Brake Light
Discussion in '1st Gen. Tacomas (1995-2004)' started by rrosebr, Nov 1, 2010.
  1. Nov 1, 2010 at 8:50 PM
    rrosebr
    rrosebr [OP] Active Member
    Drew
    Blacksburg, VA
    04 4x4 Dbl Cab V6 TRD
    K&N Air Filter, K&N Oil Filter, Security System MOD, Line-X Bedliner, Fog Light MOD
    I've noticed lately, since it has been getting cold, that when I first crank my truck in the morning, my 'e-brake' light is on. I try wiggling the release handle and even engaging and disengaging the hand brake. It seems to only go off after the truck and/or brakes warm up. Has anyone else noticed this issue?
    One other thing I may point out is I just did the fog light mod. Would this wiring change have caused this possibly? It seems to be more related to the weather.
    Drew
  2. Nov 1, 2010 at 9:09 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    Maybe just a worn out sensor? I have something similar with my 4x4 light. Since it's a handle on the ground there isn't any doubt when I take it out of 4.
  3. Nov 1, 2010 at 9:24 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Low brake fluid?
  4. Nov 1, 2010 at 9:44 PM
    jjsask
    jjsask Well-Known Member
    Regina, Saskatchewan, Canada
    2002 XtraCab 4x4 TRD
    My 2002 4x4 did the same thing, I even asked the dealership to look at it when they were doing the frame rust treatment and they told me to either live with it or replace the E-brake cable.
    Not being satisfied with this I tried a few things and I fixed it by lubricating the torsion spring that pulls the cable back. Its just inside the frame rail behind the drivers door, I soaked it with penetrating oil and it works great now. You could try WD-40 but its not a real lubricant so use some proper spray lube. It has been 2 weeks now and it was down to -10 Celsius and the light never stuck on.
  5. Nov 1, 2010 at 10:14 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    x2
    Add a little fluid to the reservoir to see if the light stays off.
  6. Nov 3, 2010 at 8:10 PM
    rrosebr
    Drew
    Blacksburg, VA
    But why would it go off after the truck warms up? Could it have something with the cable tension changing in the cold?
  7. Nov 3, 2010 at 8:47 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mine will freeze up if it's super cold and wet... like when rain changes over to snow. That was an ugly morning... no doors would open and the e break was stuck on. I don't use it when it snows anymore.
  8. Nov 3, 2010 at 10:50 PM
    rrosebr
    Drew
    Blacksburg, VA
    but the hand brake is never engaged when this happens. I just get in, crank the truck, and the light is on.
  9. Nov 3, 2010 at 10:59 PM
    Leadgolem
    Greg
    Littleton, CO
    I'd try checking the brake fluid levels, maybe adding some, like already mentioned. I don't know if there is a separate light for low brake fluid or not. If not, then the volume difference in the fluid would explain why you get the light when it's cold. You'd be sitting very close to the point where the light would come on in normal temps. When it's cold, and the volume of the brake fluid decreases, you would get the light. Then, when the truck warms up, and the brake fluid temp and volume goes up a little, the light goes off.
  10. Nov 3, 2010 at 11:01 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    mine did that untill i took off the washer on the spring adjustment that was binding up the cable under the drivers side.
  11. Nov 4, 2010 at 8:32 AM
    Digiratus
    Roaming the PNW
    The RedHead
    x2
  12. Nov 4, 2010 at 11:51 AM
    Madjik_Man
    Colorado Front Range
    My e-brake used to always do that. Especially when cold.
    My buddy (Tacoma enthusiast) adjusted it somehow and I've never had the problem since. I'll ask him what he did, and get back to you.
  13. Nov 4, 2010 at 3:39 PM
    FightFire48
    FightFire48 Taco Monster
    Will
    Spokane, WA
    04 Taco dbl cab
    3" Toytec lift AEM BruteForce CAI Gibson exhaust 2 - Rockford Fosgate 8's
    I looked everywhere online and they said you could adjust it a little bit just by raising it. But even though your fluid is at max fill line the toyota dealership said fill it pass the line and your problem should go away. They almost filled mine up and since i filled it that one time never had a problem. Hope this helps
