Box Rocket - 2003 TRD Doublecab
Discussion in '1st Gen. Builds (1995-2004)' started by Box Rocket, Oct 8, 2010.
  1. Nov 10, 2014 at 6:38 PM
    #3021
    The_Trail_Yota
    The_Trail_Yota Well-Known Member
    Colorado
    2021 TRD Offroad
    Bells & Whistles
    This is how I ended up storing my rtt in the garage, going to store the rack with a ratchet hoist system and hoist it up to the ceiling, but I still need to weld it together.
  2. Nov 12, 2014 at 9:32 AM
    #3022
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Hahaha !!! I would love to man.... It's just not in the budget right now. What do you figure the investment would be on a RTT that comfortably sleeps 3 ? I've browsed but not looked extensively and I assumed around $1200. Plus I need to invest in a rack for it.
    So maybe in a year or two, I've been slowly knocking out the laundry list of other truck modifications. Allpro UCA's, rear bumper, and dual battery mngmt system all ordered in the past couple weeks. So the RTT will be the last thing left before long.
    Your truck has been a huge inspiration that's kept me on track, especially since I know you do most things with the family in mind, it'll be sad to eventually not see it in anymore postings.
    It's black, you're looking at the backside of the canvas which is kind of white looking
  3. Nov 13, 2014 at 1:37 PM
    #3023
    Brutus
    Brutus Well-Known Member
    Butus
    Baltimore, MD
    2012 Crew Cab Sr5 TRD 4x4
    ticked if you sold the softtopper?
  4. Nov 13, 2014 at 1:46 PM
    #3024
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    No he hasn't
  5. Nov 13, 2014 at 6:22 PM
    #3025
    jonmc897
    jonmc897 Country Boy
    Jon
    Middlebury VT
    03 shorty
    Tailgate LED strip, blackened exhaust , Bilstien 5100's.
    This has got to be one of my favorite trucks here
  6. Nov 13, 2014 at 6:59 PM
    #3026
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Haven't sold yet, probably won't, but we'll see...
  7. Nov 14, 2014 at 3:29 AM
    #3027
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    The nice thing about the Soft Topper is the way it folds up, so even if you don't use it for a long time, it really takes up minimal space in a corner up against a wall somewhere or up in the rafters of your garage
  8. Nov 14, 2014 at 6:00 AM
    #3028
    The_Trail_Yota
    Colorado
    2021 TRD Offroad
    Bells & Whistles
    I love mine, I met the owner of the company here in Boulder by chance on my lunch break a few months ago and he really is a nice guy! Plus the Softopper is hand made right here in Boulder Colorado, can't beat that! :D
  9. Nov 21, 2014 at 10:38 AM
    #3029
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Adam, what would you recommend for shackles to go with OME leaves? I don't want something crazy tall, but I feel the stock length is just too short. Being greaseable is a plus I suppose, but is it really necessary?
  10. Nov 21, 2014 at 1:54 PM
    #3030
    Box Rocket
    Box Rocket [OP] Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    It's hard to really screw up with shackles. they're just a couple of plates so just about any can and will work as long as the shackle bolts will fit your OME bushings. IIRC you're looking for 18mm bolts. The Allpro ones fit, that why I went with those. I'm sure there are other options too, probably Wheelers. Greaseable bolts are definitely nice so you can keep them moving freely as they should.
    If the stock height is too short, I'd got with something 1.5" over stock. Again, that's what the AP ones are.
  11. Nov 21, 2014 at 2:18 PM
    #3031
    johnboyTRD
    South SF bay
    I'll add a little to this... If you're at full weight, I.e. You aren't planning to add any permanent major weight then it is as simple as measuring the f/r and buying shackles that achieve your desired additional rear height.
    As an alternative, Toytec makes shackles that have three settings, 1", 1.5" and 2". Just a fair warning, to use the 1" setting you have to cut the 2" holes off... It's stupid I know. Toytec also sells just a 1" shackle without adjustments. I am personally running the adjustable a at 1" and it is perfect for my setup. You'll need to determine what's best for your rig though, since we are carrying different weights in front and rear.
    Edit: the toytec worked with OME bushings, I had the standard ome greasable a, but needed more height to match the 882 ome coils.
    Second edit... I like your hi lift mount, gj.
  12. Nov 24, 2014 at 11:32 AM
    #3032
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    hey adam, did you like your 10.50 bfg mts? im looking at getting a set in the next little bit. but im torn between the 10.50 and 12.50
  13. Nov 24, 2014 at 11:58 AM
    #3033
    Box Rocket
    Adam
    Syracuse, Utah
    Yep. Liked them a lot. They were better on fuel economy and steering feel was quicker. Did just fine on the trails. The only downside was they caught and followed grooves in the road more than the 12.50s.
    So, yeah I liked them but I like the 12.50s better. That's just my personal opinion and that could be different for everyone. I like the wider footprint, more tire outside the rim to protect the rims from rocks, the heavier steering feel, and the look of the 12.50s.
  14. Nov 24, 2014 at 12:14 PM
    #3034
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    thanks man!
  15. Nov 27, 2014 at 12:02 PM
    #3035
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Do you still have your front sway bar on?
  16. Nov 27, 2014 at 1:16 PM
    #3036
    Box Rocket
    Adam
    Syracuse, Utah
    Nope. Had it off for over a year now.
  17. Nov 27, 2014 at 1:16 PM
    #3037
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Completely different truck but I have the 33 x 10.50 equivalent for my second gen. I have about 25k on mine and would echo everything Adam said. Fuel economy is great, better than with 32 x 11.5 and they do great on all the trails I run. They do seem to grab the edges on the road though.
  18. Nov 29, 2014 at 1:39 PM
    #3038
    Box Rocket
    Adam
    Syracuse, Utah
    Bought a *new* truck yesterday!! So pumped. It's in Colorado so I'll go pick it up in 2 weeks. Then its getting some love. Lots of stuff planned for it, but it's pretty solid as is.
    Specs: 1995 FZJ80 Land Cruiser
    187K miles
    Front/Rear/Center Diff locks
    It currently has a 2.5" lift and some 285's but all of that is coming off and my 5" OME lift and 315's along with front and rear bumpers and sliders from my '93 cruiser will be going on asap.
    Other plans include new Corbeau seats in the front and center rows. Center row will get 2 Corbeau buckets to replace the bench. After that, I need to respray the hood since the clearcoat is peeling. Build a new roofrack and mount a new Autana Ruggedized RTT and it's good to go. Also, I'll probably be getting a new set of KM2s in 315's. The 285's on the truck are brand new so if anyone is looking for some General Grabber AT's that are brand new, let me know.
    New truck
    Here's what it will get from my old cruiser. The rear bumper, lift/tires from this pic
    Front bumper/sliders from this pic
  19. Nov 29, 2014 at 1:47 PM
    #3039
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Great find! Digging the new color!
  20. Nov 29, 2014 at 1:49 PM
    #3040
    johnboyTRD
    South SF bay
    Congrats, looks good. 2 weeks is gonna be a long wait :)
