Brake controller help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by newdles, Aug 23, 2019.
  1. Aug 23, 2019 at 11:31 AM
    newdles
    newdles [OP] Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    maybe I’m missing something but I need to hook up my brake controller and the wiring harness I have doesn’t fit the plugin I found on my 2019 trd off road. Not sure if I’m missing another needed adapter or the one I have is right and I’m just not finding the correct adapter to hook into.
    Here are the pics I have. One of wiring harness I have and the other two are pics of the only two connectors I can find not already hooked to something inside the truck below dash by kick panel.
  2. Aug 23, 2019 at 11:34 AM
    Shellshock
    Iowa
    You don’t have the right harness. The plug you found in the truck is correct
  3. Aug 23, 2019 at 11:37 AM
    newdles
    Achmed
    Any clue which harness is needed? Thanks
  4. Aug 23, 2019 at 11:45 AM
    newdles
    Achmed
  5. Aug 23, 2019 at 11:46 AM
    Shellshock
    Iowa
    shakerhood likes this.
  6. Aug 23, 2019 at 11:49 AM
    newdles
    Achmed
    Thanks sir!
  7. Aug 23, 2019 at 11:50 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    ^^^DONT USE THIS PART, it has been updated to the 3031-P that now includes a white ground cord^^^
    There have been cases of grounding failures in the controller and shorts damaging the harness in the truck:
    https://www.tacomaworld.com/threads/2018-wiring-harness-for-brake-controller.528103/#post-16980804
    Use the model like this one:Tekonsha 3031-P Brake Control Wiring Adapter-2-Plug, Toyota Tacoma 2015-2018 https://www.amazon.com/dp/B0781KTCPT/ref=cm_sw_r_cp_api_i_tydyDbRJV3MBG
    Edit: if you have the older part without the grounding wire, you can also add one yourself to the ground wire on the plug, too.
    Boghog1 likes this.
  8. Aug 23, 2019 at 11:52 AM
    Shellshock
    Iowa
    I’ve run it for 4 years without issue :notsure:
  9. Aug 23, 2019 at 11:57 AM
    OnHartung'sRoad
    Me too, but the damage if the controller fails isn’t worth it. You can modify and protect yours better if you want by tapping in a ground wire to the plug.
  10. Aug 23, 2019 at 12:11 PM
    OnHartung'sRoad
  11. Aug 23, 2019 at 1:06 PM
    newdles
    Achmed
  12. Aug 23, 2019 at 2:47 PM
    OnHartung'sRoad
    It is the 3031-P and is available on the Amazon link above for $17 - two day free shipping with Prime, also.
    Shellshock likes this.
  13. Aug 23, 2019 at 3:25 PM
    newdles
    Achmed
    Yeah coulda shoulda woulda on my part. I knew I had to have it and just kept putting it off. Saw in a post a while back about which one was required and just couldn’t find it again for some reason. Sadly I had to have it today so went to dealership and paid $38.?? Tax and all for it so I could drive a loaded trailer about 500 miles. Lessons learned all the time :) thanks for all the help again!
