Box Rocket - 2003 TRD Doublecab
Discussion in '1st Gen. Builds (1995-2004)' started by Box Rocket, Oct 8, 2010.
  1. Jun 15, 2014 at 11:18 AM
    #2561
    Box Rocket
    Box Rocket [OP] Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Definitely not that. The snorkel will only happen if I can keep it clean. I might be able to make it work, or I could just have a new tube bent. If it's not clean I'll just rethink how I have my air intake routed and not run a snorkel.
  2. Jun 15, 2014 at 11:24 AM
    #2562
    Box Rocket
    Adam
    Syracuse, Utah
    Got to get the fenders color matched first. #nowhitefenders #noblackfenders
  3. Jun 15, 2014 at 11:27 AM
    #2563
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Hmm, possibly selling the snorkel? :spy:
  4. Jun 15, 2014 at 11:30 AM
    #2564
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well good luck in that project. From what I have found cutting the slot and covering it with some thin UHMW or something is the cleanest way. Be hard to make it super clean though. Hopefully works out
  5. Jun 15, 2014 at 6:43 PM
    #2565
    Box Rocket
    Adam
    Syracuse, Utah
    Clearly you have not seen these pics. A giant slot covered with UHMW is NOT the cleanest way. If that was the best I could do I wouldn't do it. This first link shows it can be done pretty cleanly with a Safari Snorkel. The second link shows it can be done cleanly with a custom bent tube with minimal cutting of the fender.
    Safari Snorkel and 4.5" fenders
    http://www.tacomaworld.com/forum/1s...snorkel-fiberglass-fenders-4.html#post8724816
    Custom tube a 6" fenders
  6. Jun 15, 2014 at 7:41 PM
    #2566
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    so am i just not in the loop or what? but is there any point other than looks to add glass front fenders on a mt equipped truck? I was under the impression it was more aimed towards LT
  7. Jun 15, 2014 at 8:46 PM
    #2567
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I have seen zam15s setup it is nice no doubt. Hopefully works out.
    Just covers the tire more I guess..but really not substantial. Mine didn't really. And sure don't now.
  8. Jun 16, 2014 at 10:08 AM
    #2568
    Box Rocket
    Adam
    Syracuse, Utah
    Serves the same purpose whether you're long travel or mid travel. More clearance in the wheel well opening and covers tires with a wider stance.
  9. Jun 16, 2014 at 11:31 PM
    #2569
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Awesome truck and quite an inspiration to us out here. Subscribed!
  10. Jun 17, 2014 at 7:18 AM
    #2570
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Scuff the rims? If so what grit paper. Any other tips?
  11. Jun 17, 2014 at 7:55 AM
    #2571
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    I used 100 grit on my wheels. Would have used the wire wheel for most of it but couldn't find the darn thing. Keep in mind... Mine are not as flashy (or expensive) as yours, so I just used what I had around :)
  12. Jun 17, 2014 at 8:02 AM
    #2572
    Madjik_Man
    Colorado Front Range
    Scotch Brite red pads work well.
  13. Jun 17, 2014 at 9:20 AM
    #2573
    Box Rocket
    Adam
    Syracuse, Utah
    Just need a surface that the new paint can adhere to. Scotch Brite pads might be enough. 220grit or higher would work too if you're just trying to scuff the original finish. I used a wire wheel only because I was stripping the entire finish off down to bare metal. I doubt there is reason to be that aggressive with your wheels.
  14. Jun 17, 2014 at 10:22 AM
    #2574
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Thanks Dudes
  15. Jun 17, 2014 at 11:31 AM
    #2575
    johnboyTRD
    South SF bay
    Yep I needed to get some crap off the wheels and wanted a bit extra force :) came out real nice though.
  16. Jun 17, 2014 at 12:04 PM
    #2576
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Still on the hunt for some bronze. .
  17. Jun 18, 2014 at 2:30 PM
    #2577
    Box Rocket
    Adam
    Syracuse, Utah
    I need some suggestion for some material to use to make inner fenders after I put on the Glassworks fenders. Any thoughts? I'd rather not leave it all open. Looking for something durable that will look clean
  18. Jun 18, 2014 at 2:32 PM
    #2578
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Get some thin kydex or hdpe and form it with the techniques people use for gun holsters and such.
  19. Jun 18, 2014 at 2:33 PM
    #2579
    zscott
    Zach
    Utah
    Thats more of are rigid material though rather than a flexible rubber type that would be more typical of this type of project.
  20. Jun 18, 2014 at 3:36 PM
    #2580
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Does it have to be flexible? Kydex is supposedly easy to form, I assume you could use a heat gun to shape it. It's lightweight and tough as hell.
    I could swear I saw a post in the last week or something regarding this, I can't remember which thread it was though.:facepalm: The LT guys had a few methods that looked clean.
    In any case, this would be a good place to source the material and compare characteristics and find the one that best suits the need.
    http://www.eplastics.com/
