Box Rocket - 2003 TRD Doublecab
Discussion in '1st Gen. Builds (1995-2004)' started by Box Rocket, Oct 8, 2010.
  1. Jun 11, 2014 at 8:42 PM
    #2541
    Box Rocket
    Box Rocket [OP] Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I'm sure we can work something out if you are interested. As long as you don't mind that one of the fenders has a big hole in it for a snorkel. Maybe we can figure out a package deal and you can get the snorkel too. I might be selling it too.
    I did LOTS of hammering to the firewall. Probably as much as you can without just tubbing. I'm on the fence about tubbing. It's possible that I might just do it later this summer when I have a few weeks off of work. That way I won't have to worry about it ever again. I also did quite a bit of cutting too. Cut the flares, bent the lower part of the fender a bit, cut the fender liner. Pinch weld is gone.
  2. Jun 11, 2014 at 9:01 PM
    #2542
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Don't mean to jack haha chad has first dibs but I've been looking for a snorkel and if you already have the fender with the whole that would be a big plus. Let me know :D
  3. Jun 11, 2014 at 10:12 PM
    #2543
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Hmmm ok. Thanks. I'm going to finish off the front tomorrow night. Found some (a lot) more fender to trim... If it's not too much trouble, I'd love to see a pic of this area from your taco - I know I'm overthinking this but the cutting and bashing is new for me.
  4. Jun 11, 2014 at 10:14 PM
    #2544
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    lol
  5. Jun 12, 2014 at 9:14 AM
    #2545
    Box Rocket
    Adam
    Syracuse, Utah
    Sure thing. When Chad speaks up we'll see where it goes.
    I haven't actually cut much of the fender itself. Some of the bottom edges have been bent/folded back and hammered a little but I didn't actually cut any sheet metal. I did cut some sheet metal on the rear fenders.
    Confused. Why is that funny?
  6. Jun 12, 2014 at 9:20 AM
    #2546
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    after all of the "its just not worth the work" comments and discussion
    "I might just tub it this summer"
  7. Jun 12, 2014 at 9:31 AM
    #2547
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
  8. Jun 12, 2014 at 10:06 AM
    #2548
    Box Rocket
    Adam
    Syracuse, Utah
    That was in regards to fitting 35's. Tubbing has it's place for sure. My point was that the jump from 33s to 35's isn't worth all the extra work if you don't have to, because 35's alone don't offer that much benefit over 33's. But that's a different discussion.
    And if I tub my truck this summer it will be because I'm bored and want a project to fill my time. I've been working 80+ hour weeks since March and once this project is done I'll have a few weeks of "comp time". I don't currently have any plans while I'm off so I'm sure I'll drum up some truck stuff to fil my time. There's isn't much I "need" to do to the truck so it will just be doing crap for the hell of it. Tubbing would be one of those things.
  9. Jun 12, 2014 at 11:04 AM
    #2549
    johnboyTRD
    South SF bay
    Interesting. I found a lot to cut - I'm all over the fender and firewall when stuffed and turning. You're making me nervous that I'm cutting too much haha.
  10. Jun 12, 2014 at 11:11 AM
    #2550
    Box Rocket
    Adam
    Syracuse, Utah
    Don't worry. You're handling it the right way, get the suspension stuffed and the steering cranked and cut where stuff hits.
    Remember I have a 1" body lift too which helps.
  11. Jun 12, 2014 at 11:20 AM
    #2551
    johnboyTRD
    South SF bay
    True dat. Really stoked to test it out next weekend. Will be the gnarliest trail my truck has seen yet.
  12. Jun 12, 2014 at 11:26 AM
    #2552
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Your alignment, mainly caster also affects where you will and won't rub/ how much
  13. Jun 12, 2014 at 4:58 PM
    #2553
    Lurp
    Lurp Well-Known Member
    GA
    2010 Sport
    The best 4dr 1 gen I've seen,killer build brother
  14. Jun 12, 2014 at 4:59 PM
    #2554
    johnboyTRD
    South SF bay
    Yeah, next time I get an alignment done I'll look into that. Really I should prob get one sooner than later - done quite a bit of rear lifting since the last one.
  15. Jun 14, 2014 at 11:48 AM
    #2555
    Box Rocket
    Adam
    Syracuse, Utah
    Stopped in at Low Range Offroad this morning. Left with a couple items I'm excited to get installed.
  16. Jun 14, 2014 at 2:05 PM
    #2556
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
  17. Jun 14, 2014 at 3:43 PM
    #2557
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    glad they worked out
  18. Jun 14, 2014 at 3:52 PM
    #2558
    Box Rocket
    Adam
    Syracuse, Utah
    Dude, big thanks for the tip on those fenders!
  19. Jun 14, 2014 at 4:04 PM
    #2559
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    :popcorn:
    Gonna cut a big slot and all to make the snorkel work?
  20. Jun 15, 2014 at 8:30 AM
    #2560
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    :cheers:
