Brake Fluid Leaking into my Cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Riotswarzone, Jun 9, 2010.
  1. Jun 9, 2010 at 7:07 AM
    Riotswarzone
    Riotswarzone [OP] Member
    Brandon
    Greenfield MA
    Silver 06 SR5 TRD Access Cab
    I just got my 06 Tacoma two weeks ago from a small dealer in VT. The Break light came on shortly after getting it home, i check fluid level and filled it up, the light went off. 3 days later light is back on, Repeat process 1. Have filled the fluid 3 times already. Seems that my driver side mat has liquid on it, i think that it may be the Brake Fluid, is is possible for the fluid to leak into the cab?
    Any info would help
    thanks!
  2. Jun 9, 2010 at 7:22 AM
    EEtaco
    EEtaco Well-Known Member
    North Carolina
    09 V6 Prerunner
    Going from memory, you could check the hoses going into the reservoir as the clamps may be loose and fluid is running down into the cab. I'd also check the area surrounding the break pedal to see if their are any visible leaks.
  3. Jun 9, 2010 at 7:29 AM
    frybike6
    frybike6 Well-Known Member
    southwick, MA
    2010 tacoma doublecab longbed SR5
    Check under the master to see if it's wet, and it could possibly be leaking from the master into the brake booster and then finding it's way into the cab. Could be an internal leak. How does the pedal feel?? Spongy or have a nice solid feel?
  4. Jun 9, 2010 at 7:32 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I had brake fluid leaking onto my floormat from the clutch pedal. Had to have the clutch master cylinder replaced. Do you have a warranty with the dealer? I would think you could get them to take care of it since you just bought it.
  5. Jun 9, 2010 at 7:36 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Exactly what I was thinking. The clutch shares its reservoir with the brake system.
  6. Jun 9, 2010 at 8:38 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The master cylinder can also leak into the vaccuum booster. Check the vac line for fluid. It's the line that comes off the inboard side of booster and goes to the intake. If wet replace the master, booster, and check valve on the vac line.
    X2 on checking to see exactly where the fluid is coming from!
  7. Jun 10, 2010 at 5:56 AM
    Riotswarzone
    Brandon
    Greenfield MA
    Thanks for all the help!!! It's a small dealership...will be easier to have them fix it if i can give them something to fix. Thanks again.
  8. Jun 10, 2010 at 6:28 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2015 RAV4...c'mon lease, end already!
    3 Tacomas so far, waiting impatiently for my 4th
    Did you get it at Durand Toyota? If so, I was looking at that same Silver TRD before I bought my Tacoma. Damn nice looking truck if it is the same one! :thumbsup:
  9. Jun 17, 2010 at 9:25 AM
    Riotswarzone
    Brandon
    Greenfield MA
    I got it at Marks Motors in Bratt. Wholesale dealer. But its a Tacoma...they all look damn nice!!!
