Brake lights ground location
Discussion in '1st Gen. Tacomas (1995-2004)' started by Vann, Apr 16, 2018.
  1. Apr 16, 2018 at 10:09 AM
    Vann
    Vann [OP] Well-Known Member
    Garth
    Weisenburg, PA
    '04 x-cab 4x4, 2.7 5sp. "The Black Pearl"
    stock
    As the title says can anyone point me in the right direction as to where the rear brake lights are grounded on an '04 4X4 xcab? The issue I'm having is when the lights are on, one side is dimmer than the other and when the brakes are applied the problem switches sides. I suspect it's a grounding issue.
  2. Apr 16, 2018 at 11:40 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    There're two spots that they're grounded at. One behind the driver's side kick panel and one behind the the passenger side kick panel. The scuff panel and kick panel Both need to be removed. Both are about 8 inches from where the door hinges toward where the firewall and fender meet. White wires with blk stripe held to the body with gold bolts.
    ThunderOne likes this.
