Brake Controller Install Help Request
Discussion in 'Towing' started by JsAZ, May 9, 2009.
  1. May 9, 2009 at 12:50 PM
    JsAZ
    JsAZ [OP] Member
    Gilbert, AZ
    09 DC PreRunner TRD Sport
    I'm having trouble identifying the connector to plug my factory brake controller adapter into. I've removed the driver's side kick panel and searched for a connector with nothing attached and didn't find one. The towing bible write up had one close up picture of the connector but didn't give enough context for me to identify it.
    Could someone please help identify where the factory brake controller should be connected?
    Here's a couple of images with my kick panel removed:
    Thanks in advance!
  2. May 10, 2009 at 8:36 AM
    tbmevent01
    tbmevent01 Well-Known Member
    Dean
    LAS VEGAS, NV
    09 TRD Sport DC
    Banks monster exhaust,AFE CAI,debadged,mag light mod,bed mat, ICON 2.5 resi rear,ICON front coilovers,FNW wheels, NITTO Ridge Grapplers,Leer 100XQ,Wet Okole front and rear
    Hi, I just installed a prodigy brake controller in my 09 TRD. It was little difficult to find since mine was zip tied to another wire harness. But, it is tucked in there and it does have the white connector like the 1 in the towing bible pic. Just look carefully at all the harnesses for that open white connector. Also, camping world sells a plug and go adapter for our trucks. I didnt use the bare wire 1 that came with truck. Hope this helps.
  3. May 10, 2009 at 10:27 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    this video is of the sequoia, but it should be similar to the taco
    link
  4. May 11, 2009 at 8:25 PM
    JsAZ
    JsAZ [OP] Member
    Gilbert, AZ
    The video was somewhat helpful, but I still can't find the connector. I'm starting to wonder if I'm just not qualified for this. :(
    I cut the electrical tape around the bundle below just to make sure, but every connector in this bunch is already mated up. Right now I'm convinced that they just forgot to pull mine through to the kick panel, but I know that sounds dumb.
    I'm thinking I'll run down to the dealership and see if one of the service guys can make some sense of what I'm looking at.
  5. May 17, 2009 at 3:08 PM
    tacojim
    tacojim Member
    aus tx
    09 dc sport
    do you know where it is yet. I am having the exact same problem
  6. May 17, 2009 at 3:55 PM
    tacojim
    tacojim Member
    aus tx
    09 dc sport
    the connection is to the left of the parking brake switch behind the largest bundle of wires.
    look behind the wires close to where the letter "n" in the word not is in the above photo
  7. May 17, 2009 at 7:05 PM
    JsAZ
    JsAZ [OP] Member
    Gilbert, AZ
    Thanks for all the advice. I ended up going to the dealership and one of the service guys said that they always take the bottom half of the dash off to retrieve the connector. I bet you could probably find it without taking off the bottom dash, but you'd have to know where to look.
    Once I got the bottom part of the dash off, I could see it very clearly. I still had to retrieve it by reaching my hand up from underneath, but it was much easier.
  8. May 17, 2009 at 7:10 PM
    tacojim
    tacojim Member
    aus tx
    09 dc sport
    now that I know where it is, I could get to it without taking off the kick panel or the lower part of the dash..before my first post today I spent at least 30 minutes looking for it and could not find it.
  9. Mar 21, 2013 at 7:15 PM
    BBelwood
    BBelwood New Member
    I found mine it is tucked in the wad of wires. I extended mine and put a four wire male to female connector on it, I ran the wires to the empty pocket on the right side below the steering wheel. I just plug it in when I need it. Now if you intend to use the Manuel brake you may want to mount it.
  10. Jul 14, 2013 at 12:40 PM
    Thighmaster
    Thighmaster Well-Known Member
    Ward, Colorado
    2012 Red TRD Off-Road
    June 2016 OME Dakars + 3" ToyTec Boss Lift
    Thanks so much for that! Without popping loose the left lower half of the dash would not have found it. Even then it was pretty covered up. Again - thank you.
  11. Jun 18, 2015 at 9:53 AM
    JasW
    JasW New Member
    Jas
    2011 Taco Double Cab
