If someone has a set sitting around of these and could stack two on top of each other and look down through the hole and see if there is room around the stud I would appreciate it.
  6. May 31, 2012 at 11:12 AM
    #226
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    it should fit, no reason it wouldnt. try putting the wheel spacers on the wheel with the lugs sticking through. rotate the spacers. if there is room for the spacers to move around with the lugs sticking thru them, then there is room for the extended shanks on the ET lug nuts.
  7. May 31, 2012 at 11:15 AM
    #227
    munkel
    PDX
    Exactly, only problem is that mine are installed and I am at work and can't pull my wheel apart right now and check. :) I would love to go pick up a set but only if they are going to work.
    Stacking two spacers with the lugs fed through the holes will answer this as well. If you can rotate it a bit then a ET lug nut should work.
  8. May 31, 2012 at 1:33 PM
    #228
    motorsporttech
    motorsporttech Member
    Hey Mike,
    An ET lugnut will sit in the spacers.. There is room for the shank of the ET lugnut to go inside the lug hole of the spacer. I know that the Factory Tacoma Studs are really short to begin with so you dont get many turns on the lugnuts but you will be fine without the ET lugnuts. If you feel better about running the ET lugnuts you can, but you will have to get the Open End ET lugnuts and depending on how tall the lugnut is they will not sit flush inside the spacers... Especially the .750" and 1.00" spacers. I dont think they will sit inside the spacers. Let me know if you have any other questions. Thanks
  9. May 31, 2012 at 1:38 PM
    #229
    motorsporttech
    Aaron, We shipped your set out on the 5/25, UPS sent you an email to your email address with the tracking number... You should have them Tomorow
    Thanks
  10. May 31, 2012 at 1:54 PM
    #230
    munkel
    PDX
    :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup: Thank you for the post and for the adapters, much appreciated!
  11. May 31, 2012 at 2:26 PM
    #231
    Heckler2008
    Heckler2008 Member
  12. May 31, 2012 at 2:32 PM
    #232
    blackhawke88
    SGV, CA
    07 TRD Offroad
  13. May 31, 2012 at 4:22 PM
    #233
    Heckler2008
    Heckler2008 Member
    I was hoping that was the reason, because I ordered 3/4 spacers so factory studs should work.
  14. May 31, 2012 at 4:57 PM
    #234
    Appljaxx
    Appljaxx This guy
    Jeremy
    Albuquerque, NM
    '18 TRD Pro
    I have one set of 4 (1" black) spacers from this group buy i am not going to use. 150.00 Shipped. They are new I haven't even opened the box yet. pm me
  15. May 31, 2012 at 5:06 PM
    #235
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    PM sent
    CC
  16. May 31, 2012 at 11:13 PM
    #236
    blackhawke88
    SGV, CA
    07 TRD Offroad
    so more than one of the lugs are seriously not the same length as the other, and one of the lug nuts seize on one of the lugs. I emailed the vendor for a replacement spacer.
  17. Jun 1, 2012 at 1:19 AM
    #237
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Really, that blows...Gotta check mine as they won't be going on for sometime.
  18. Jun 1, 2012 at 11:16 PM
    #238
    BuckWells
    BuckWells Well-Known Member
    Aaron
    Wichita, Kansas
    06 TRD Offroad
    painted badges, sockmonkey decals, CHLM, bed light mod, 20% tint, color match grille
    spacers arrived today. they look great. i'll install them tomorrow with updates on fitment. 1.25"
  19. Jun 2, 2012 at 2:18 PM
    #239
    jimmyk4d5
    jimmyk4d5 Well-Known Member
    Jim
    Alto ,MI
    TRD SPORT DOUBLE CAB (SPRUCE MICA)
    well i got my 1.5" spacers yesterday, and started installing them today. i see exactly what you guys are talking about with the lug nuts not going on very deep on the lug. i am getting the extended lug nuts for piece of mind. it didn't sit well in my head those nuts not covering much of the threads. for a few bucks i will feel better and more confident .it probably wouldnt matter so much with the thinner spacers.
    are you with me??????LOL...
  20. Jun 2, 2012 at 2:37 PM
    #240
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Installed my front 1.25 spacers yesterday. Fit awesome, complete thread engagement on all studs, and the 55-65 mph shake I had with my old 1.5 lug centric spacers went away with them.
Thread Status:
