Bouncy Toy after installing new suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by Torryota, Jul 22, 2011.
  1. Jul 22, 2011 at 12:51 PM
    Torryota
    Torryota [OP] Member
    Torrance
    Eibach/Bilstein 5100, K&N Air Filter
    Hey, first time poster here. I have a 95.5 Taco Single cab. I've been lurking around the forum a bit and bought the 3" Eibach Spring/Bilstein 5100 shock setup from Toytec that's so often recommended around here. In the rear are 2" AAL. Installed the Diff drop too.
    Well, after leaving the shop, I noticed a significant front end bounce, which is quite annoying and somewhat sketchy. I was wondering if this is normal, or if the bounciness may go away after a while. I returned to the shop and the guys said I might need stiffer front springs. Has anyone else with this setup experienced this problem?
  2. Jul 22, 2011 at 12:55 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Bouncy as in stiff bouncing or soft bouncing? Stiffer springs wouldnt be a good idea if it already has a stiff bounce. After my 5100's and 886's were installed, the ride was stiffer then stock if that helps any.:cool:
  3. Jul 22, 2011 at 12:56 PM
    98tacoma27
    Ben
    Not Beech Creek
    Were the billy's set at 0" (stock setting)?
  4. Jul 22, 2011 at 1:01 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I'm guessing it's a stiff bounce since eibachs have a high spring rate. I bet it will get less and less intense with time, I still have a bounce with my set up (5100/883) but it doesn't happen too often, only when im going >20 with big slope changes
  5. Jul 22, 2011 at 1:02 PM
    Torryota
    Torrance
    Its a pretty stiff bouncing, it kinda seem more like the shocks aren't providing enough dampening
  6. Jul 22, 2011 at 1:05 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Where are the billys set at?
  7. Jul 22, 2011 at 1:05 PM
    Torryota
    Torrance
    They weren't changed from how they came in the box, (with the clamp ring in the top groove) but that might have been the highest setting? Is the 0" setting the lowest groove?
  8. Jul 22, 2011 at 1:09 PM
    98tacoma27
    Ben
    Not Beech Creek
    And there's your problem. You now have approxiamately 5.5" of lift. The seat should be on the very bottom ring towards the lower control arm.
  9. Jul 22, 2011 at 1:10 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yes, 0" should be at the very bottom where it isnt compressing the spring to give a lift. Mine are also set at 0" cause the springs are what give the lift, not the shock.
  10. Jul 22, 2011 at 1:12 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Wow if thats the case, something def will get f'ed up!!!:eek::eek:
  11. Jul 22, 2011 at 1:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    It should be on the bottom ring in the pic on the left. Only you will have just three rings.
  12. Jul 22, 2011 at 1:14 PM
    malander
    max
    01 limited trd 4x4
    I think something will get fucked up regardless..I didn't read the single can part. IMO eibachs shouldn't be use on single cabs unless there's quite a bit of weight up front.
  13. Jul 22, 2011 at 1:21 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    If you can, try and take some pics of the front suspension and your cv boots.
  14. Jul 22, 2011 at 1:38 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Oh man you need to go back and get that clip moved down the lowest setting. Your UCA's are probably maxed out right now that's why it feels so bouncy not to mention you have the springs preloaded like crazy.
  15. Jul 22, 2011 at 2:22 PM
    Torryota
    Torrance
    No its not that high. It's about the same height as before with 2"spacers, and the uca.s aren't maxed out, but I'm going back to the shop right now.
  16. Jul 22, 2011 at 2:25 PM
    JLee
    Jerry
    Benicia, CA
    Then there is something else wrong because I have about 1 1/2" of down travel at the bump stop and I'm a 0
  17. Jul 22, 2011 at 2:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    And make sure the perch isn't upside down.
  18. Jul 22, 2011 at 2:57 PM
    Torryota
    Torrance
    Right now the truck is sitting pretty level. If I move the clip down will it drop the nose a bunch?
  19. Jul 22, 2011 at 3:02 PM
    98tacoma27
    Ben
    Not Beech Creek
    You know for a fact that the clip is on the top notch?
  20. Jul 22, 2011 at 3:15 PM
    scocar
    scocar hypotenoper
    Post a pic so we can see the setting and the perch.
    The perches should be on this way, and you should be able to see to whole grooves above the perch.
