Brake fluid change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dady83, Nov 13, 2023.
  1. Nov 13, 2023 at 5:51 PM
    Dady83
    Dady83 [OP] Well-Known Member
    2020 Tacoma SR5
    Hi there! Want to do brake fluid change just wanted to know how bottles I will need. Thanks in advance
    Chew likes this.
  2. Nov 13, 2023 at 5:53 PM
    Bishop84
    Bishop84 Well-Known Member
    1 qt or 1 liter does the job well.
  3. Nov 13, 2023 at 5:54 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    There’s no point unless you flush. Suck all the old fluid out of the reservoir with an old turkey baster. Fill with fresh fluid. Bleed from right rear drum first till fresh fluid comes out. Then do left rear. Then right front. Then left front. Do it in line with a tire rotation and it adds about an hour total.
    HondaGM and Greg-tacoma like this.
  4. Nov 13, 2023 at 9:07 PM
    Dady83
    2020 Tacoma SR5
    That is what I meant, thanks
    HondaGM likes this.
  5. Nov 14, 2023 at 2:31 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I always get two bottles
    Always worried about running out when flushing
  6. Nov 14, 2023 at 3:08 AM
    MGMDesertTaco
    2 quarts should be enough to flush the entire system and fill the master unless you're slopping it everywhere. Don't get any of it on the paint. Wash it off with soap and water asap if you do.
    HondaGM, faawrenchbndr and Dady83[OP] like this.
  7. Nov 14, 2023 at 3:57 AM
    Dady83
    2020 Tacoma SR5
    Any specific brand recommended? I know what's matters is dot3 and not being a toyota brand.
    HondaGM likes this.
  8. Nov 14, 2023 at 4:01 AM
    MGMDesertTaco
    HondaGM likes this.
  9. Nov 14, 2023 at 4:01 AM
    airforceb2cc
    Don
    KCMO
    Nope, any brand will do. Prestone when it is on sale, otherwise Wally World.
    SmoothTRD, HondaGM and faawrenchbndr like this.
  10. Nov 17, 2023 at 8:44 AM
    Dady83
    2020 Tacoma SR5
    HondaGM likes this.
  11. Nov 17, 2023 at 8:49 AM
    airforceb2cc
    Don
    KCMO
    Sure will.
    HondaGM and Dady83[OP] like this.
  12. Nov 17, 2023 at 10:09 AM
    dil
    dil Well-Known Member
    Rocklin, CA
    2019 SR5 DCLB V6 4x4
    Stock
    Is the procedure to bleed the brakes the same as with older vehicles using the old crack the bleeder open, pump, close, release, repeat? I’m not familiar with how the electronic booster works for this system.
    HondaGM likes this.
  13. Nov 17, 2023 at 11:02 AM
    twtaco$
    twtaco$ Well-Known Member
    I use a mighty vac. Crack the bleed screw start pumping fill up the little bottle until the fluid coming out looks clean. Don’t let the MC go dry.
    Limited-time deal: Mityvac MV8000 Professional Single Person Manual Brake and Clutch Bleeding Tune-up Kit https://www.amazon.com/dp/B00265M9SS
    dil likes this.
  14. Nov 17, 2023 at 11:34 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    don’t let the cup, attach the mighty vac get full either. I used one of these few years ago and wasn’t paying attention. The cup got full brake fluid was sucked into the mighty vac, tool itself destroying the gauge
    dil likes this.
  15. Nov 17, 2023 at 11:35 AM
    twtaco$
    Done that one myself.
  16. Nov 17, 2023 at 11:49 AM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    If you have an air compressor, you can use an air-operated vacuum pump such as the one HF sells for $16.00. Far quicker and easier than using a hand vac. This pump is for AC systems, so what I did was add a 1/4 ball valve, a nipple for the tubing, and an old bleeder cup (which can easily be made from an old pickle, jam jar, or any container that seals). I plug it into my air system, apply some vacuum by opening the ball valve, crack the bleeder valve and pull through fluid until fresh fluid comes through. Close the bleeder valve, and then close the ball valve to stop applying vacuum. It works like a charm, and you can do the whole thing by yourself. It's also pretty clean. I have found I need to add fluid to the reservoir after each brake is bled.
    dil and Chuck X1 like this.
  17. Nov 18, 2023 at 5:17 PM
    Dady83
    2020 Tacoma SR5
    Just changed the AT oil and YES it was a qt short. I had heard about it lots of time an never believed it. SMH
  18. Nov 23, 2024 at 5:26 AM
    TBLTravy
    TBLTravy Well-Known Member
    2019 SR5 4X4 Sement , 2016 DCSB *sold*
    Did you ever do the brake fluid? Going to do mine soon and never done it before.
  19. Nov 23, 2024 at 5:40 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  20. Nov 23, 2024 at 6:21 AM
    BillyE
    BillyE Well-Known Member
    Nothing wrong with DOT 4, 4LV, or 5.1 either. Just not silicone DOT 5
