Brake lights on when the trailer is connected.
Discussion in 'Towing' started by iflyfish, May 7, 2008.
  1. May 7, 2008 at 12:03 PM
    iflyfish
    iflyfish [OP] New Member
    Baraboo, WI
    02 4Dr.
    Greetings.
    I have an 02 Tacoma that I had a Tekonsha Voyager brake controller installed in. I noticed when I hooked it up for the first time that the as soon as I connect the round trailer connector from the camper, the brake lights on the truck go on. I also have no brake lights on the camper. Everything else seems to work fine. I have running lights, turn signals, the trailer brakes work fine, etc.
    As soon as I unplug the connection to the trailer, the brake lights on the truck go back out.
    Anyone else seen anything like this? Am I missing something in the installation process?
    Thanks much.
    -Eric
  2. May 7, 2008 at 12:13 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    That would be caused by shorted or improper wiring. It could be either on the truck or the trailer side. If you know the trailer correct I'd question the brake controller install. Either plug the trailer into someone elses truck or plug a different trailer into your plug and see what happens to narrow it down.
  3. May 7, 2008 at 12:20 PM
    iflyfish
    Baraboo, WI
    02 4Dr.
    Thanks Roland. I'll see if I can find someone that has a trailer and a truck with a brake controller installed.
    Edit - We had towed the same camper, with the same Voyager controller, in a Tundra for the last two years - with no issues. I check the trailer over pretty well after winter storage, just in case a mouse nibbled on a wire somewhere. Everything on the trailer looks good. I have to believe that the guys that did the brake controller install have something messed up. I just wanted to make sure there wasn't some sort of module that was needed with the Tacoma, or something obvious that was missed.
    -Eric
  4. May 7, 2008 at 8:52 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Sounds to me like the outfit that installed your brake controller tapped the wrong wire for the brake output, or did not splice or insullate correctly. Something is shorting accross somewhere. Also, I would tend to suspect that as of right now you have either NO trailer brakes or fully engaged trailer brakes at all times. Either case is VERY BAD. Take the truck itself back to them, and have them sort it out, you paid them for a job that is not correctly completed, it's there problem to fix, and stand there over their shoulder to make sure that they tape up or heat shrink up anything they touch so that you don't get 500 miles down the road and have a problem again. If you don't want to trust them then send me some pictures of how they hooked it up, wiring, with voltage readings with the truck off, truck on, and brake pedal depressed, and I'll try to sort it out for you.
  5. May 12, 2008 at 4:17 PM
    iflyfish
    Baraboo, WI
    02 4Dr.
    Ok, I think we have most of the issues figured out. The trailer brakes work, turn signals work, running lights work, I can shift into gears without the trailer attached, etc.
    Now, the only issue that remains is the brake lights. As soon as I plug the trailer into the 7-pin connection on the truck, the brake lights on the truck come on. They stay on, even when the truck is off, until it is physically disconnected.
    Any ideas? Someone else mentioned that I may need some sort of converter, to covert the seperate tail/brake lights of the truck to the combined tail/brake lights on the trailer. If so, does anyone know what that might look like? Any part number or anything.
    Thanks for the help.
    -Eric
