Bought My First! Preferred Plugs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mrenniks, Dec 11, 2011.
  1. Dec 11, 2011 at 5:22 PM
    mrenniks
    mrenniks [OP] Member
    Matthew
    Charlottesville
    99 Tacoma 2.4L SR5
    Hello all, I just bought my first Toyota taco. I drove a 160 miles from my home in Virginia to buy a '99 Tacoma 2WD 4cyl 5speed extended cab with only 63,000 miles on it! Love it so far and it is running great...
    What I want to know is what most people prefer to use or have found works best in these trucks out of all the types of spark plugs there are? Or should I just use what the manual says?
    Mine has the the 2RZ-FE engine if that makes a difference.
  2. Dec 11, 2011 at 5:23 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    welcome to the site! 63k, good score, enjoy the taco:D
  3. Dec 11, 2011 at 5:24 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    stock oem plugs ....
  4. Dec 11, 2011 at 5:25 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    I've used stock plugs from the dealership, worked fine. Welcome and nice find.
  5. Dec 11, 2011 at 5:33 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    I'm running E3 plugs, seems to idle a bit smoother, but that may just be me thinking too hard about it.
  6. Dec 11, 2011 at 5:44 PM
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    I'm running ngk laser iridium plugs runs smooth
  7. Dec 11, 2011 at 7:09 PM
    crainholio
    crainholio Well-Known Member
    Plain ones from the dealership if you don't mind changing them every 30K miles or so...Denso Iridiums (or NGK Iridiums presumably, haven't tried them) if you prefer to go longer between changes.
    I use Denso Iridiums because I pile on over 30K miles per year and don't want to change plugs that frequently.
  8. Dec 11, 2011 at 7:15 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    oem plugs......IMHO they put them in there for a reason
  9. Dec 11, 2011 at 7:38 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    NGK or Denso
  10. Dec 11, 2011 at 10:34 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  11. Dec 15, 2011 at 3:46 PM
    Phearson
    Phearson Taco or Die
    Brad
    Gresham OR
    1996 SR5 Tacoma. 33x10.5 Kevlar 3in lift
    Kinda like.. Should i run higher quality gas? Its not always gonna make your truck better. I would stick with OEM. I run it.
    But then agion. Everyone has there own liking and im not a Mechanic. Im Desiel :D
  12. Dec 16, 2011 at 10:16 PM
    1998tacomaowner
    1998tacomaowner Well-Known Member
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    umm just got plugs today from dealer they say denso right on them
    denso or ngk will be just fine cause all i ever ran in toyotas was ngk cause thats what i was told will run best
  13. Dec 17, 2011 at 9:59 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    So, from what I understand, you run OEM sparkplugs ina diesel...Interesting... :spy:
  14. Dec 17, 2011 at 10:10 AM
    Phearson
    Brad
    Gresham OR
    Yeah and i put lighter fluid in the gas... RUNS LIKE A CHAMP!
    No im saying im not a mechanic. But i am a Desiel Mechanic. Wasnt trained in gas cars
  15. Dec 18, 2011 at 10:18 AM
    hard2kill
    Rhinebeck NY
    lmao......i miss my duramax
  16. Dec 18, 2011 at 8:10 PM
    1998tacomaowner
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    im not a mechanic either im an electrician but i dident think desiels had spark plugs i thought they had glow plugs hmm
    anyways dealer is going to sell denso but ngk will run fine
