Bouncy Toy after installing new suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by Torryota, Jul 22, 2011.
  1. Jul 22, 2011 at 3:18 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The Toytec Eibach coils give over 3" of lift how much lift did you put in the back? you might have the spring perches upside down.
  2. Jul 22, 2011 at 3:21 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Like everyone else said, post a pic of your setup so we can see what's up.
    My 5100/toytec combo was installed with the 5100s set to the top setting, and the ride was exactly how you describe yours is.
  3. Jul 22, 2011 at 3:46 PM
    Torryota
    Torryota [OP] Member
    Torrance
    Eibach/Bilstein 5100, K&N Air Filter
    OK Here are some photos
    As you can see, the truck is up a little in the front, but other than that its pretty level. I should clarify that the rear AAL are actually 2.5" on paper, and the truck originally had a a 2.5" leveling kit in the front, and it sagged a little in the rear to begin with.
    Pic #2 shows the left UCA as its stands right now. It is stretched a bit, but its about the same as when it had the leveling kit.
    Pic #3 shows the whole assembly from behind. The shocks are set at the highest setting.
    Pic #4 shows the gap between the bump stop and the frame, about 2.5"
    The shop said they'll reset the front shocks for free, my question is whether to take it down to the stock setting or perhaps just the middle setting, so that the front end stays fairly level with the rear. I imagine dropping it down even one notch should help the ride.
  4. Jul 22, 2011 at 3:50 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Yep. In the last picture you can see the grooves for the 5100s, and you have yours set at the top setting. As of now, you're probably getting 6 inches of lift in the front- take it back and get it fixed ASAP so that you don't kill your UCAs and cvs
    Edit: us 1st gen guys can't use the eibach/toytec coils with the 5100s set to anything but stock, or it gives tooooo much lift. Have the shop set it to the stock bottom setting and the ride will improve 1000000000x
  5. Jul 22, 2011 at 3:50 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yep, they're on the wrong setting. You're CV angles are BAD. It actually looks a tad nose high to me. You could measure from hub center to fender on both the front and rear to see if it is in fact higher.
    YOU DEFINITELY NEED TO GET THEM RESET ASAP.
  6. Jul 22, 2011 at 3:51 PM
    98tacoma27
    Ben
    Not Beech Creek
    And get it realigned. They should do all of this for free since they f-ed it up to begin with.
  7. Jul 22, 2011 at 4:03 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    This too.
    (I typed fast cause I knew someone was gonna try and get at it first :D )
  8. Jul 22, 2011 at 4:04 PM
    Torryota
    Torrance
    couple more photos, and thanks for the advice guys
    Pic#1 from the front, I don't think its got 6" of lift, but maybe 4", maybe you guys can tell from the pic.
    Pic #2 Closeup of the perch.
    Pic #3 Closeup of the UCA joint, she is squeezed pretty good. I pointed it out to the shop and they said it wasn't anything serious. Perhaps they are idiots. The CV's aren't too bad, no worse than they were before with the leveling kit, probably because of the diff drop.
    I'm gonna take it back in on monday, until then I'm gonna avoid driving it. Aside from the potential damage to the UCA's and CV joints, could there have been any damage to the spings and shocks themselves from being in this position?
  9. Jul 22, 2011 at 4:08 PM
    98tacoma27
    Ben
    Not Beech Creek
    Your geometry is way off and your parts are severely stressed. When you take it to get fixed, avoid the highway (if possible), avoid sharp cornering, and avoid any and all bumps you can.
  10. Jul 22, 2011 at 4:09 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Shouldn't be, unless you take it offroading... Mine ended up being undamaged (thankfully)
    The coils give a little over 3 inches without a plate bumper...me and Jlee both got around 3.5 inches at first- but you have that AND the extra 2.5 from the shock settings
  11. Jul 22, 2011 at 4:11 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    dang dude get that lowered asap, thats how my cvs look without the diff drop. and i have the same set up as you, but on the lowest setting. ill take some pics for you
  12. Jul 22, 2011 at 4:13 PM
    Torryota
    Torrance
    Once again, thanks for the advice guys. I feel like a retard. I guess I thought the shocks would come in the stock setting, and maybe the shop didn't know any better. I should have mentioned something to them about it. Oh well, hopefully nothing is fucked up. TBH when I bought the truck it already had the leveling kit installed and the front end was more toed in than it is now. It also rode like shit before, with a really jarring ride. Now it rides smoother but bouncier, if that makes any sense. Anyways, yeah the shop will adjust the height for free, and i'm gonna get it aligned afterward. I just hope the front end doesn't drop too low, or else I might have to change out the rear AAL too :(
  13. Jul 22, 2011 at 4:15 PM
    97yota4wd
    Eric
    Mesa, AZ
    its okay dude everyone makes mistakes and you live and learn.
    and yeah the ass end will be a litle higher, you could think aout a back bumper. or maybe a spare tire rack in the rear, it will help alot.:)
  14. Jul 22, 2011 at 4:23 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Same thing happened to me. And the shop that did the install for me the first time seemed to know their stuff...the guy's eyes lit up when I started naming off all of the parts that I was putting on my truck so I thought I was in good hands. Wrong.
    They ended up messing up the front end and underestimated the time they needed to do the install so they kept my truck overnight. Then after all the waiting and it was wrong?!?! :annoyed: And they refused to fix it without charging me so I walked out the door and over to another shop. The guys there reinstalled the front shocks and redid my alignment...they ended up charging me like $100 which was much less than the original shop wanted to fix their own mistake! In the end the 2nd shop won out as I made my tire purchase through them 6 months later.
  15. Jul 22, 2011 at 4:25 PM
    #35
    98tacoma27
    Ben
    Not Beech Creek
    I'm surprised you didn't roshombo them.
  16. Jul 22, 2011 at 4:25 PM
    #36
    Konaborne
    Cody
    Kealakekua, Hawaii
    A tiny bit of rear rake never hurt nobody! It's actually what I was trying to go for, but the eibach's leveled it out...You'll love the ride compared to spacers once the bounce goes away, it's literally night and day!
    And don't feel bad. I made the same mistake a while back.... These pics were from a thread exactly like this one...
    (when my baby was still a baby :D)
  17. Jul 22, 2011 at 4:27 PM
    #37
    MTgirl
    Weesa
    It was close :D but they were on the other side of the counter and it was a bit higher then i can jump so....
  18. Jul 22, 2011 at 4:28 PM
    #38
    98tacoma27
    Ben
    Not Beech Creek
    *said in swanky British accent*
    Amateur
  19. Jul 22, 2011 at 4:33 PM
    #39
    MTgirl
    Weesa
    here's my wrong install
    and the right way...
    FWIW - I went from 35.5" (ground to top of fender on the stock setup) to 39.5" with the 5100's in the high setting and then down to 37.5" on zero.
  20. Jul 22, 2011 at 4:54 PM
    #40
    scocar
    scocar hypotenoper
    You need Rock Stars and a monster decal for your hood.
