Bottoming out after 49,000 miles! Anyone else?
Discussion in 'Suspension' started by nvtaco, Feb 6, 2012.
  1. Feb 6, 2012 at 8:07 PM
    nvtaco
    nvtaco [OP] Well-Known Member
    Vancouver, BC
    07 Double Cap TRD Sport
    Vent visors, backup lights, the loadhandler!
    '07 double cab trd sport, only 49,000 miles, bottoming out in the rear all the time now at say 10mph over a speed hump (not bump), bottom out.
    1 adult, 3 kids, bottom out over all sorts of potholes, driveways.
    Would it be my rear springs or shocks (or both) that may be shot.
    Anyone else experience this?
    I use it as a truck hauling lawnmowers, grass, leaves, brush, and towed a travel trailer with a weight dist. hitch for approx 15k of its life.
    Have you fixed this problem and if so how? Thanks
  2. Feb 6, 2012 at 8:19 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    There is a TSB for the rear leaf pack. Check the Sticky in the second Gen. section.
  3. Feb 6, 2012 at 8:29 PM
    nvtaco
    Vancouver, BC
    Thanks, I forgot to mention I am a Canadian taco and have the (4 I think) leafs.
  4. Feb 6, 2012 at 8:31 PM
    nvtaco
    Vancouver, BC
    Were you able to fix it with another spring option or just live with it?
  5. Feb 6, 2012 at 8:31 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    There is the option of an AAL, too. That would assist with hauling and towing.
  6. Feb 6, 2012 at 8:32 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Yup, me too! Just under 50k
  7. Feb 6, 2012 at 8:33 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    I'm not saying it would be covered. Just answering the question of other people having the same issue. Obviously, they have.
  8. Feb 6, 2012 at 8:34 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    my single cab does it. i had an acura 4cyl motor in the bed of my truck 350lbs max and my truck would bottom out over small dips in the road.. im just gonna replace shocks with bilsteins 5100's and the AAL, call it a day. just under 50k on my truck
  9. Feb 6, 2012 at 8:34 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    oh yeah i have 60k and my rear end bottoms out all the time! mostly offroad tho and very harshly
  10. Feb 6, 2012 at 8:38 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    How bad is this for the rest of the truck? I got some superbumps from wheelers and it at least makes it tolerable! But.......it can't be good for the rear of the truck, frame etc!
  11. Feb 6, 2012 at 8:39 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    I didn't bother with the TSB. Went with OME set up instead. Bottoming out is definitely an issue with these trucks. It's up to you how far you need or want to take the suspension.
  12. Feb 6, 2012 at 8:52 PM
    nvtaco
    Vancouver, BC
    Did you go OME Dakar springs along with the OME shock or just Dakars and 5100s? I dont mind doing a mild lift replacing the front shocks, coils and rear stuff. Are you happy with it?
  13. Feb 6, 2012 at 8:53 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Complete OME with Dakars.
  14. Feb 6, 2012 at 8:54 PM
    nvtaco
    Vancouver, BC
    That was exactly my thought as well. When I bottom out, I am wondering what will be totally stressed out next:eek:
  15. Feb 6, 2012 at 8:56 PM
    nvtaco
    Vancouver, BC
    Did you have this setup when you were hauling the hay in one of your pictures? Thats a fair bit of weight and the backend doesn't look bad at all! If thats the case I think I have made my decision to replace :)
  16. Feb 6, 2012 at 8:57 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Get a full leaf pack to eliminate this problem. It might cost you ~$500 but is well worth it.
  17. Feb 6, 2012 at 8:58 PM
    nvtaco
    Vancouver, BC
    Thanks and good looking truck, I have not seen a short box single cab before, me likey!
  18. Feb 6, 2012 at 8:59 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Heh, no. That was actually with my stock three leaf pack. I was quite surprised, more than twenty bales in there. Dakars would look even better!
  19. Feb 6, 2012 at 9:07 PM
    nvtaco
    Vancouver, BC
    So how would you rate the ride now, empty with the dakars?
    Progressive with good give, jarring?
  20. Feb 6, 2012 at 9:26 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
