Box Rocket - 2003 TRD Doublecab
Discussion in '1st Gen. Builds (1995-2004)' started by Box Rocket, Oct 8, 2010.
  1. Mar 6, 2013 at 2:49 PM
    #1061
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    No overtime pay either :(
  2. Mar 6, 2013 at 2:54 PM
    #1062
    Box Rocket
    Box Rocket [OP] Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Nope. I guess the one positive to it is that I'll probably get a little comp time when it's all over with.
    Instead of complaining about it today, I went and bought a new Trasharoo! Sold my Olive Green one since I wanted a black one. Sometimes it's the small things that brighten a day. :)
  3. Mar 6, 2013 at 3:17 PM
    #1063
    Drunknsloth
    Retribution
    South West
    You can say that again!
  4. Mar 9, 2013 at 9:37 AM
    #1064
    Box Rocket
    Adam
    Syracuse, Utah
    Got all of my stuff for my rear shock relocation.
    ubolt flip kit
    Ruffstuff paired shock tabs
    Axle relocation plates
    and one other item........................
    ......GASP! a 1" BL from 4crawler. I will still be trimming a bit for the new tires but this should help a little to reduce the amount of trimming necessary.
  5. Mar 9, 2013 at 9:48 AM
    #1065
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    oh body lifts...
    luckily you make your own armor so you can make adjustments easy enough for any gaps
  6. Mar 9, 2013 at 9:51 AM
    #1066
    Box Rocket
    Adam
    Syracuse, Utah
    Yeah I really don't think the gaps will be noticeable because I kept everything really tight to the body when I built it. But yeah, Some small adjustments shouldn't be hard.
    Only one that might needs some tweaking is the sliders. But that's an easy one, just cut off and reweld higher on the frame plates.
  7. Mar 11, 2013 at 7:29 PM
    #1067
    Drunknsloth
    Retribution
    South West
    Haha you need to go higher and I need to go lower. :D
  8. Mar 11, 2013 at 8:06 PM
    #1068
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Really? You need a body lift for the 33s????
    Shouldn't need that..unless your planning on slapping those 35s on there...
  9. Mar 11, 2013 at 8:11 PM
    #1069
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Thats what I was thinking.
  10. Mar 11, 2013 at 8:13 PM
    #1070
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    You are now a level one bro!
  11. Mar 11, 2013 at 9:08 PM
    #1071
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Pretty soon he will have RBP and Metal Mullisha stickers all over his ride :D:D
    I dont think a 1'' BL will be that noticeable.
  12. Mar 12, 2013 at 9:48 AM
    #1072
    TacoBran
    TacoBran You're Unique, Just Like Everyone Else
    Brandon
    Peoria, AZ
    2023 Double Cab Trail Edition; 03 Double Cab 4x4 TRD SOLD
    2023 Bone stock... 2003 - Icon coilovers, TC UCA, icon shocks w/resi's, deaver leafs - 4x4 swap in progress
    Your already trimming what's the difference to trim more? At least in trimming you will never ever have to worry about your 1" pucks pushing thru your cab.
  13. Mar 12, 2013 at 9:58 AM
    #1073
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    Most body lift pucks from well known manufactures have the same surface area as the stock body mount (usually ~2.5"-3" diameter); therefore, there's no difference from the cab sitting on top of the stock body mount vs. sitting on top of the 1" puck.
    That being the case, why would you worry about the puck pushing through your cab?
  14. Mar 12, 2013 at 11:44 AM
    #1074
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    good point^ bodylifts are very useful when used for the right purpose
  15. Mar 12, 2013 at 12:18 PM
    #1075
    Box Rocket
    Adam
    Syracuse, Utah
    The 4crawler BL has long had the reputation of being the best choice as far as BL go.
    No reason for everyone to get all up in arms over it. It's not even installed yet. I still need to pull my coilovers and stuff the front suspension and see what needs to be trimmed. I'm not rubbing badly as it is but I'm also not looking to do major surgery on it yet.
    More than the suspension the 1" BL will also help with my bumpers. My tailgate makes contact with the top of my rear bumper when the tailgate is open. And the grill makes contact with the top plates of my front bumper when the body flexes. When I built the rear bumper and added the top plates, I purposely built them as tight as I could to the body but over time it has proven to be a little too tight. So the extra inch will give me a little clearance at the bumpers that will be easier than refabbing bumper mounts.
  16. Mar 12, 2013 at 2:29 PM
    #1076
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    Box knows what he's doing guys. After all he is the man. :cool:
  17. Mar 12, 2013 at 6:55 PM
    #1077
    Blackdawg
    Monte
    Wyoming/St. Louis
    Seems like your stuck re fabbing something no matter what id guess..
    Without BL..Have to redo the bumpers it sounds like
    with BL...redo the sliders and rear bed side protection..
  18. Mar 12, 2013 at 6:58 PM
    #1078
    Box Rocket
    Adam
    Syracuse, Utah
    I don't think so. The rear bedsides won't need any rework no matter what. Sliders......well I'll just have to see. But yeah, it is what it is.
    ......but since you hinted at it earlier, one step closer to 35's. ;)
  19. Mar 12, 2013 at 6:59 PM
    #1079
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    your truck with be so stinking sexy with 35's!
  20. Mar 12, 2013 at 7:03 PM
    #1080
    Blackdawg
    Monte
    Wyoming/St. Louis
    :yay:
    i sorta figured thats what the real intention was..haha
    and really you don't think the rear tubes off your bumper will need moved up??
