Brake Fluid Change Interval 30k miles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Felt, Nov 2, 2024.
  1. Nov 2, 2024 at 9:36 AM
    Felt
    Felt [OP] Member
    23 SR 4WD DCLB
    I went in for my 30k mile service on my 2023 tacoma SR and was surprised the service desk guy said a brake fluid change was due. Had this vehicle for just over a year and have never replaced brake fluid in a previous vehicle before unless it had water in it.
    The service schedule shows this as a line item every 30k miles which is almost every 16ish months apparently, seems excessive.
    Everyone else also just replace brake fluid this often?
  2. Nov 2, 2024 at 9:41 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Seems excessive to me, too. I’ll replace brake fluid every 7-10y as long as measured moisture content stays low and everything looks OK. Never had a problem with that.
    Jpalafox and Jakerou like this.
  3. Nov 2, 2024 at 9:53 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    BillF1564 and Clearwater Bill like this.
  4. Nov 2, 2024 at 11:36 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Brake fluid is more dependent on time than mileage. I definitely try not to let it go longer than 4-5 years because I live in a humid region.
    My motorcycle gets replaced/bled every 2 years because it has a less fluid and goes "bad" quicker.
    MGMDesertTaco likes this.
  5. Nov 2, 2024 at 11:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    Amazingly dealers don't always have your best interest at heart. :eek:
  6. Nov 2, 2024 at 12:00 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    I've been getting the reminder from the dealership for the last 2 years. Truck just turned 4 years old. Apparently brake fluids are hygroscopic (water absorbing), which means they absorb moisture from the atmosphere under normal humidity levels. In the rainy PNW I may consider having it changed soon. Although, looking at the brake fluid recently, it still seems to look okay. In the past I recall having brake fluid replaced when I had major brake work done. Never as a stand alone maintenance item.
    Toyota's are known for their reliability. Deciding on maintenance intervals requires some research and deciding what you are comfortable with. Lots of opinions out there. Especially when it comes to changing fluids.
    MGMDesertTaco and soundman98 like this.
  7. Nov 2, 2024 at 12:22 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    every 5 years is my rule but if it starts looking dirty i flush the system. It takes 30 min with a power bleeder
  8. Nov 2, 2024 at 12:49 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Look at your brake fluid. Brand new when it comes out of the can, it's clear. Is yours?
    I try to change mine at 30k so I don't have issues later.
    The fluid is far cheaper than a new truck
  9. Nov 2, 2024 at 12:57 PM
    Bishop84
    Bishop84 Well-Known Member
    Its an aggressive tactic. Brake fluid rarely fails or boils on vehicles, especially toyotas.
    I usually just suggest doing it with brake pads or every 5 years.
    I never sell it to customers unless its with a brake job.
    RotorRPM, t0p_d0g and Canadian Caber like this.
  10. Nov 2, 2024 at 2:11 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Not needed. They prob tried to sell you a rear wheel alignment.
    doublethebass likes this.
  11. Nov 2, 2024 at 3:22 PM
    Roof Walker
    Roof Walker Well-Known Member
    SE Michigan
    2021 Tacoma TRD Pro MT
    Maxxis Militia
  12. Nov 2, 2024 at 3:31 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Back in my youth, nobody changed out brake fluid. That shit would be black as tar and it still worked fine.
    At some point does it make sense to do so? I guess but I can assure you that it is probably more than fine at 30K miles.
    TacoTime55 likes this.
  13. Nov 2, 2024 at 3:34 PM
    auskip07
    Skip
    Atlanta, Ga
    cars have changed since the 60s
  14. Nov 2, 2024 at 3:43 PM
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    I understand what it means for brake fluid to be hygroscopic…I just don’t understand at which point the fluid in a sealed system comes in contact with moisture in the air, aside from having the fill cap off when checking moisture levels. If there are no leaks, and the brake system is in good working order, I just don’t see where the moisture would come from.
    Since getting involved with maintaining cars (circa 1985), I’d never once replaced brake fluid as a preventative measure. Never even heard of such a thing until around 2015. I’ve also owned multiple vehicles that never once had the brake system opened/flushed/bled for any reason in more than 12 years of service for each (12yrs, 15yrs, and 18yrs respectively). Granted, I always inspect the brakes thoroughly, replace pads/shoes/rotors/drums before they start squealing, and keep properly lubricated where appropriate.
    Has brake fluid chemistry changed at some point where it degrades? That’s the only thing I can think of, that would mandate replacement of fluid in an an otherwise well maintained brake system.
  15. Nov 2, 2024 at 3:49 PM
    MGMDesertTaco
    About every 2 years imo.
  16. Nov 2, 2024 at 3:49 PM
    Bishop84
    So what I've seen professionally is things fail sooner. In Toyota land the older ABS modules fail sooner and contaminate. We see it in Corollas and 1st gen tundra/sequoias.
    Personally I've boiled a caliper once, and it may have been preventable if I had fluid with lower moisture.
    So I agree its not critical, but it needs to be done at least every 5 years.
    KY_Rob[QUOTED] likes this.
  17. Nov 2, 2024 at 3:57 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Did you take it to a Porsche dealer by mistake?
    With that in mind, though, my fifth generation 4Runner brake fluid was completely grungy at 60,000 miles.
  18. Nov 2, 2024 at 5:35 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    As the pistons move a tiny bit of water can make it into the caliper. I've never tested the moisture content of fluid in the caliper, but if it hasn't been changed in a while it comes out dark yellow with black particles floating in it. Not sure if it's moist or just cooked from the heat of braking.
    I used to have a 4th gen 4Runner, and they had lots of problems with the pistons getting stuck from corrosion. I don't know if changing the fluid helps, but it can't hurt. I don't hear about the problem much with newer 4Runners and Tacomas, so maybe they changed the design.
    KY_Rob[QUOTED], balljoint and SH10151 like this.
  19. Nov 2, 2024 at 5:39 PM
    spp
    spp OC, Kalifornia
    OC California
    Went thru the Maintenance schedule for my 2023 and no where does it call for fluid replacement.
    It falls under the dealer recommends it so they can pay for those nice new buildings.
    Just say no.
  20. Nov 2, 2024 at 5:51 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Flush it every 3 years or so
    It isn't a sealed system, there has to be some type of vent to atmosphere at the reservoir, otherwise there'd be vacuum when the level goes down over time.
    When you panic stop on the freeway the fluid can (and does) boil a bit down at the calipers. Haven't you seen the aerated fluid coming when when you bleed it? I have.
    Regular flushing keeps the pedal firm, keeps grit out of the reservoir and keeps seals happy
    No way I'm leaving it in there for years until it's all black
