Box Rocket - 2003 TRD Doublecab
Discussion in '1st Gen. Builds (1995-2004)' started by Box Rocket, Oct 8, 2010.
  1. Aug 25, 2014 at 8:36 AM
    #2801
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Just a few months. .. Just like my fenders
  2. Aug 25, 2014 at 8:54 AM
    #2802
    Box Rocket
    Box Rocket [OP] Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Yeah, what's happening with that? When are you doing your fenders?
    on the topic of the LR arms...I know they've been discussed on here a lot lately about arms that have broken at the weld. I'll admit it's got me a little concerned, however two good friends here locally have been running LR for a long time. One was Kurt at Cruiser Outfitters and another guy that had LOTS of wheeling miles on his including two trips through the Rubicon and neither one of them ever had any issues. So I don't know all the factors that went into the ones that broke, but I'm still feeling good about them. Time will tell. I do have plans to pull them out soon and gusset the eyes similar to how the TC or Camburg arms are gusseted. Should be no worries after that.
  3. Aug 25, 2014 at 8:58 AM
    #2803
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I was about to say. Those breaks have me worried and if I had a welder, that would be my first thing to do. Mine have been running strong since 2011 though so Im hoping there was just a bad batch...
  4. Aug 25, 2014 at 10:20 AM
    #2804
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I contacted spc about the problem. They responded by saying the arms that use 4 washers per side are the arms that they are having problems with. If you have washers on the outside of the arms only. Meaning 2 per arm. Then they are the ones that are ok. If you have 4 washers per side the welds are getting pinched and breaking. If this is what some people still have then spc will send you new washers.
  5. Aug 25, 2014 at 10:30 AM
    #2805
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    If you have 4 washers you also have the old/crap bushings. SPC will replace the entire arm and ball joint with a new pair that has the poly bushings and two washer system.
  6. Aug 25, 2014 at 11:06 AM
    #2806
    Box Rocket
    Adam
    Syracuse, Utah
    Interesting. I got mine used from ponethousand and they have sleeved poly bushings and the only came with 4 washers (2 per arm). Is there another way to tell whether I have arms designed for 2 or 4 washers?
  7. Aug 25, 2014 at 11:17 AM
    #2807
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Sleeved bushings are the old style. Pain in the ass to remove as well, recently just did mine.
  8. Aug 25, 2014 at 11:26 AM
    #2808
    Box Rocket
    Adam
    Syracuse, Utah
    Hmm. the sleeves in the bushings on the ones I got from Paul slide out easily.
  9. Aug 25, 2014 at 11:54 AM
    #2809
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You have the newer revision.
    The original arms used 4 washers per arm (inside and outside washer per bolt hole). SPC swapped over to the newer revision in 2010-2011ish.
    I don't quite buy the SPC statement; plenty of UCA's since the revision. These are manufactured in China btw. Ive been a strong support of LR but know Im not too sure...
  10. Aug 27, 2014 at 4:15 PM
    #2810
    Box Rocket
    Adam
    Syracuse, Utah
    Just sharing an observation now that I've had enough time to confirm it. I was definitely getting better fuel economy with my Safari Snorkel. I was pretty consistently getting somewhere in the 18mpg range when I had my Safari Snorkel. Now that my snorkel has been off for a couple months I'm consistently getting mid 16's. There's no restriction in the intake and it's essentially back to stock configuration using an OEM air filter in the stock air box which is exactly how it was with the snorkel. The only real difference is the intake location and that there is a subtle "ram air" effect with the snorkel.
    So there ya go. The Snorkel increases mpg.
  11. Aug 27, 2014 at 4:17 PM
    #2811
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    I'm buying one. Thanks for helping me justify it to my wife... Jk, but seriously that is an interesting datapoint.
  12. Aug 27, 2014 at 4:31 PM
    #2812
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    I better leave mine on then...
  13. Aug 27, 2014 at 4:40 PM
    #2813
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    its definitely on my bucket list (down at the bottom). After one day of wheeling, my AFE is diiiiiirty
  14. Aug 27, 2014 at 4:43 PM
    #2814
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Drop in or CAI?
  15. Aug 27, 2014 at 5:07 PM
    #2815
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    FIPK = K&N
    He said AFE
  16. Aug 27, 2014 at 5:20 PM
    #2816
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Jesus Christ, let's not get into semantics in Adam's build thread. It was a simple question for Fernando if he had a drop in or an open air cone-style filter (typically referred to as a CAI).
    My whole point was if Ferny had an open air filter element I was going to recommend he get a pre-filter to wrap around the filter like a condom. It's a godsend in dusty environments.
    It's people like you that have turned TW into a shit show for those who are genuinely here to learn and help.
  17. Aug 27, 2014 at 5:33 PM
    #2817
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    My apologies. my attempt at humor was a bit misplaced.
  18. Aug 27, 2014 at 6:06 PM
    #2818
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Sorry guys, didnt mean to stir up a shit storm! :eek:
    Its a drop in. I almost got a cold air (only cuz they sound so badass) but i decided against it since I know eventually I will get a snorkel. I actually wanted to buy Adam's but he already had a waiting list :(
    I have seen those. Those look like they help. but as far as the drop in goes, im not sure what to do. And I havent done the deckplate mod either (dont plan on doing it either)
  19. Aug 27, 2014 at 7:26 PM
    #2819
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    No worries man, you didn't do anything.
    Nothing you can do with a drop in. Honestly I would suggest going back to a OE Toyota paper filter. They do a far better job in filtering particulates. Not washable, but they are cheap enough to just replace twice a year. After scoring the rotors on my supercharger with the shit that passed though my high flow filter, I'm not a fan for offroad vehicles.
  20. Aug 27, 2014 at 9:43 PM
    #2820
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    My .02
    I had a k&n drop in and a cone type filter on my truck. After the 2nd roll when I cracked my intake, I replaced it with a junkyard one that used a paper filter. My old one had all kinds of crap on the inside while the replacement one was still nice and clean. So I need up doing more cleaning on the lower portion of my intake.
