Bought Used... Please HELP ID these upgrades.
Discussion in 'Suspension' started by 8200rpm, Aug 13, 2011.
  1. Aug 13, 2011 at 9:16 PM
    8200rpm
    8200rpm [OP] Member
    10 DCSB 4X4 TRD OR
    Icon E/T Coilovers, Camburg UCA, ARB OME Dakar Leafs, ARB OME Nitrocharger Sport, TRD CAI, TRD Exhaust
    Hello all,
    I recently purchased a used 2010 Tacoma DCSB 4x4 w/ TRD OR from a dealership. The truck has several modifications that the previous owner added. I went in expecting to buy a completely stock, off road capable truck, and was surprised to see all the upgrades. Truck was lightly used and competitively priced so I pulled the trigger.
    I'm new to 4x4's and embarrassingly do not know any details on these upgrades. Here are some pics...
    Front coilovers and UCA. Brand is obvious but which models?
    Rear reservoir shocks. Completely unmarked. What brand/model are these? Performance wise, are the stainless steel lines of any significance than rubber hoses?
    Rear leaf springs. Only 3 leafs per side? Is this normal? I think these are original, non-TSB leafs.
    If you can provide any input/opinions/suggestions, I'd really appreciate it.
    When I compared it to a coworker's Access cab TRD OR, my truck is ~3" higher.
    Are these worthwhile upgrades? Should I have any concerns? Anything I should know about in terms of extra maintenance or things I should watch out for?
    Thanks for your input.
  2. Aug 13, 2011 at 9:24 PM
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    2008 4Runner 4x4 Sport
    Camburg ucls and icon coil overs are top of the line. Check out wheelersoffroad.com or toytec.com and you can see what you saved by buying a car with all of those goodies installed already. WELCOME TO TACOMA WORlD!!!!! Cant id the rear shocks.
  3. Aug 13, 2011 at 9:26 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Those are the original US stock rear leafs
  4. Aug 13, 2011 at 9:41 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    7100's in the rear maybe?
  5. Aug 13, 2011 at 9:42 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Rear shocks appear to be Icons as well, judging by the design of the reservoir mounting bracket. $1500 worth of shocks and $700 upper control arms. Not bad. :proposetoast: Now either get the rear leaf TSB or put in add-a-leafs, so you can get rid of that silly axle spacer.
  6. Aug 13, 2011 at 9:42 PM
    OZ-T
    Peter North
    British Columbia
    Looks like a rear block too
  7. Aug 13, 2011 at 9:43 PM
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    Great pics man. How about one of the whole truck?
  8. Aug 13, 2011 at 9:43 PM
    MattDubs
    MattDubs Well-Known Member
    St. Augustine, FL
    6" Procomp
    you scored bro.
  9. Aug 13, 2011 at 9:46 PM
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    That's what im thinking.
  10. Aug 13, 2011 at 9:55 PM
    JTaco386
    JTaco386 Well-Known Member
    JT
    San Antonio, TX
    13 DCSB TRD Sport 4x4
    x2
  11. Aug 13, 2011 at 10:34 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
  12. Aug 13, 2011 at 10:46 PM
    8200rpm
    8200rpm [OP] Member
    10 DCSB 4X4 TRD OR
    Thanks. Shot everything using a Canon SD1300 on Macro.
    Can't believe I did not take a pic of the whole truck. :facepalm: It just looks like a factory Magnetic Gray Metallic DCSB w/ TRD OR.
    Previous owner installed one of these...
    Previous owner also had a Flowmaster welded in place of the stock muffler. Bit loud for me. So today, I rolled around on the ground and installed one of these... (TRD Cat Back PT910-89061)
    Sounds much better.:D
  13. Aug 13, 2011 at 10:50 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    CO
    2011 Mall Crawler/84'
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Lucky, looks like Icon shocks in the rear.
  14. Aug 13, 2011 at 10:51 PM
    OZ-T
    Peter North
    British Columbia
    Am I the only person that see's a block in the rear ?
  15. Aug 13, 2011 at 10:52 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Nice truck
  16. Aug 13, 2011 at 10:57 PM
    medic2230
    Murph
    Bama! Roll Tide
    I'm seeing the same thing. Your talking about the space you see in the pic between the axle and the spring, right? Looks like it has blocks in there.
  17. Aug 13, 2011 at 11:03 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    All of those shocks and stuff are worthless. Put the oem ones back on....but instead of throwing them away give them to me :spy:
    Lucky score! whoever had the truck knew what they were doing...
    Just grab a new leaf pack and you'll have a fully built truck that makes me jelly.
  18. Aug 13, 2011 at 11:17 PM
    8200rpm
    8200rpm [OP] Member
    10 DCSB 4X4 TRD OR
    Is it good or bad? Opinions are more than welcome.
    I'm completely ignorant, so more input the better. Thanks.
  19. Aug 13, 2011 at 11:19 PM
    OZ-T
    Peter North
    British Columbia
    Bad
    Get rid of the block and get an AAL or a new leaf pack .
  20. Aug 13, 2011 at 11:27 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    They wear out your leafs a lot quicker than if you had an added leaf, or a new leaf pack providing lift. They also give a worse ride than the abeforementioned mods.
