Bought used LR UCAs. Came w 4 washers per UCA?
Discussion in 'Suspension' started by schleygo, Jul 18, 2012.
  1. Jul 18, 2012 at 8:57 AM
    schleygo
    schleygo [OP] Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    I watched the vid here
    http://www.spc-tv.com/install/lt-suv/69-25470-toyota-tacoma-upper-control-arms.html
    I read the instructions on the same webpage. Plus I searched this website.
    http://www.tacomaworld.com/forum/suspension/137537-light-racing-uca-install-3.html
    Question. I bought my LR UCAs used on fleabay. Each UCA came w 4 washers. Do I need to install a washer on each side of where the bolt goes thru the frame of the truck? The stock UCAs just had the large washers on the outside where you tighten the UCA down. Do I just reuse the 2 large washers that came off the stock UCA?
    I got the truck torn down now and stuck. Thanks
  2. Jul 18, 2012 at 9:13 AM
    schleygo
    Daniel
    Ft Worth TX
    It appears that there is space for 2 washers on the inner part of the UCA.
    I can not find any info on washers being used on both sides of the UCA during install
  3. Jul 18, 2012 at 9:16 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Read the directions again, it's all in there.
  4. Jul 18, 2012 at 9:21 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    LR comes with 4 for each side, one on each side of each mounting location. OP, make sure you tighten the bolts down with the truck loaded up on the UCA's otherwise you will blow the bushings.
  5. Jul 18, 2012 at 9:22 AM
    98tacoma27
    Ben
    Not Beech Creek
  6. Jul 18, 2012 at 9:23 AM
    schleygo
    Daniel
    Ft Worth TX
    Copy.
    Ok. I will use all 4 washers for the LR UCA.........and dont tighten completely until uca has a load on it.
    Thanks
  7. Jul 18, 2012 at 9:23 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
  8. Jul 19, 2012 at 10:22 AM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Read the very last sentence in parentheses in instruction #7 on the pdf linked...
  9. Jul 19, 2012 at 10:38 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    Interesting. That because they are using the new SpecRide bushings?
  10. Jul 19, 2012 at 10:43 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I do believe that changed with the new bushings , yes
  11. Jul 19, 2012 at 10:43 AM
    OZ-T
    Peter North
    British Columbia
    This is true if they have the old bushings
  12. Jul 19, 2012 at 10:44 AM
    JonnyBb
    Arkansas
    Your bushings still holding up?
  13. Jul 19, 2012 at 12:23 PM
    OZ-T
    Peter North
    British Columbia
    Seem to be fine so far
